Page 41 of 47 FirstFirst ... 31 37 38 39 40 41 42 43 44 45 ... LastLast
Results 1,401 to 1,435 of 1619
Thread: the JEEPS only thread!
    May 27th, 2008
    Malvern, PA
    5.7L WK2 | 2.5L TJ
    07-13-2012 02:25 PM #1401
    Quote Originally Posted by 972SLOW View Post
    You drive all the way to york to wheel but dont go to treverton, shamokin, or centralia? If this is true, you sir are crazy theres some great trails up there and you can ride all day and not be on the same trail.
    I get the reading anthracite company land use permit.
    So yes, I legally ride a lot the trails in that area, burma road, behind the 901 pub, st claire...
    I've crossed the crack on the abandon section of 61 south of centrailia too, which is marked on RAC's map, not sure how much they specifically own though.
    The spot outside delta pa (york) is the closest to me believe it or not.
    The new outdoor adventure park or whatever it's called below Treverton is on my list, just haven't been up that way yet, but we used to ride near whaleback damn near a decade ago...
    98 wrangler build
    the position being taken is not to be mistaken for attempted education or righteous accusation only a description just an observation of the pitiful condition of our degeneration
  2. Member horsty69's Avatar
    Jun 21st, 2003
    PA
    2013 TSX, 2011 MINI, 2011 Zuma 125
    07-13-2012 02:40 PM #1402
    Difficulty ranges from easy to difficult depending where you go there and if you know the trails. I warn you now, scope any pit before entering unless you see someone go through it as there are some that will swallow your rig and you but look harmless. Alot of it is nice clay up there and real soupy. Step in it and lose your boot. The main trails are easy riding and you could even take a car down some if you wanted (ive seen it done at highspeeds ) Pretty much everyone goes there and gets trashed. As far as directions hop on 61n and ride it all the way up. Go past old 61 and its like i wana say 20 minutes or so past mt carmel. Once you get up there, theres locals that will help you out and stuff but dont go solo. Very small world. Glad to see another local on here. (95% of these pictures dont show up for me) whats your rig? Also a heads up, if your rolling on some a/t's that arent very many plys then i would recomend bringing plugs and a pump as theres some debris up there from the locals. I cut 3 sidewalls on my 35x12.50's but plugged them to get me home. I now ride on 35x10.50 boggers which are 6 ply so i no longer have to worry about that.
    Thanks...my rigs a 2005 LJ, 2inch lift, 31X10.5 Duratracs Im in the process of monstalining it...pretty mild and mostly stock as you can see. I am worried about my tires as if you are familar the duratracs are an AT, although a very agressive one at that. Why do you say not to go up alone..get lost, get stuck, hear banjos?
    If you decide to go sometime hit me up...Id like to wheel for a day.
  3. Member 972SLOW's Avatar
    Feb 14th, 2011
    Reading, Pa
    1978 SUBURBAN LIFTED WITH 35 BOGGERS AND A BUILT 350, JEEP, BUICK, low mileage 337
    07-13-2012 02:43 PM #1403
    Quote Originally Posted by deucestudios View Post
    Oh alright, i was under the impression for some reason that you never venture that way. Yea i have heard word that your supposed to have a reading anthracite permit but honestly i have never even seen one before and i have been going there for years. I also heard they only give out a very small number of permits a year and they are only available at a certain time so if this is true i wouldnt end up with one anyways as im sure the locals buy them out. Those are all good areas as well personally on the way up every time i love stopping at the old 61 and checking the cracks in the road as well as the new grafitti. Im not sure how much you have ridin up there but pretty much all the trails and pits have names like smurfs pond, mud rd, mud ln, the sands, the clay pits, etc. I believe its mud ln thats the worst one up there. Pretty much just really deep clay to the point where you have trouble even walking through it but i have seen some high dollar machines get stuck there as well as a stock rover on mudders make it through on the sidelines so i guess really as long as you have experience and arent stupid about it you will be fine.
    They finally got around to doing the outdoor park? I havnt been up there in close to a year but last time i was the locals were all pissed off because of talk about shutting down all the trails and making a park but then there would be no more drinking, camping, or other shenanigans. Hopefully its still good up there. Im sad to see everytime i go up its more and more destroyed by people dumping junk and whatever else.
    Quote Originally Posted by Chaoz View Post
    Psh speak for yourself whips and blacks are no longer friends.. **** whipped creme even makes me quiver
  4. Member 972SLOW's Avatar
    Feb 14th, 2011
    Reading, Pa
    07-13-2012 02:54 PM #1404
    Quote Originally Posted by horsty69 View Post
    Nice, dont see too many newer rigs up there but all the main trails are plenty wide enough that you wont need to worry about scratchs until you get to the good trails. Clearance wise you should be fine for the most part just got to watch the lines you take. As long as they are meaty you will be fine tread wise but if they are only like 2 ply then just know that you are warned. I went many times before having tire issues but that one time was enough to make me upgrade. I dont recomend wheeling anywhere alone honestly for obvious reasons but i dont recomend going solo up there because you can get lost easily, or if you break down, run out of gas, get stuck, run into a pack of coyotes (yes there are many and even some bear) I rolled up in a buddys cherokee previously and we got it stuck. Burried up to the hood in clay (he has 4" lift and 34" tsl's) and his winch line was long but 2 feet shy of the nearest tree. We ended up sitting there for about an hour or two before a local found us and pulled us out. He then told us about how nobody enters that pit really because its soo soupy. It was our own faults though as it was one of few pits we never tried and alcohol gets the best of you. While its on my head i recomend a snorkel as well. Ive seen many people hydrolock up there. You can get away without one but its recomended.
    I run a 78 suburban with a 4" lift, 35's, and no snorkel until now but when i ripped my engine apart my oil pan was caked in mud and i know i had water in there many times. Im wreckless though on the trails. We baja the rocky trails at like 35mph where the back ends starting to slide out on ya. Ill be sure to keep you in mind though for future rides. IM trying to get something together soon so i can take my kx or blaster up as i havnt had either up there yet.
  5. Junior Member
    Feb 3rd, 2005
    SoCal
    Wrangler Rubicon Unlimited
    07-13-2012 08:54 PM #1405
    Cugar Buttes, Lucerne Valley CA. We ran the Bull Frog and Cake Walk Trails. Technical and fun.
    Crevier MINI
  6. Member HumboldtCorrado's Avatar
    Jan 17th, 2006
    humboldt county, ca
    '90 corrado VR6; '00 GTI VR6; '93 Jeep Wrangler
    07-21-2012 02:24 PM #1406
    beach yesterday - northern california. sun finally came out, and i finished my '93 YJ's 8.8 swap/SOA a couple weeks ago. now i just gotta find some money for some new tires...
  7. Member 1badMKIrocco's Avatar
    Jan 18th, 2002
    Estes Park, Co
    Jeeps
    07-30-2012 02:36 PM #1407
    Here's a couple pics the GF took from a trail ride we did this past weekend.
    (The Jeep is on the Numbered NF road!)
  8. Member goody6691's Avatar
    Oct 2nd, 2004
    E-town MD
    STUPID YELLOW CAR
    08-13-2012 01:11 PM #1408
    mine
    DUBAUDI
    Feb 5th, 2009
    NW, Connecticut.
    '98 A4. PSS9 and more to come
    08-16-2012 09:05 PM #1409
    The more I check this thread the more I desire a jeep as a second car and not a mki jetta coupe. Hope I can afford a 4 door jk someday.
  10. Member horsty69's Avatar
    Jun 21st, 2003
    PA
    08-21-2012 11:22 AM #1410
    Quote Originally Posted by silvermannn View Post
    stay away from this thread...Jeeps are a contagious lifelong affliction.....if you dont listen to me you will end up living out of the back of your pristine jacked up JKU with maxed out credit cards and mud crusted on your clothing,and your face will still look like this
  11. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    1985 VW Scirocco Wolfsburg Edition
    08-24-2012 12:18 AM #1411
    I'm not going to lie, but I was some what disappointed with this thread
    I've loved jeeps since I was little because my dad has a 74 cj5, and that's what got me hooked on jeeps, but looking through this entire thread I've only saw a couple willies, one wagon (freaking loved that one the most), a couple cj's, an old school chief grand cherokee, and only a couple old j10's, I was quite surprised seeing brutas here, seen photos of that truck every where
    but this thread had mostly cherokee's and new yj's and tj's and even the new goofy jeeps, I just dont care about new jeeps and cherokee's they are every where, and when I read "JEEP only thread" i thought it was going to be a bunch of old school jeeps, but i guess I was misled
    but oh well, here is my old odd jeep, he has been put aside for now, work will continue on him in the future
    but he is an old 84 jeep J10
    clean
    Photobucket
    and dirty (after finding a little mud hole)
    Photobucket
  12. Member Iroczgirl's Avatar
    Feb 17th, 2007
    Bend, OR
    '55 Ford 351C, '80 Rabbit AAZ
    08-24-2012 12:27 AM #1412
    Quote Originally Posted by nickbukowy View Post
    clean
    Photobucket
    Photobucket
    I like it! I miss my Gladiator, J2000 shortbed, 327 Vigilante, 4 speed.
  13. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    08-24-2012 12:38 AM #1413
    holly cow
    such a good looking truck Irocz, Ive seen a couple J2000's and a J3000's and one J10, some had the 327 vigilante and others with a straight 6, i cant remember which one i saw were long beds instead, but they were all in pick n pull, just so sad, they had them for sale at a very cheap price too but i didnt have the money to buy them at the time
    but i love the V8 360 in mine, but the transmission and transfer case has to go though, seriously no numbers on them so i cant get any info on them and cant figure out what they are lol
  14. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    X,80,X,X,98,00,X,06,12
    08-24-2012 09:11 AM #1414
    sigh..
    Yes of course let's not forget the "rule" that any jeep 1 model year newer then the one we happen to own isn't a real jeep and should never be discussed...
    Every Jeep pictured in this thread or being discussed is in fact a Jeep, how can the title be misleading when it simply says "the Jeeps only thread"?
  15. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    08-24-2012 02:11 PM #1415
    Well the thing is when I here the name Jeep, I think of the old cj's or scramblers and willies and wagons, and the full size jeeps like the j10s and the wagoneers and chief cherokees
    I've seen so many Cherokees I just don't care for them, and the tj's and yj's and the Rubicons are all to new and just don't really like them for some reason, hey look good but it seems like some thing is missing, but I don't know
    Every one has their preferences, and I prefer older jeeps
  16. Moderator robbyb413's Avatar
    May 12th, 2002
    Boston, MA / Portland, ME
    2010 S4 Prestige, 1999 TJ 4.0, 2010 A4 P+ (Hers)
    08-28-2012 04:37 PM #1416
    And that is where any debate about this issue ends. This isn't the place to discuss that, start a new thread if you'd like to continue this line of thought. Thanks.
    VAG COM services available, send a PM | Join the VWVortex Folding@Home team... save the world | Current Rides: 2010 S4 Prestige, 1999 TJ 4.0 Sport | Old Rides: 2001.5 A4 1.8TQMS GTRS, 1997 TJ 4.0 Sport, 1990 Corrado g60 StageIV | Lounging in a field with 726 sweater cows
  17. Member
    May 27th, 2008
    Malvern, PA
    5.7L WK2 | 2.5L TJ
    08-29-2012 12:55 PM #1417
    For 972SLOW:
    98 wrangler build
  18. Member 972SLOW's Avatar
    Feb 14th, 2011
    Reading, Pa
    08-29-2012 01:13 PM #1418
    For 972SLOW:
    thanks man. Looks like some familiar spots. Bringing back some memorys. Looks like your yj came a long way from the backyard find. You get it stuck or broken yet? Cage looks good man. Keep it up
  19. Member Zyoid's Avatar
    Feb 25th, 2008
    Hudsonville, MI
    2012 VW Golf TDI
    08-29-2012 03:22 PM #1419
    -Obama Sucks-
  20. Member Power5's Avatar
    Jun 19th, 2001
    Cincy, Ohio
    '99 XJ 6"-Aussied d44-35" TSL-XRC8 / '11 Sonata white yay
    09-01-2012 10:44 AM #1420
    Should not have stumbled back into this thread. Makes me want to get my jeep running again. Electrical gremlins have had it parked for 2 years now.
    From her Glory Days:
    Aaron
    PSN: RealPower5
  21. Member
    Mar 20th, 2011
    Sheboygan, WI
    06 VW GLI, 98 Cherokee
    09-08-2012 06:55 PM #1421
    Quote Originally Posted by Power5 View Post
    How could you let the poor XJ sit for 2 years. Find a part out and buy the harness, swap it in and go.
    Finished my HD Offroad mid-stiffeners last weekend (front and rear stiffeners to go) and I scored an awesome deal on a Rough Country long arm upgrade
    06 GLI
    98 Jeep Cherokee
  22. Member
    May 27th, 2008
    Malvern, PA
    5.7L WK2 | 2.5L TJ
    09-10-2012 09:35 AM #1422
    Got another one.
    Not keeping it.
    '98, 4.0L, 5 speed, 3.07 hp30 & chrysler8.25 (29 spline), crank windows.
    New clutch 10k ago, new muffler & tailpipe, new cooling system.
    98 wrangler build
  23. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    09-10-2012 10:15 AM #1423
    Got another one.
    Not keeping it.
    Selling? parting? modifying?
    I'd love to get my hands on that 3.07 hp30 I can't find one in the local pull a parts, don't really feel like buying one just to regear it. I think I found a few 3.73 and 3.55s, maybe a 4.10 locally. If any are what you'd want let me know I can bring one to WV with me and then meet with you to swap.. dead serious
  24. Member
    May 27th, 2008
    Malvern, PA
    5.7L WK2 | 2.5L TJ
    09-10-2012 11:34 AM #1424
    Quote Originally Posted by chris@revotechnik View Post
    Selling.
    Sent ya a PM about the axle.
    98 wrangler build
  25. Member
    May 7th, 2000
    San Francisco, CA
    1983 Jeep CJ-8 Scrambler
    09-11-2012 09:12 PM #1425
    I recently drove my '83 Scrambler from Denver to San Francisco via Moab and Tahoe. It was like riding a horse for four days.
  26. Member
    Jun 2nd, 2008
    Cabbagetown, ATL
    2000 Civic, 1986 Thunderbird TC
    09-16-2012 07:22 PM #1426
    Picked her up Friday morning, 2.5l, 5sp - rebuilt the transfer case, rebuilt the top end of the engine and she runs like a champ. $1500 came with hard top and bikini tops. I'm going to pull the interior and rhinoline the interior next weekend.
    Its great I havent had a Jeep since my 77 CJ7. Big tires coming soon.
    Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
    I've got a bunch of high end vintage audio gear I'm clearing out, restored Marantz 4270 - better than new condition; Pioneer SX-5590, 8/10; Concept 16.5, 8/10 cosmetically - 10/10 function. Various high end vintage speakers: Rectilinear Research, AR, Kenwood, Infinity, McIntosh, Leslie 251. PM me for details, clearing out to finance home theater upgrade.
  27. Member scirockalot8v's Avatar
    Sep 15th, 2006
    724 to the 412
    mk4 and mk5
    10-03-2012 08:29 AM #1427
    is that Casparis or creek falls pa?
    some of my brothers. we wheel in western pa. im looking to get back into it soon.
    PM me for Custom Coilover Covers.
  28. Moderator robbyb413's Avatar
    May 12th, 2002
    10-03-2012 10:18 AM #1428
    Is it just me, or are 3/4 of the pictures in this thread showing Jeeps having a good time taken in PA? When are we having a ?id=959 trip to Centralia et. al.??
  29. Junior Member
    Mar 3rd, 2012
    Poughkeepsie NY
    10-10-2012 11:09 PM #1429
    My tj is going back on the road in the next month! I can't wait to drive in the snow, and happy I won't need to take my low tdi out.
  30. Member
    Jan 19th, 2005
    Shepherdsturd, WV
    '12 JKU / '06 FXSTDI
    10-19-2012 09:20 AM #1430
    Urban offroading
    Have a Rock Krawler 2.5" lift sitting in my basement and just ordered shocks and an exhaust spacer yesterday.
  31. Member
    Jan 19th, 2005
    Shepherdsturd, WV
    10-19-2012 09:21 AM #1431
    Quote Originally Posted by robbyb413 View Post
    There's actually wheeling to be done up there. There's really no place like Rausch Creek anywhere in MD or Eastern WV. I've heard GW national forest has trails, but I've heard they're just kind of meh.
  32. Member Hidrorayo's Avatar
    Sep 2nd, 2007
    Lakewood, CO
    2003 Silverstone Grey 1.8T GTI|1990 Tornado Red G60 Corrado |2012 3.6L M/T Jeep Wrangler Rubicon
    10-25-2012 11:48 PM #1432
    Went wheeling up in Boulder with some friends.
    Bleifrei ------------
    Unleaded ----------
    Sans Plomb -------
    SpoonfedTuning
  33. n00b
    May 24th, 2012
    http://www.sneakers-redbrick.org
    Jeep Wrangler TJ 4.0
    11-13-2012 05:46 AM #1433
    Very nice pictures.
    I''ve got a Jeep Wrangler TJ 4.0 stock and I'm amazed how good it is is off-road. Better then other stock 4x4s I've owned.
  34. Member Amsterdam087's Avatar
    Dec 31st, 2007
    Gone Fishin'
    4x4
    11-13-2012 10:55 AM #1434
    Great pics Hydro, thanks for sharing.
    I am an apex predator, and hatchery zombies are my target
    ****BPC****
  35. Junior Member
    Mar 3rd, 2012
    Poughkeepsie NY
    11-15-2012 10:23 PM #1435
    Last time out
