VWVortex.com - DIY: Diverter Valve Replacement 1.8T
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 91
    Thread: DIY: Diverter Valve Replacement 1.8T
    1. 11-02-2006 03:04 AM #1
      Please contact me if you have pictures for this or complete it and take pictures on the way. I will add them to this post. 03_uni-b
      I take no responsibility of any damage done to your vehicle. Use these instructions at your own risk. You know your capabilities.
      That being said, lets get started...
      Most of what is shown here is applicable to all 1.8T engines.
      For this DIY, I am replacing the stock diverter valve with the VW.OEM TT Bypass Valve (part # 06A.145.710.N), and two medium size hose clamps, and one small hose clamp
      Tools required:
      1. A medium size flat-blade screw driver
      2. Needle nose pliers, tin snips, or a dremel with a cutting disc to cut the one-time only clamps
      3. Some motor oil or vegetable oil
      Step 1 - Remove engine cover
      Step 2 - Locate the stock diverter valve
      Step 3 - Remove the hoses from the stock diverter valve. To do this, you will need to cut off the one-time use only clamps. You may use needle nose pliers, or you can break the "loop" part of the clamp with strong tin snips or use a dremel with a cutting disc. Warning: If you choose to use a dremel, it will cut through the clamp like butter, be careful and keep your hand steady so that you do not accidentally cut into the hose.
      Step 4 - After cutting off the one time use hose clamps, remove the hose from the top nipple. Then remove the hose from the bottom nipple. After that remove the hose from the side nipple. The Side nipple may be a little bit difficult to slide out but give it a strong tug. DO NOT DROP ANYTHING INTO THESE OPEN HOSES. After removing your stock valve, put the hose clamps on the bottom and side hoses. (In the picture I have the small hose clamp also on the top hose. Do not do this because you will be risking dropping the small hose clamp into the open hose on the bottom)
      Step 5 - Put some vegetable or motor oil on the bottom and side nipple of the new diverter valve that you are installing. This will help it slide into the hoses. In the picture the stock diverter valve is on the right and the new diverter valve is on left.
      Step 6 - Install the new diverter valve. Put the small hose clamp on the upper hose and put it on the top nipple. Tighten all hose clamps
      Step 7 - Put your engine cover back on and you are done [IMG]http://**********************/smile/emthup.gif[/IMG]
      Modified by rockon217 at 12:29 AM 11-2-2006
      Modified by rockon217 at 10:20 AM 11-2-2006
    2. 11-02-2006 03:06 AM #2
      wish i had a 1.8t so i could do this...otherwise u get 2 [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 11-02-2006 03:11 AM #3
    4. 11-02-2006 03:25 AM #4
      the only mod i can get drunk to [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. 11-02-2006 03:28 AM #5
      Quote, originally posted by rockon217 »
    6. 11-02-2006 03:49 AM #6
      Quote, originally posted by jakanapapa »
      hey man, a lot of people don't know how to do this. and a lot of people on the tex here ask about DV's and how to swap them. I thought I would help a lot of people out by doing a DIY write up since there isn't one for DV's in the DIY thread.
    7. 11-02-2006 09:19 AM #7
      ttt
    8. 11-02-2006 01:10 PM #8
      bump
    9. 11-02-2006 01:14 PM #9
      I like the vegetable oil idea lol. Nice write up. Someone sticky this bad boy
    10. Geriatric Member Bora_Azul's Avatar
      Dec 8th, 2002
      Hartford, CT / Porto de Mos, Portugal
      01 Sand pail, shovel not included
      11-02-2006 01:14 PM #10
      i guess this is true..there are a lot of "non-car" folk that try and do things they prob shouldn't and this i guess could help..
      PM a mod and ask them to add this tothe DIY/FAQ in my sig if its not there already , don't keep bumping it...it gets annoying
    11. 11-02-2006 01:15 PM #11
      will do
    12. Member core5's Avatar
      Apr 28th, 2006
      Norcross, GA
      2013 Passat 3.6 SE
      11-02-2006 01:28 PM #12
      It might be worth mentioning that with larger DV's, you may need to get a splicing barb and attach the vacuum hose that goes on top to an additional segment of hose. That way, you won't put a kink in it.
      Ross-Tech HEX-USB+CAN Interface user. PM if you want help locally (NE Atlanta area).
      Legendary
      "You really think someone would do that - just go on the internet and tell lies?"
    13. Member TranAndy's Avatar
      Feb 19th, 2005
      Orange County, CA!
      mk1, mk4, b6 avant
      11-02-2006 01:59 PM #13
      WOW finaly someone wrote a DIY on a DV....?
      Also Known As: MalakaiTran
      MK1
      MK4
      B6 Avant
    14. 11-02-2006 02:03 PM #14
      next:
      Do it yourself: changing your lightbulbs.
      Clean your engine! lol
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    15. 11-02-2006 02:23 PM #15
      You guys shouldn't hate so much, it's annoying...
      I don't know much about cars, but I would like to learn. Unlike many of you, I didn't have a father that was into automotive repair or even a shop class at my high school (the program was shut down). So basically, all I have to go off of is the occasional manual and the internet because I don't know too many mechanics that will teach people for free.
      Props for your writeup. Good pics, good advice.
    16. 11-16-2006 02:05 AM #16
      On my 2005 GTI there is already a screw clamp on the bottom hose but the other 2, like yours, are one-time-use clamps. Also, on my car the top clamp is a 3/4" clamp and the side (and i assume bottom b/c urs look the same size) is 1.25" clamp.
      maybe u can add this to the diy so that people know what to go get.
      thanks for the write-up.
    17. Banned
      May 20th, 2004
      11-16-2006 02:08 AM #17
      lolz.
      Well theres already one on how to put gas in your car so I guess this one was coming.
    18. Member foundubbedriver's Avatar
      Jan 10th, 2006
      chicagoland.
      eurotuner unicorn garbage.
      11-16-2006 02:42 AM #18
      Quote, originally posted by vengeance18t »
      lmao, wow..nice write up.. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      @cermak_j or @muffskinz_bodywerks <-- (instagram). 🐣
    19. 11-16-2006 07:48 AM #19
      Hey,nice DIY man,simple neat,effective.Much appreciated.
    20. 11-16-2006 07:57 AM #20
      Quote Originally Posted by deathtank View Post
      DeathTank out....
    21. 11-22-2006 02:25 PM #21
      does anyone know the part #/name of the hose that links the diverter valve and the intercooler? i have holes in mine..
    22. Member burtondk12's Avatar
      Mar 19th, 2006
      slc
      11-23-2006 12:32 PM #22
      you should do a diy on cleaning ur engine bay, because it is sooooooo clean
      CT / tristate suspension/ airride installs. pm me for details
    23. 11-23-2006 01:22 PM #23
      hey good write-up, i already know how to do this, but now im switching back to dv from bov, (hks) and i down know where that small hose goes back to that was attached to the hks bov. Can you tell me where it goes?
      EDIT: sorry, it goes on top of dv. my bad.
      Modified by vroom pshh at 11:12 AM 11-23-2006
    24. Member infamous20V's Avatar
      Dec 17th, 2004
      Portland, ME
      11-23-2006 01:45 PM #24
      next time you whore out your engine bay like this, clean it!!
    25. Member fastjetta4's Avatar
      Jan 27th, 2006
      Los Angeles, CA via Belle Mead, NJ
      2002.5 VW Jetta GLS 1.8T
      11-23-2006 03:32 PM #25
      nice, to the point DIY [IMG]http://*****************.com/smile/emthup.gif[/IMG]
