what are you using for a drivetrain? (rear diff, shaft, trans?)
#1
This is the progress so far,[IMG][/IMG] http://i93.photobucket.com/alb...4.jpg
[IMG][/IMG] http://i93.photobucket.com/alb...3.jpg [IMG][/IMG] http://i93.photobucket.com/alb...5.jpg [IMG][/IMG] http://i93.photobucket.com/alb...1.jpg [IMG][/IMG] http://i93.photobucket.com/alb...6.jpg
#2
#3
This should be a cool thread to watch. Lots of engineering challenges with this idea.
#4
for now it's just a 2l 16v with a locking diff
#5
sorry , verbal diarrhea (mistake)
for now it's just a 2l 16v tranny with a locking diff
#6
Hope you fully complete this project.
#7
Quote, originally posted by 8V Fury » Hope you fully complete this project. Sadly, I don't see it happening.
#8
You put the links BETWEEN the [IMG] tags. But cool project. Good luck
#9
Modified by Speed Racer. at 11:27 PM 10-9-2006
#11
lmao.. this aught to be friggen insane.. tell me its gonna be a VR?
#12
Quote, originally posted by IDrankBeer » Sadly, I don't see it happening.
a la Golf Quattro project? Lets just home he can pull this off. I'd love to see it happen!
#13
Why is there a steering rack in the back?
#14
I'm guessing that he has to modify the front end stuff to work in the back with the trans, but I dunno much![]()
#15
Quote, originally posted by IDrinkMaltLiquor » I'm guessing that he has to modify the front end stuff to work in the back with the trans, but I dunno much Im confused. Is he putting hte motor in the back or just making the car RWD? If the motor was goin back there he has to have something there to adjust toe settings, but why the entire rack. you can gte replacements that work and you dont need that huge nasty looking rack.
If he is just going RWD. why put that factrory subframe back there in the first place? I dont get it?
What is goin on here
#16
thats pretty much exactly how my Mid engine RWD was built!Nice use of the cage for reinforcement!
#17
He probably put the rack back there because it was easy. I'ts probably just welded straight.
#18
so your putting an original vw drivetrain into the rear?
#19
Quote, originally posted by The_Hamster » so your putting an original vw drivetrain into the rear?
i would say so
Quote, originally posted by Jetta RWD » sorry , verbal diarrhea (mistake)
#21
the rack is only there for temporary mock up, no it's not going to be a another VR setup , VW are the original 8V, the engine is not amazing but it's true to VW roots.the engine is a
1.8L PG block with flat high compression pistons 13:1 ratio
Shot peened connecting rods and a balanced knife edged crank
aluminium pulleys,
ABA head with 268-272 cam with dual springs and maybe stainless valves
custom made 4-2-1 header with 3" exit
the hardest part so far was the tubular frame design, the rest is going nicely, I've been only working on it, on weekends since the end of july and it's starting to get cold here in the north of quebec.
Modified by Jetta RWD at 1:21 PM 10-10-2006
Modified by Jetta RWD at 1:25 PM 10-10-2006
#22
I put alot of thought into the drivetrain, all my rally buddies are runny audi quattro's , the quattro systeme would of being a nice setup, but parts are rare here in canada and i'm in school (low budget)
The car had originally a full roll cage and a very modified 2L 16V on weber carbs but failed to find relyability, i've also had a G60 and a VR in this car. For the last 6 months i've been running a 2L 8V ABA with headers, cams, pulleys and a giac chip.I also have anothere project underways, witch is a tubular frame MKII jetta with a GM350 small block and a audi locking diff, the engine shoud output around 550-600 FP of torque. But due to low budget I had to put it on hold for now. I'd like to be the first VW to compete in the canadian drift series
I might put another engine in the front and make a it a Suzuki Cultus pikes peak genre, but without the large wings and aprox 900BHP
Modified by Jetta RWD at 1:29 PM 10-10-2006
#23
that looks prettty friggin sick. nice work so far!
PRE 93. | Inland Euros | Support Your Local Euro Shop.
FS: 14" Riken Turbos. Cheap! Buy them!
I drive oldschool by choice, not circumstance.
#24
Quote, originally posted by Jetta RWD » The car had originally a full roll cage and a very modified 2L 16V on weber carbs but failed to find relyability, it was the carbinators, guranteed!
I might put another engine in the front and make a it a Suzuki Cultus pikes peak genre, but without the large wings and aprox 900BHPyou should, just so i can convince my friend someone has already done a v8 in a dub, so its not origional any more...
#25
I still dont see whats goin on. Mid motor or front motor RWD?
#26
appears to be sorta a rear transverse. normal front engine setup transfered to the rear.
#27
Here's a better view from the inside, the car is jacked up and the suspension is at it's highest.
#28
you're going to have RW steering??![]()
#29
Quote, originally posted by Mk2-SAiNT 2.0 » you're going to have RW steering?? ![]()
read fool
he said its just for mockuplooking good so far.. do you have a tubing bender?
#30
noted.thanks for such a civilized response.
#31
Quote, originally posted by Mk2-SAiNT 2.0 » noted. thanks for such a civilized response.
#33
i hate people that dont know what they are talking about. Hey keep u the good work would love to see more pics of her sweet fab skills.![]()
#35
the O neil ford SUV 01, what is that ? explorer ? i love the skid plateyes I have a tube bender, it's not the most high tech, but it does the job
Modified by Jetta RWD at 8:44 PM 10-10-2006
