Dave is she alive?
I bought my b3 passat wagon back. It tossed a timing belt so got the head at G&S machine to check it out.
Now, I got to change the paint on the rims. Splatter paint is not my style.
#47672
Dave is she alive?
#47673
ill have it done before year 2020or sell it by 2012
chassy specs:
91 alpine white coupe shell wolfsburg edt. sunroof, very straight body
single round, grille spoiler, 16v lip, g60 front wide flares,smoked headlights
new big bumpers, recaros, corrado slc subframe/crossmember
new:
bfi stage 1 motormounts
ball joints
slc control arms
sway bar mounts/end links
inner and outer tie rods, boots, rack bushings bearings
11 in rotors,pads rebuild kit for calipers,ss lines, rear disc
hd strut mounts
raceland coilovers
5x100 rx2s from wolfsburg mk4 with 205 40 16 powdercoated centers stripped and polished lips
passat pedal cluster fro hydro clutch
non abs booster bracket that mounts slave cyl
engine trans:
2001 vr 12v, o2j, spec stage 3 clutch light flywheel,kenetics stage 2 kit (no injectors and chip),short runner 034efi fuel rail, light pullies, awic ect
faces after pcoat..
need: engine harness,c2 fuel kit to get this running
#47675
Awesome.... I love rx2's.... Very very cool
volkswagens,metal,pbr and the mighty glasgow celtic
#47677
Yay, another TDI.
skb, do you have access to, or can recommend local for B100? PM if need be, kthnx.
MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
#47678
#47679
#47680
Its my old gli... The kid that owns it now is in the air force his name is andrew.
#47682
#47685
#47686
#47688
#47689
The headliner trim round the sunroof i couldnt ever find it... But i think andrew has something up there now i dont think its torn.. The wheels are killin the car for sure it looked so good on the a's
#47690
Yea it looked good on the a's but it was rubbin really bad and I wanted to go lower. I put that 8v lip on it and fixed the ac control, I still have the 16v lip. Let me know man we can work something out.
#47691
#47692
Boo! Leaking brake proportioning valve:
Temporary fix - blocked one of the rear lines at the MC (capped it with a brake bleeder) - use the remaining line to the rears, ran it through a Wilwood adjustable valve and then through a Tee fitting to the rears. I'm a bit concerned about getting enough pressure from one rear line to work both rear brakes.
If it works out, I'll ditch the sketchy spaghetti system of hard lines and get one of the Tilton units and install it next to the shifter: http://photos.motoiq.com/MotoIQ/Proj...45_XZNH8-L.jpg
Bleeding this MFer is making me crazy - I used a 1/2 gallon of cheap fluid to get the air bubbles out and I still have a super-soft pedal. Any tips, or should I just keep at it? I'm using a vacuum bleeder (like this: http://www.amazon.com/dp/B000JFN9WC/...SIN=B000JFN9WC )
#47693
The brakes are the only thing that kept me from auto-crossing today BTW
Tiny oil leak at the turbo, need a steel adaptor fitting here - I think I've stripped the aluminum -3AN fitting I have right now (another MFer!). Need to loom the wiring and stuff it away. Need to weld up a mount for the passenger seat (Cobra Monaco racing bucket) and get the front seatbelt latches bolted to the car.
Megasquirt is up and running.
VR crank sensor / using the ABA distributor for cam position. Have LS2 truck COP ignition coils (hottest coils in the universe!) ready to go in, have the board for sequential injection ready to go.
Starts on second crank when cold, first crank when warm - should get better with a few more keystrokes. Idle is hunting a little - need to richen the mixture and mess with idle timing a little.
Need brakes so i can road tune it![]()
#47694
Gravity bleed em for about 10 or 15 mins all four corners then try and bleed em again...
#47695
#47696
Gotta love old dubs!!!!
#47697
2006 Jetta 2.0 T DSG
Inside every older person is a younger person wondering, "What the heck happened?"..
#47698
Took the 930 out for a cruise today. Needs some suspension pieces me thinks.
#47700
It's my Ota's. 1984 930 Turbo. Yeah the turbo lag is terrible, it'll still burn through the p zeros. If it were me I'd have some wider rubber in the rear, he's still rocking 225's.
There is considerable spool up time.
#47701
#47702
#47703
#47704
Checked on the respray progress
And got my wife a new car from Paul.........Thanks buddy!
Just like that!
#47705
No worries mate.... Im glad she likes it, i just barely drove it and it needed someone that would drive it!!!!!!! I got to many cars lol.... Got rid of one mk5 and then bought another one hahahahaha filthy habit
