VWVortex.com - Problems with GLI exhaust manifold bolts?
    Results 1 to 16 of 16
    Thread: Problems with GLI exhaust manifold bolts?
    1. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-25-2006 05:19 PM #1
      Has anyone else had problems with your exhaust manifold bolts coming loose? Mine is a 2005 PG GLI 1.8T and this has been the only problem its ever had. I first start to notice it when exhaust starts to sputter out very quietly, but after driving it for a few days, its starts to get really loud (not a good loud.....more like a "hey, ********, go get your car fixed because no one likes you" loud). This is the THIRD time I've taken it in. The first time they just tightened them. The second time they replaced every bolt on the manifold. This time....we'll see what they say. Its not like this is a major problem, but it is irritating having to schedule appointments and make arrangements to be carted around (preferrably in a chariot) while waiting for my car. Give me some feedback on this because this is bothering me.
      2013 Audi A4 2.0T Monsoon Gray (20x9 Hartmann HRS6 matte anthracite, B&O w/ accubass line level and 12" JL sub, 15MM H&R spacers (rear), 2010 CC Sport 6MT DBP, 2007 Fahrenheit GLI 6MT, 2005 PG GLI 6MT, 2001 Wolfsburg 5MT, 2001 Jetta 2.slow 5MT, 1997 Golf 5MT, 1995 Jetta Celebration Edition 5MT, 1986 Golf 1.6L 5MT
    2. Member BUCKHUSKY's Avatar
      Apr 7th, 2004
      Shelton, CT
      2004.5 PG GLI
      10-25-2006 05:32 PM #2
      Is it your downpipe connection or the exhaust manifold to head connection?
    3. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-25-2006 05:39 PM #3
      The exhaust manifold to head connection...sorry
    4. Member groverone's Avatar
      Feb 27th, 2002
      Sugar Hood
      08 Touareg VR6
      10-25-2006 06:44 PM #4
      love and info bump! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I like people, just ask my cats!
    5. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-25-2006 07:35 PM #5
      Werd brotha. I'm starting to think that I'm the only one that has had this problem I just can't figure out why those bolts would continually loosen. Let's go have beers this week Nate
    6. Member VDub GLI04's Avatar
      Jan 7th, 2005
      Savannah, Ga
      2006 GTI, 2005 Jetta 2.5S
      10-25-2006 08:34 PM #6
      yes i had this problem for a while and unfortunately for me they wouldnt fix it under warranty b/c i have an aftermarket exhaust, so i took the liberty to fix it myself.
      first i tried tightening the bolts and the sound quieted down a little but just got louder, after about 100 miles one of the three just backed out again.
      so then i just went bought new bolts along with a NEW GASKET and replaced it all. cured the problem and hasnt been a problem since. when i took the old bolts out there was absolutely no gasket there so i was glad that i went ahead and bought one.
      here's a couple pics of the front one that kept backing out since you cant just look back there to see it...
      sorry about the resolution
    7. Member VDub GLI04's Avatar
      Jan 7th, 2005
      Savannah, Ga
      10-25-2006 08:35 PM #7
      also ive seen this happen to like 5 other GLI's
    8. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-26-2006 10:33 AM #8
      Thank you for the input! I really appreciate it! I'm going to let the service guys down at the dealership know they need to replace the gasket along with all the bolts again. I'm just tired of this happening. Thanks again for the info!
    9. 10-26-2006 12:51 PM #9
      yessss i thought i was the only one. I have a gil also and it has happened to me twice now first at 25,000 mi and again at 49,000 i dont know why it happens but i tighten them up and thats that,I figure ill just let it go im going to upgrade my turbo soon.
    10. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-26-2006 12:56 PM #10
      Mine first happened at 13,000 miles, then at 17,000 miles, and now its happening again at 20,400 miles. These intervals are too close to each other to ignore so I'm going to see if having the gasket and all the bolts replaced will take care of the problem for good. If not, I'm not sure what I'm going to do Good call on the upgraded turbo though. Maybe that's what I'll do if it this fix doesn't work.
      Modified by XCrushUrSkullX at 9:57 AM 10-26-2006
    11. 10-26-2006 01:35 PM #11
      happened 2 me 2... the sound i heard sounded like almost a whistling...prolly form the air rushing past the gasket... if tightened it 4 times now in the past 6 months
    12. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-26-2006 05:37 PM #12
      I feel you red face
    13. Member IFIWASINMYVW's Avatar
      Mar 20th, 2006
      '11 F25 X3 GONE: '05 BMP GLI '82 Quantum, '96 Trek, '04 A4Q, '84 Rabbit
      10-26-2006 06:14 PM #13
      I ended up buying a stack of gaskets from VW... I have one left... ... It's from the motor mounts wearing out and causing the mani to tourqe against the turbo/exhaust during shifts. Now I've got another noise similar but somewhere else. the last time I changed my gasket that did'nt fix it and I stripped the turbo housing, so the next time I'd better install a new turbo.
    14. Member
      Feb 6th, 2006
      New Rochelle
      04 R32 BMP (current) 2011 WRX (RIP) 2004.5 Gli (RIP)
      10-26-2006 09:25 PM #14
      yea i had that problem for a while and it got worse when i put on a full 3 inch. try putting in an upgrades dogbone that solved the problem for me.
    15. Member VDub GLI04's Avatar
      Jan 7th, 2005
      Savannah, Ga
      10-26-2006 10:48 PM #15
      Quote, originally posted by bikerdudej »
      i had a dog bone and it still happened to me the first time.. but once i changed everything.. i havent had the problem since
    16. Member XCrushUrSkullX's Avatar
      May 1st, 2006
      SL,UT
      2010 CC Sport
      10-27-2006 11:40 AM #16
      Awesome. I'm loving the feedback I'm getting in this forum. Its going in on Monday to replace the gasket and all the manifold bolts. It might fix it, it might not. We'll just have to see what happens. Why is it only on the GLI's that we're seeing this problem? Are they set up any differently than the regular 1.8t's? The 20th ann's and 337's are so similar that I would imagine they would have the same problem, but I'm not hearing any complaints from them. Time to get an IY 20th I guess
    « Back
