VWVortex.com - Complete Fuse and Relay assignments for the 2006/2007 GTI
    Results 1 to 17 of 17
    Thread: Complete Fuse and Relay assignments for the 2006/2007 GTI
    1. 10-09-2006 09:50 PM #1
      Here is the COMPLETE Fuse Box location and Fuse assignments as well as the Relay locations for the 2006/2007 GTI. I know it is a long list but it can be useful.
      Fuse Box A on front of fuse box in engine compartment next to battery (Fuse numbers read from left to right)
      1 -SA1 -Fuse 1 (on fuse panel A)150A 200A -C -Generator (GEN)(90A/120A) C -Generator (GEN)(1401A)30a
      2 -SA2 -Fuse 2 (on fuse panel A)80A -J500-Power Steering Control Module V187-Electro-mechanical Power Steering Motor 30a
      3 -SA3 -Fuse 3 (on fuse panel A)50A -J293 -Coolant Fan Control (FC)Control Module V7 -Radiator Fan V177 -Coolant Fan 2
      30a
      4 -SA4 -Fuse 4 (on fuse panel A)80A -Fuses (on fuse panel C),under instrument panel,left: SC32 -SC 37,Power Seat Adjustment Circuit Breaker 1-30A Power Seat Adjustment Circuit Breaker 2-30A
      29
      5 -SA5 -Fuse 5 (on fuse panel A)100A -J604-Auxiliary Air Heater Control Module Z35 -Auxiliary Air Heater Heating Element 30a
      6 -SA6 -Fuse 6 (on fuse panel A)80A 100A - -Fuses (on fuse panel C),under instrument panel,left: SC18 -SC20,SC22 -SC28,SC43 -SC45 Optional Equipment
      30a 30a
      7 -SA7 -Fuse 7 (on fuse panel A)50A -Fuses (on fuse panel C),under instrument panel,left: SC22 -SC27 30a
      Fuse Box B in engine compartment under fuse box cover(next to battery)
      F1 -SB1 -Fuse 1 (on fuse panel B)30A -J104 -ABS Control Module (pump)30a
      F2 -SB2 -Fuse 2 (on fuse panel B)30A -J104 -ABS Control Module (valves)30a
      F3 -SB3 -Fuse 3 (on fuse panel B)20A -J393 -Comfort System Central Control Module J217 -Front Passenger ’s Wiper Motor 30a
      F4 -SB4 -Fuse 4 (on fuse panel B)5A -J519 -Vehicle Electrical System Control Module (measuring cable)30a
      F5 -SB5 -Fuse 5 (on fuse panel B)15A -J519 -Vehicle Electrical System Control Module (horn)30a
      F6 -SB6 -Fuse 6 (on fuse panel B)15A -N276 -Fuel Pressure Regulator Valve 87a
      F7 -SB7 -Fuse 7 (on fuse panel B)15A --Not used
      F8 -SB8 -Fuse 8 (on fuse panel B)--Not used
      F9 -SB9 -Fuse 9 (on fuse panel B)10A -N249-Turbocharger Recirculating Valve (AXX,BWA,BPY) N80-Evaporative Emission (EVAP)Canister Purge Regulator Valve 1 (AXX, BWA,BPY) N75-Wastegate Bypass Regulator Valve (AXX,BWA,BPY)
      87a
      F10 -SB10 -Fuse 10 (on fuse panel B)--Not used
      F11 -SB11 -Fuse 11 (on fuse panel B)10A -Z19-Oxygen Sensor (O2S)Heater 87a
      F12 -SB12 -Fuse 12 (on fuse panel B)10A -Z29 -Oxygen Sensor (O2S)Heater 1 (behind Three Way Catalytic Converter (TWC)87a
      F13 -SB12 -Fuse 12 (on fuse panel B)15A -J743-Motronic Engine Control Module (ECM)30a
      F14 -SB14 -Fuse 14 (on fuse panel B)--Not used
      F15 -SB15 -Fuse 15 (on fuse panel B)10A -V50-Coolant Pump 30a
      F16 -SB16 -Fuse 16 (on fuse panel B)5A -J104 -Steering Column Control Module 30a
      F17 -SB17 -Fuse 17 (on fuse panel B)5A -J285-Instrument Cluster Control Module 30a
      F18 -SB18 -Fuse 18 (on fuse panel B)30A -R12 -Amplifier 30a
      F19 -SB19 -Fuse 19 (on fuse panel B)15A -R-Radio 30a
      F20 -SB20 -Fuse 20 (on fuse panel B)5A --Telephone J503 -Radio/Navigation Display Control Module 30a
      F21 -SB21 -Fuse 21 (on fuse panel B)--Not used 30a
      F22 -SB22 -Fuse 22 (on fuse panel B)--Not used 30a
      F23 -SB23 -Fuse 23 (on fuse panel B)10A -J623-Engine Control Module (ECM)30a
      F24 -SB24 -Fuse 24 (on fuse panel B)5A -J533-Data Bus On Board Diagnostic Interface 30a
      F25 -SB25 -Fuse 25 (on fuse panel B)--Not used 30a
      F26 -SB26 -Fuse 26 (on fuse panel B)--Not used 30a
      F27 -SB27 -Fuse 27 (on fuse panel B)--Not used 87a
      F28 -SB28 -Fuse 28 (on fuse panel B)25A -J623-Engine Control Module (ECM)87a
      F29 -SB29 -Fuse 29 (on fuse panel B)5A -J235-Engine Coolant Pump Relay 87a
      F30 -SB30 -Fuse 30 (on fuse panel B)20A -J485 -Auxiliary Heater Operation Relay 29a
      F31 -SB31 -Fuse 31 (on fuse panel B)30A -V -Windshield Wiper Motor 29a
      F32 -SB32 -Fuse 32 (on fuse panel B)---Not used -
      F33 -SB33 -Fuse 33 (on fuse panel B)---Not used -
      F34 -SB34 -Fuse 34 (on fuse panel B)--Not used 29a
      F35 -SB35 -Fuse 35 (on fuse panel B)--Not used 29a
      F36 -SB36 -Fuse 36 (on fuse panel B)--Not used 29a
      F37 -SB37 -Fuse 37 (on fuse panel B)-Not used 29a
      F38 -SB38 -Fuse 38 (on fuse panel B)10A -J293 -Coolant Fan Control (FC)Control Module 87a
      F39 -SB39 -Fuse 39 (on fuse panel B)5A -F47-Brake Pedal Switch 87a
      No.Designation in Current Flow Diagram Nomina l Value Function/Component Terminal
      F40 -SB40 -Fuse 40 (on fuse panel B)20A -N70 -Ignition Coil 1 with Power Output Stage N127 -Ignition Coil 2 with Power Output Stage N291 -Ignition Coil 3 with Power Output Stage N292 -Ignition Coil 4 with Power Output Stage
      87a
      F41 -SB41 -Fuse 41 (on fuse panel B)---Not used 87a
      F42 -SB42 -Fuse 42 (on fuse panel B)5A -J757 -Engine Component Power Supply Relay 87a
      F43 -SB43 -Fuse 43 (on fuse panel B)30A -N70 -Ignition Coil 1 with Power Output Stage N127 -Ignition Coil 2 with Power Output Stage N291 -Ignition Coil 3 with Power Output Stage N292 -Ignition Coil 4 with Power Output Stage N323 -Ignition Coil 5 with Power Output Stage N324 -Ignition Coil 6 with Power Output Stage
      87a
      F44 -SB44 -Fuse 44 (on fuse panel B)---Not used -
      F45 -SB45 -Fuse 45 (on fuse panel B)---Not used -
      F46 -SB46 -Fuse 46 (on fuse panel B)---Not used -
      F47 -SB47 -Fuse 47 (on fuse panel B)40A -J519-Vehicle Electrical System Control Module 30a
      F48 -SB48 -Fuse 48 (on fuse panel B)40A -J519-Vehicle Electrical System Control Module 30a
      F49 -SB49 -Fuse 49 (on fuse panel B)--J681-Power Supply Relay 2 (terminal 15)30a
      F50 -SB50 -Fuse 50 (on fuse panel B)---Not used 30a
      F51 -SB51 -Fuse 51 (on fuse panel B)40A -J299-Secondary Air Injection (AIR)Pump Relay 29a
      F52 -SB52 -Fuse 52 (on fuse panel B)40A -J59-Load Reduction Relay 29a
      F53 -SB53 -Fuse 53 (on fuse panel B)50A --Optional Equipment 29a
      F54 -SB54 -Fuse 54 (on fuse panel B)---Not used 29a
      Fuse Box C Located left side of dash
      1 -SC1 -Fuse 1 (on fuse panel C)10A -J485-Auxiliary Heater Operation Relay N79-Positive Crankcase Ventilation (PCV)Heating Element (BUB,BMJ,BWA) G70-Mass Air Flow (MAF)Sensor (AXX,BWA,BPY) J757-Engine Component Power Supply Relay T16-Data Link Connector (DLC) (T16/1)J431-Headlamp Range Control Module
      15a
      2 -SC2 -Fuse 2 (on fuse panel C)10A -J623-Engine Control Module (ECM) E1-Light Switch V49-Right Headlamp Beam Adjustment Motor V48-Left Headlamp Beam Adjustment Motor E102-Headlamp Beam Adjustment Motor J538-Fuel Pump (FP) Control Module (AXX,BWA,BPY)J492-All-Wheel Drive Control Module J345- Towing Recognition Control Module J587-Selector Lever Sensor System Control Module J533-Data Bus On Board Diagnostic Interface J285-Instrument Cluster Control Module J500-Power Steering Control Module J104-ABS/EDL Control Module E132-Anti-Slip Control Switch E256-ASR/ESP Button G100-Brake Pedal Position Sensor,(from November 2005)
      15a
      3 -SC3 -Fuse 3 (on fuse panel C)5A -J234 -Airbag Control Module 15a
      4 -SC4 -Fuse 4 (on fuse panel C)10A -G266-Oil Level Thermal Sensor M17-Backup Lamps J255-Climatronic Control Module G65-High Pressure Sensor E16-Heater/Heat Output Switch J530-Garage Door Opener Control Module N253-Battery Interrupt Igniter Y7-Automatic Day/Night Interior Mirror E422-Tire Pressure Monitoring Display Button K216-ASR/ESP Control Lamp 2 Z20-Left Washer Nozzle Heater Z21-Right Washer Nozzle Heater
      15a
      5 -SC5 - Fuse 5 (on fuse panel C) 5A -J745-Headlamp Range/Cornering Lamp Control Module,on right headlamp 15a
      6 -SC6 - Fuse 6 (on fuse panel C)5A -J745-Headlamp Range/Cornering Lamp Control Module,on left headlamp 15a
      7 -SC7 - Fuse 7 (on fuse panel C)5A --Not used 15a
      8 -SC8 - Fuse 8 (on fuse panel C)10A --Not used 15a
      9 -SC9 - Fuse 9 (on fuse panel C) ---Not used 15a
      10 -SC10 - Fuse 10 (on fuse panel C)---Not used 15a
      11 -SC11 - Fuse 11 (on fuse panel C)---Not used 15a
      12 -SC12 - Fuse 12 (on fuse panel C)10A -J386-Driver ’s Door Control Module (window regulator) J387-Front Passenger ’s Door Control Module (window regulator)30a
      13 -SC13 - Fuse 13 (on fuse panel C)10A -T16-Data Link Connector (T16/16) E1-Light Switch G397-Rain/Light Recognition Sensor G197-Compass
      30a
      14 -SC12 -Fuse 12 (on fuse panel)10A -F -Brake Light Switch J217-Transmission Control Module (TCM) J587-Selector Lever Sensor System Control Module R149-Auxiliary Engine Coolant Heating RF Receiver E16 -Heater/Heat Output Switch J301-A/C Control Module J255-Climatronic Control Module J446-Parking Aid Control Module J104-ABS/EDL Control Module
      30a
      15 -SC15 -Fuse 15 (on fuse panel)7.5A -J519-Vehicle Electrical System Control Module (interior illumination)30a
      16 -SC16 -Fuse 16 (on fuse panel)---Not used 30a
      17 -SC17 -Fuse 17 (on fuse panel)5A -G273-Interior Monitoring Sensor G384-Vehicle Inclination Sensor H12-Alarm Horn
      30a
      18 -SC18 -Fuse 18 (on fuse panel)5A --Not used 30a
      19 -SC19 -Fuse 19 (on fuse panel)5A -J754-Crash Data Recorder 30a
      20 -SC20 -Fuse 20 (on fuse panel)5A --Not used 30a
      21 -SC21 -Fuse 21 (on fuse panel)---Not used 30a
      22 -SC22 -Fuse 22 (on fuse panel)40A -V2 -Fresh Air Blower (Climatronic)30a
      22 -SC22 -Fuse 22 (on fuse panel)40A -V2 -Fresh Air Blower (Climatronic),rear battery 29a
      23 -SC23 -Fuse 23 (on fuse panel)30A -J386-Driver ’s Door Control Module (window regulator) J387-Front Passenger ’s Door Control Module (window regulator)30
      24 -SC22 -Fuse 22 (on fuse panel)25A -J388-Left Rear Door Control Module (Central Locking) J389-Right Rear Door Control Module (Central Locking) J393-Comfort System Central Control Module
      30a
      25 -SC25 -Fuse 25 (on fuse panel)25A -Z1 -Heated Rear Window J301-A/C Control Module (only with additional water heater) E16-Heater/Heat Output Switch (only with additional water heater) N24-Fresh Air Blower Series Resistor (only with additional water heater)
      30a
      26 -SC26 -Fuse 26 (on fuse panel)30A -J388-Left Rear Door Control Module (window regulator) J389-Right Rear Door Control Module (window regulator)30a
      27 -SC27 -Fuse 27 (on fuse panel)15A -J538-Fuel Pump (FP)Control Module G6-Transfer Fuel Pump (FP)30a
      28 -SC28 -Fuse 28 (on fuse panel)25A -Special Purpose Vehicle Socket (Not for USA/Canada)30a
      29 -SC29 -Fuse 29 (on fuse panel)10A --Not used 15a
      30 -SC30 -Fuse 30 (on fuse panel)20A -J217 -Transmission Control Module (TCM) J743-Direct Shift Gearbox (DSG)Mechatronic Terminal 15a
      31 -SC31 -Fuse 31 (on fuse panel)20A -V192 -Brake System Vacuum Pump 15a
      32 -SC32 -Fuse 32 (on fuse panel)30A -U13 -Converter with Socket,12V,230V-110V 29a
      33 -SC33 -Fuse 33 (on fuse panel)25A -J245-Power Sunroof Control Module 29a
      34 -SC34 -Fuse 34 (on fuse panel)15A -V125-Driver's Seat Lumbar Support Curvature Adjustment Motor V126-Front Passenger ’s Seat Lumbar Support Curvature Adjustment Motor V129-Driver's Seat Lumbar Support Height Adjustment Motor V130-Front passenger Seat Lumbar Support Height Adjustment Motor
      29a
      35 -SC35 -Fuse 35 (on fuse panel)--Not used 29a
      36 -SC36 -Fuse 36 (on fuse panel)20A -V11 -Headlamp Washer Pump J39 -Headlamp Washer Relay 29a
      37 -SC37 -Fuse 37 (on fuse panel)30A -J131 -Driver's Heated Seat Control Module J132-Front Passenger ’s Heated Seat Control Module 29a
      38 -SC38 -Fuse 38 (on fuse panel)20A -J388-Left Rear Door Control Module (Central Locking System),with J641-Alarm Horn Relay,rear battery J389-Right Rear Door Control Module (Central Locking System),with J641-Alarm Horn Relay,rear battery
      30a
      39 -SC39 -Fuse 39 (on fuse panel)---Not used 30a
      40 -SC40-Fuse 40 (on fuse panel)401A -E16-Heater/Heat Output Switch (fresh air bower) J301-A/C Control Module (fresh air blower)75a
      41 -SC41 -Fuse 41 (on fuse panel)20A -V12-Rear Window Wiper Motor J729-Dual Washer Pump Relay 1 J730-Dual Washer Pump Relay 2
      75a
      42 -SC42 -Fuse 42 (on fuse panel)20A -U1-Cigarette Lighter U9-Rear Cigarette Lighter U5-12 V Socket (criminal investigation)(Not USA/Canada)
      75a
      43 -SC43 -Fuse 43 (on fuse panel)15A -J345-Towing Recognition Control Module 30a
      44 -SC44 -Fuse 44 (on fuse panel)20A -J345-Towing Recognition Control Module (not for rear battery)30a
      45 -SC45 -Fuse 45 (on fuse panel)15A -J345-Towing Recognition Control Module 30a
      46 -SC46 -Fuse 46 (on fuse panel)---Not used -
      47 -SC47 -Fuse 47 (on fuse panel)---Not used -
      48 -SC48 -Fuse 48 (on fuse panel)10A --Mag-Lite and portable two-way radio charging station 75a
      49 -SC49 -Fuse 49 (on fuse panel)---Not used -
      Relay arrangements and circuit breakers on relay panel below instrument panel, left (the relays have numbers embossed on the top of the relays)
      1 -J13 (53)-Fresh Air Blower Relay -(only auxiliary heater)
      2 -Not used
      3 -Not used
      4 -J39 (53)-Headlamp Washer Relay
      5 -J17 (449)-Fuel Pump (FP)Relay
      5 -J485 (449)-Auxiliary Heater Operation Relay
      A -Power Seat Adjustment Circuit Breaker 1-30A (from May 2004)
      B -Power Seat Adjustment Circuit Breaker 1-30A (Through April 2004)
      .J17 and J458 are minirelays located on a relay connector panel
      Relay arrangements on relay panel at Vehicle Electrical System Control Module, under instrument panel, left
      B1 -Not used
      B2 -J99 -Heated Outside Mirror Relay (449)
      B3 -Not used
      B4 -J689 Power Supply Relay 2 (terminal 50)(449)
      B5 -J9 -Rear Window Defogger Relay (53)
      B6 -J413 -Horn Relay (449)
      B7 -J729 -Dual Washer Pump Relay 1 (404)
      B8 -J730a -Dual Washer Pump Relay 2 (404)
      B9 -J59 -Load Reduction Relay (460)
      Relay arrangements on E-box High, in engine compartment, left
      A1 -J317 -Power Supply Relay (terminal 30a)(100)
      A2 -J235-Engine Coolant Pump Relay (100)
      A3 -Not used
      A4 -J757 -Engine Component Power Supply Relay (167)
    2. Member Sincity's Avatar
      May 16th, 2005
      '07 GTI APR Stg II RIP. '09 C63 AMG Kleemann Stg II. Trade '08 RDX for MKVII R or GTI.
      10-09-2006 09:58 PM #2
      Awesome! Thanks....
    3. Member TO_Turbo's Avatar
      May 1st, 2002
      Toronto ON
      10-09-2006 10:05 PM #3
      That's great, thanks. I had a list like this for my MK IV and was looking for one for the MK V. The list in the Owner's Manual is nowhere near complete enough.
      Rob
    4. 11-28-2006 10:51 AM #4
      Awesome, thanks!
      My 2006 GTI has an interesting "quirk" though - SC49 (fuse panel C, fuse 49) is used!
      For some reason, the switched 12v wire for the headlight switch was run to fuse 49. The frustrating thing is no one put a fuse in that position during assembly so my headlight switch wasn't illuminating the green foglight indicator when I turned the foglights on. After much searching with a multimeter, I discovered there were wires run to that SC49 fuse position. I put a 5amp fuse in and presto - working foglight indicator, etc. on the switch. Anyone else come across this??
      It was definitely done at the factory and not some dealer hack job...
    5. Member PBN's Avatar
      Aug 2nd, 2006
      Winston Failem
      Jazz Blue 20AE
      11-28-2006 10:59 AM #5
      STICKY THIS [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 11-28-2006 12:30 PM #6
      did you get it from the same chart that's in my sig?
    7. 11-28-2006 01:14 PM #7
      i got it from my VESIS repair manual.
    8. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      11-28-2006 04:29 PM #8
      Quote, originally posted by 4string »
      Would you happen to be able to suggest to me a good location for a fuse tap for hardwiring a Garmin GPS? The specific fuse tap is good for a 10A or less accessory and is to be used with no more than a 10A fuse for the actual tap itself (ie. there are two fuses, both 10A or less).
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    9. 11-29-2006 08:36 AM #9
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] thanks
    10. 12-01-2006 01:42 PM #10
      i don't know how accurate this is
      on my fuse box in the dash on the left side
      it has
      #27=15A
      #28=20A
      #29=10A
      #30=empty
      #31=empty
      according to your chart, and a pdf file i have it should read
      #27=15A
      #28=25A ( not used in USA)
      #29=10A ( not used)
      #30=20A (TCM)
      #31=20A (Brake System Vacuum Pump)
    11. 12-01-2006 10:36 PM #11
      Quote, originally posted by BRM10984 »
      34 - SC34 - Fuse 34 (on fuse panel) 15A - E177 - Front Passenger‘s Seat Lumbar Support Adjustment
      Switch 30( not switched power-has 12volts all the time
      1 - SC1 - Fuse 1 (on fuse panel) 10A -
      T16 - Data Link Connector (DLC) (T16/1)
      J220 - Motronic Engine Control Module 1)
      J248 - Diesel Direct Fuel Injection Engine Control Module 2)
      J643 - Fuel Primer Relay 1) 15 power (only has power with the key on)
    12. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      12-01-2006 10:39 PM #12
      I suppose I'll go with fuse one since I'm looking for switched power. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      12-07-2006 05:59 AM #13
      Quote, originally posted by Dan GSR »
      it has
      #27=15A
      #28=20A
      #29=10A
      #30=empty
      #31=empty
      #27=15A
      #29=10A ( not used)
      #30=20A (TCM)
      Neither the chart posted or the one in D.Passat00s sig are completely correct.
    14. 12-07-2006 10:40 AM #14
      unfortunately, that's VWOA for ya.
    15. 12-07-2006 10:42 AM #15
      Sweet, thx [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. Member blackvento36's Avatar
      Mar 17th, 2003
      Easton, PA
      12-07-2006 04:55 PM #16
      Quote, originally posted by D.Passat00 »
      You don't have to tell me, you should see the fuse layouts in the Bentley manual
    17. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      01-02-2007 06:01 PM #17
      You just saved my day with this info. Many thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
