VWVortex.com - Malfunction code: PO243- Turbo/Sup Wastegate solenoid A malfunction
    Results 1 to 3 of 3
    Thread: Malfunction code: PO243- Turbo/Sup Wastegate solenoid A malfunction
    1. Junior Member vw117's Avatar
      Aug 4th, 2002
      New York
      2007 VW Touareg V10 TDI
      10-31-2006 11:19 PM #1
      Hey Guys,
      I have a 2003 B5.5 Passat and the Malfunction Indicator Light went off. I went to Autozone for a diagnostic and received the error code:
      I did a search but was unable to find out what this is. Any ideas?
      Thanks in Advance.
    2. 11-02-2006 12:05 AM #2
      it means you have a boost problem. could be too much or not enough. bad vacuum line, bad solinoid. i would check your vac lines first
    3. Junior Member vw117's Avatar
      Aug 4th, 2002
      New York
      11-02-2006 07:35 PM #3
      Ok Thanks. The light went away for now (I just tightened the gas cap to make sure this was not the issue). I may bring it in for a checkup.
      Thanks Again
