VWVortex.com - Info on Syncro rear brake variations
    Results 1 to 17 of 17
    Thread: Info on Syncro rear brake variations
    1. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      Supercharged 6 spd 98GLX, Choptop 66 Beetle with Porsche 944 brakes and 5 Speed, 13 Sportwagen TDI
      10-09-2006 09:08 AM #1
      I have just the straight up syncro, I'm assuming to switch to disc brakes that it's probably just a matter of swapping on some form of factory bracket to hold the caliper and also the hub and rotor. Is this right?
      Edit....
      I need to clarify this thread. I understand how to do a rear disk brake conversion on any other car. I also figured out that the G60 syncro had them too. What I basically need to know is does the hub somehow attach directly to the control arm or is there another bracket that bolts on first.
      Modified by mechsoldier at 6:34 AM 10-9-2006
      Dub Autowerks VW, Audi, Porsche, and BMW parts and service
      1723 West Valley Hwy E
      Sumner, WA 98390
      http://www.DubAutowerks.com
    2. 10-09-2006 10:25 AM #2
      Check out this site gives you an idea what is involved. http://www.amh-tuning.de/index1.htm
      The rear hub gets pressed in just like the front and all you do is bolt on the caliper carrier and caliper. Hope this is what your looking for.
    3. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-09-2006 11:51 AM #3
      Is this pressed into the bearing....because that's kinda what it looks like to me.
      Sumner, WA 98390
    4. 10-09-2006 05:06 PM #4
      Quote, originally posted by mechsoldier »
      Looks to be pressed into the hub should have the ears on the back side with the threaded holes for the caliper carrier.
    5. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-10-2006 01:42 AM #5
      Well that's the problem I'm having
      Here you can see I have the control arm sitting in my room. Those holes you see that look like they could be for a caliper, they aren't threaded. Then you can see that splined sleeve the axle goes into, so does the hub press onto this or what.....That's my problem. Do I need that piece from a disk break syncro because the drum one won't accept the hub from the disk setup, or do I just need to get the hub from a syncro setup.
      Or did VW in their wisdom (which they're admittedly very good at usually) design the system so that you can use the disk brake from ANY rear disk setup and just press it over that sleave to accept the axle (I.E. is that sleeve the same as a VW rear stub axle in outer dimensions just with a hole in it so it can accept the axle)
      Sumner, WA 98390
    6. 10-10-2006 10:12 AM #6
      Okay first off the splined part is the hub, it is pressed into the control arm with a bearing. The holes should not be threaded as the caliper carriers have the threads ( carriers are syncro specific) in them. The rotor goes on just like the front of the car with a set screw to hold it to the hub. Hope this helps.
    7. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-10-2006 03:44 PM #7
      So are you telling me the drum setup and the disk setup use the same hub....because that's what I'm asking.
      Sumner, WA 98390
    8. 10-10-2006 05:41 PM #8
      Looks to be the same but I've never seen the hubs for drum brakes in person, I can't imagine they're different. You need to see if someone can check etka to compare part numbers.
    9. Member eurowner's Avatar
      Jan 25th, 2002
      The Syncro Ranch, Salida CO
      1982 VW Golf GTi 1600 '85 GMC K3500 6.2 Diesel '17 Toyota Tacoma TRD OR 4DLB
      10-10-2006 09:49 PM #9
      NO!
      Drum rear ends use a spindle shaft. The Drum spins on the bearings between the shaft and the drum its-self, which the wheel bolts too.
      If you are running a CV jointed drive shaft, the outer cv joint will fit through the hub-via splines, and drive the wheel.
    10. 10-10-2006 09:54 PM #10
      OK that answers that question but the picture of his still looks like a regular disc brake rearend, am I right or wrong?
    11. 10-10-2006 10:40 PM #11
      Quote, originally posted by orangea2vr6 »
      yes it does, but he needs to pull off the drum and show us the other side [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-11-2006 03:28 AM #12
      HAHA if I could pull off the drum and look at the other side I wouldn't even be having to ask this question...I already shipped it back to the states. Doesn't anybody have an etka or something
      Sumner, WA 98390
    13. Member 1.8TsyncroB3's Avatar
      Mar 7th, 2001
      Montreal Area
      10-11-2006 11:11 AM #13
      The answers can be found in the forums of the UK syncro site http://www.vwsyncro.co.uk, just look through the thread titles and you'll find it. you will have to register to view some of the threads. The thread on this subject can be found here: http://www.vwsyncro.co.uk/data...D=119
      To make it short, the Drum brake syncro set-up is easily converted to Discs by removing the drum and back plate & fitting the disc brake dust shield and disc. The caliper bracket mounts to the holes shown in your photos. YES the drum brake set-up uses the same hub as the disc brake set-up. you will obviously also require handbrake cables for a golf/jetta syncro, but fortunately the calipers are common Mk2/Mk3 items. Even the Mk4 aluminum calipers can be made to fit with a bit of tweaking.
      Modified by 1.8TsyncroB3 at 11:12 AM 10-11-2006
    14. Moderator yellowslc's Avatar
      Aug 29th, 2000
      Houston
      10-11-2006 11:27 AM #14
      To toss another option out there:
      I had caliper carrier spacer brackets machined which bolt to the syncro control arms to allow corrado/mk3 vr front hubs, corrado/mk3 280x22 vented rotors and TTQ/R32 rear calipers/carriers to bolt right up. I will be picking up my rear syncro beam this week from being modified so I can finally assemble and take some photos of this.
      The other option is the syncro specific caliper carriers with that super wide mounting pattern.
      R
    15. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-11-2006 01:14 PM #15
      There's another option also, apparently the Seat Cupra-R uses 305 mm x 28 mm rotors and also the boxter caliper can be mounted up using an S3 caliper bracket....(although I only saw it done in the front)
      Sumner, WA 98390
    16. Moderator yellowslc's Avatar
      Aug 29th, 2000
      Houston
      10-11-2006 02:44 PM #16
      The width of the mounting bolts on the syncro control arms is much wider than anything else VAG. That is the issue.
    17. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      10-11-2006 02:50 PM #17
      meh...oh well, I start going to school for machining in 2 months....I'm a master certified mechanic already and not looking to change jobs, I'm just looking to be able to end all this nonsense....It goes into cad in the first semester...Soon it should just be does it fit? No not yet but it will tomorrow
      Sumner, WA 98390
