VWVortex.com - Jetta IV AEG does not start - P0322 "engine speed sensor" suspected
    Results 1 to 14 of 14
    Thread: Jetta IV AEG does not start - P0322 "engine speed sensor" suspected
    1. 10-05-2006 09:19 PM #1
      Ok, my girlfriends car wouldn't start, so I started diagnosing the old fashioned way. Fuel pump ran, exhaust smelled like gas. So no problem with the fuel delivery. Checked for spark, no dice. So I did a bonehead move and ordered a DIS coil (this is a Jetta IV with the AEG engine) from germanautoparts.com, but that didn't solve the problem.
      So I went out and bought a scan tool, which revealed code P0322, which somehow relates to the engine speed sensor. Now, I noticed in the [crappy] bentley manual that I borrowed from a friend that the engine speed (crank) sensor is only mentioned in the fuel injection section, but no matter. I checked (what I believe to be) the engine speed sensor as per the manual and saw infinate resistance accross all three wires (one of the combinations, between terminals 2 and 3, should read between 480 and 1000 ohms). So, my first question.... Is this picture accurately showing the "engine speed sensor" connector?
      And if so, I believe the connection cable routes to this sensor, which is sort of located to the lower right of the oil filter (as vied from in front of the car looking at the engine):
      And final question, is that if this indeed IS the engine speed sensor, and it is indeed preventing the car from starting (as the manual/scantool suggests it would), does anybody have the VW part number so that I may avoid a whole bunch of headaches at the VW dealer?
      I would appreciate any help.... My girlfriend is growing tired of a 1+ hour commute in my somewhat uncomfortable impreza, and I'm getting sick of driving my dodge ram to work....
      Once again, just to clarify.... 1999 Jetta IV, auto, 2.0 AEG.
      Thanks a bunch.
      Modified by LUME at 1:20 AM 10-6-2006
    2. 10-05-2006 10:17 PM #2
      Is this the same as "crankshaft position sensor" and "impulse sender", if so the part number is 06A 906 433C for AEG engines.
      BTW the engine will not run, or stop running if this sensor goes bad.
      Modified by randallhb at 8:19 PM 10-5-2006
    3. 10-05-2006 10:31 PM #3
      It definitely is a crank position sensor of some kind, so I guess this is it... Thanks for the input!
      --Roy
    4. 10-07-2006 02:54 PM #4
      Part number is correct, and car now starts! Thanks!
    5. 10-21-2006 10:57 PM #5
      Hi - I have a problem where my car stalls when it gets to operating temperature, then wont start till it cools ALL the way down. Was this part of your symptom. I have replaced all I can think of except the RPM sensor - (crank sensor).
      I have replaced the following:
      Coil, rotor, cap, wires, plugs, IAF sonsor, both coolant temp sensors, air filter. I just looked a the codes and the P0322 was one of many along with a P725 (speed sensor) and a P1580 (idle speed contrl).
      I had been disconnecting the temp sensors so there were a few of those in there as well.
      I actually have the crank sensor and will slap it in tomorrow regardless. I am just nervous as this car has stranded me (1 hr at a time while it cools) too many time and I am about done.
      Did this crank sensor fix yor problem? anything you can think of
      Thanks,
      Mike
    6. Member 97VWJett's Avatar
      May 17th, 2003
      Redmond
      Mk3 2.0, Mk4 2.0, B4 VR, C5 Allroad
      10-21-2006 11:01 PM #6
      Quote, originally posted by LUME »
      ... and car now starts! Thanks!
      Shop Owner/Manager @ IPM Auto Service
      8543 152nd Ave NE
      Redmond, WA 98052
      425.883.6311
      Emissions Certified, VCDS, MIG Welding, Fabrication, Honesty, Integrity, and more.
    7. Member 97VWJett's Avatar
      May 17th, 2003
      Redmond
      10-21-2006 11:05 PM #7
      P0322 http://forums.vwvortex.com/zerothread?id=1550552
      P0725 engine speed sensor. ECU can't read RPMS
      P1580 Just clean the throttle body and you'll be set.
      please use this link from now on: http://forums.vwvortex.com/zerosearch
      search terms: P0322, P0725, P1580, search archives and topic titles
      8543 152nd Ave NE
      Redmond, WA 98052
      425.883.6311
    8. 03-25-2007 03:00 PM #8
      I have a CEL with Code P0322. I also have Warm Starting issue. Some times the car wont start after a drive. If i let is sit for a few minutes it Tends to Restart. As of now the issue is still intermittent. The price of the sensor on Worldimpex is $52.00. any one think i maybe able to take it out and just clean it? If not does any one know some where cheaper to get one? I know 52$ is not much, but Im a pretty broke college student. To bad there arent any VW Salvage yards around here....
    9. 03-26-2007 11:44 AM #9
      any one?
    10. 03-30-2007 12:26 PM #10
      Quote, originally posted by Mussen »
      Screw it.....I guess my credit card takes another hit....
    11. Semi-n00b daveyfuentes's Avatar
      Dec 8th, 2007
      Hudson Valley, New York
      99/VW/Jetta
      03-23-2010 09:13 PM #11
      Hi. I am having nearly the same problem. I get codes 00297 and every once in a blue moon 00281. 00297 is the speed sensor (Or cranck shaft position sensor) and 00281 is that the sensor is not connected. Now i have replaced the sensor once before. However, the male connector part does not match the female connection part. We altered the male part to make it fit. (the female part is rectangular.) The male part is as shown up above, flat on one end and then a U shape. Does anyone know the part number for the sensor with a rectangular male connection part? any help would be extremely helpful.
    12. 11-12-2010 06:43 PM #12
      I had the random stall at traffic lights, felt like there was in 'inconvenience sensor' on my car.
      My ODB2 reader threw the P0322 error - if the EPC light had turned on, subsequent re-starts cleared the error. Intermittent problem, intermittent error code.
      Followed the advice here, picked up a new impulse sender/reference sensor/crankshaft position sensor/distributor trigger sensor or part # w0133-1617649
      Installed and works like a charm.
      My two cents.
      Bolt = hole in new sensor?
      Upon removal of the retaining bolt, verify that the bolt and hole in the new unit are sized correctly. My new part had a hole 1/16th inch too small, we spent 20 minutes trying to line things up before we checked. 30 seconds with a drill bit and we were good to go.
      Finding the sensor.
      The Haynes manual showed a random part of the car with a series of connectors, but no indication what part of the engine (top? bottom? side?)
      To find the sensor position, start at the firewall, (remove the 3 coolant bottle mounting screws and gently pull away. Find the grey shrouded connector at the firewall and follow the cable from the electrical connection down, the part can be replaced from above and the oil filter does NOT need to be removed.
      Add a tool to the list - Magnetic pickup
      Have a magnetic pickup handy, we dropped the mounting bolt 3 times before we got everything finished.
      Total time - including re-tries, screw dropping and mounting hole adjustment, < one hour
    13. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      11-12-2010 06:57 PM #13
      Your pics look uncannily like mine lol:
      http://forums.vwvortex.com/showthrea...ght=TECH+p0322
      Always check for codes before throwing parts at a situation... don't know how my DIY/info thread didn't get found.
      EDIT: ****ing owned by a zombie thread... I appreciate the people who search but casting "raise dead" on some of these threads is useless.
      Anyways cheers.
      I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
      Current: 2004 Golf TDI 5MT
      Previous: 2003 VW Jetta TDI 5MT | 2002 Audi A4 1.8T Quattro 5MT | 2005 VW Passat Wagon 1.8T 4Motion 5MT | 2007 A4 Avant 2.0T Q/6MT | 2000 VW Golf 2.0 5MT
    14. 10-19-2013 09:38 AM #14
      I realize that it has been several years, but do you remember what the fix was? I am having a similar issue with my VW.
      Thanks
