Page 1 of 8 1 2 3 4 5 ... LastLast
Results 1 to 35 of 266
Thread: BFI HD MK3 and Rado VR6 Motor Mounts
  1. 11-03-2006 12:55 PM #1
    We offer a complete line of performance motor mounts for all Mk3 and Corrado SLC. Our line of Full Poly mounts is unlike any other poly options available. They are machined from extruded stock, not gravity cast. This results in both a more uniform product as well as a more durable one.
    Be aware that the different motors will react differently to the stages. The ABA both weighs less and is positioned differently than the VR6. In general, the ABA will experience more vibration than the VR6 with the same mounts.
    The hardware provided is grade 10.9 which is much stronger than the stock bolts, those of which are prone to breakage due to age and especially with harder mounts.
    All mounts are available as kits or individual pieces. If ordering a single mount or piece, please specify front, rear, or upper to make sure you get the correct hardware.
    BFI Stealth Series Motor Mount Complete Kit
    These mounts are specifically engineered to fall in between new factory mounts and our popular .5 Mounts. Shore hardness is 50A - For comparison, the OEM mounts are around 40-45A in holey hardness. These are constructed from extruded stock polyurethane and are NOT made from rubber like the factory pieces.
    This will ensure an extremely long product life that will not break down like rubber, while still giving added performance with factory-like comfort preserved. Included in the complete kit is a G60 solid rubber transmission mount. Stealth Mounts are Ideal for those that want improved upgrade mounts for performance without sacrificing interior vibration levels on both VR6 and 4-cylinder models.
    Complete kit w/trans (5pcs w/hardware)
    BFI Stage .5 Polyurethane Motor Mount Complete Kit
    These are poly, 60A in shore hardness. They are softer than both our Stage I poly(85A) and Stage II Delrin mounts . These mounts are still a huge upgrade over the stock swiss-cheese rubber mounts.
    We developed these mounts for those wanting an upgrade in both performance and durability over the OEM parts, yet were still very concerned with daily comfort. For comparison, the OEM mounts are around 40-45A hardness. These mounts will provide an almost factory level of comfort in VR6 cars while offering both an increase in performance and greatly increased level of durability. Vibration is more evident in 4-cylinder models.
    Complete Kit w/trans (5pcs w/hardware)
    BFI Stage 1 Polyurethane Motor Mount Complete Kit
    These are poly, 85A in shore hardness. For comparison, the OEM mounts are around 40-45A hardness. BFI Stage 1’s are a huge upgrade over the stock swiss-cheese rubber mounts. Stage I is intended for a higher level of performance, over our Stage .5 and Stealth.
    They still offer reasonable ride quality, with some increased vibration over OEM in VR6 cars. Vibration is far more evident in 4-cylinder models.
    BFI Stage 2 Delrin Complete Motor Mount Kit
    These are Delrin, and fall in between poly and solid metal as far as stiffness goes. Delrin, like some poly versions, requires some break in time. It will take 150-250 miles for them to soften to their effective hardness. They also require some heat in them to soften up. And on colder days they may have more vibration at start up until driven on for a few miles. They are also self-lubricating so it will never squeak.
    The Stage 2 mounts are designed for pure performance, at the expense of ride comfort. They will hold the motor and transmission very securely and help get all the power to the ground. If you drag race or are after total performance, then the Stage II is for you. If you are concerned about vibration, then perhaps you may want to go with a less rigid mount from BFI.
    Please post, IM, or email us at: sales@blackforestindustries.com with any Technical Questions
  2. 11-10-2006 06:44 PM #2
    is the front and read different height on stage1 kit?
    I bought that + tranny mount and my motor sits crooked, is it ok to cut the rear one a little bit? How much should I take out?
    Thank you
  3. Member schippa2's Avatar
    Feb 9th, 2006
    Bethlehem, PA
    '96 POS, '06 Ninja 650r
    11-10-2006 08:49 PM #3
    I got the Stage 1s all around, and I like them
    It's not a huge difference because my mounts weren't bad to begin with, but it's definitely tightened up a bit, and shifting into 3rd, 4th, and 5th has actually improved noticeably which made it completely worth it for me. Clutch engagement seems more consistent somehow too.
    In case anyone wants to know about the vibrations, they really do need a few weeks to settle down, and it can be very harsh at first. After a week it's the most noticeable right off the line and around 2600 rpm for me. Engine's a little louder too. I'm already used to it.
  4. 11-10-2006 09:10 PM #4
    Will these mounts work with a MKII swapped VR?
  5. 11-11-2006 12:46 PM #5
    These are designed specifically for MKIII, Corrado VR6 applications. We have seen them used in MK2 VR6 but that would be at your discretion.
  6. 11-12-2006 12:43 AM #6
    Quote, originally posted by zander »
    they worked for me, but like i said the motor sits crooked. it seems like the rear motor mount need cutting down. I'm trying to find out how much to cut them though so i don't have to pull the motor 10 times...
    I used mk3 subframe and rad support. Another option would be to try corrado subframe, supposedly makes the rear of the motor sit lower
  7. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    11-19-2006 07:52 PM #7
    Quote, originally posted by BiSiE »
    roughly 1/4 inch makes it slightly canted still, but clears the hood nicely.
    2002 Lexus IS300 - Trac off is just Japanese for sideways on
  8. Member SpaceHamster's Avatar
    Jul 26th, 2004
    Middletown, NY
    1996 VR6 Passat, 2003 1.8T Passat
    11-20-2006 12:34 AM #8
    Just to ensure, will these fit a 1996 Vr6 Passat?
    Thinking about getting these, I have heard they work wonders.
  9. 11-20-2006 10:40 AM #9
    The mounts themselves will work, although the hardware kit is intended for MKIII, Corrado VR6 only.
  10. 11-21-2006 01:08 PM #10
    Quote, originally posted by Tire_Marx »
    is it safe to keep cutting it until the motor is leveled? any complications from this?
  11. Member mk3_vdub's Avatar
    Oct 18th, 2006
    Columbia, MD & Morgantown, WV
    03' 24v GTI VR6, 88 AEB Cabby
    11-21-2006 04:21 PM #11
    which stage would be comparable to the vf engineering mounts....(2?) i have vf front and rear and am in need of a trans mount... thinking about one of these instead of vf's....
    also...do you sell the trans mounts separately? pricing?
  12. 11-21-2006 04:49 PM #12
    The transmission mounts are all listed seperately on our website HERE
    The Stage 1 would be the most comparable.
  13. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    11-21-2006 11:59 PM #13
    no clue. i removed 1/4 inch, and then called it a day
  14. 11-22-2006 08:35 AM #14
    HI,
    I've got a 3.0 s/c Golf 3.. Its already got an uprated front mount but brand new OE rear and gearbox mount..
    I want to keep the new rear mount but want one of these gearbox mounts.. What one is recommended, I do not want excessive vibration but want it to perform better than OE?
    So how much for plug and play gearbox mount and shipping to U.K?
    Thanks
  15. 11-22-2006 10:52 AM #15
    We do not ship outside of North America unfortunately. JustMatz is about to begin distributing our products in the UK but we are still working on the details.
  16. 11-25-2006 05:28 PM #16
    Will you sell custom height mounts? I'll probably have to get custom made bolts, etc.
    A 1/2 inch more height on the motor means a 1/2 inch lower I can sit my ride
    -Kyle
  17. 11-25-2006 05:50 PM #17
    sent you an im
  18. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    11-30-2006 10:12 PM #18
    ive had the stage 2 setup for way over a year it seems. ( i truly can not remember).
    good stuff.
  19. 12-12-2006 02:38 AM #19
    Quote, originally posted by black forest ind »
    Corrado only? Not for a Golf?
  20. 12-12-2006 08:52 AM #20
    MKIII is a golf, jetta, or cabrio
  21. 12-12-2006 04:42 PM #21
    oh.. lol.. haha ok yeah i guess i didn't know that
  22. 12-27-2006 11:18 PM #22
    just to confirm, vr6 mk2 jetta, with mk3 subframe(s), all stage 1 mounts (including transmission).
    to level the motor, we had to cut 1/4 inch from the rear engine mount.
    can't comment on drivability/vibration yet - still in the shop...
  23. 12-28-2006 03:06 AM #23
    Bought complete stage 2 in january of 2006....its now december of 2006 and over 15000kms on them including track days
    NO PROBLEMS WITH MOTOR HEIGHT OR ANYTHING BREAKING
    best mod i've ever done to the car period. motor isnt crooked and the car feels rediculously solid
  24. Member 7797's Avatar
    Jun 11th, 2002
    07 VW GLI, 05 Mini Cooper S, 72 BMW 2002
    12-28-2006 10:13 PM #24
    Stage 1 just ordered!
  25. 01-02-2007 11:15 AM #25
    Quote, originally posted by WannabeVWguy »
    vibration?
  26. 01-02-2007 12:03 PM #26
    how much is for front engine mount and trans mount for gti vr6?
  27. 01-02-2007 12:06 PM #27
    Prices are in the first post, and on the website
  28. 01-12-2007 10:26 AM #28
    Ok I finally got to drive mine (Mk2-Vr6) with full stage1 set (including tranny) It feels amazing! and I have to say Vibration is minimal.
  29. Member dossantos25's Avatar
    Mar 17th, 2005
    Toronto
    05 GLI, 09 CBR600RR
    01-13-2007 06:59 PM #29
    vibration?
    ive been in WannabeVWguys car and its not that bad, i just installed the comeplete Delrin kit as well and i just had the car idling and revving while sitting and although there is slight vibration, the engine doesnt move PERIOD ... these are VWs not high end luxury cars so i dont mind a bit of vibrations, but its hardly enough to ripple liquid in a cup in your cupholder.
  30. 01-15-2007 11:01 AM #30
    IM Sent for Trans Mount Stage2
  31. Banned
    Dec 26th, 2005
    01-19-2007 01:12 PM #31
    Can anyone confirm or deny that the st1 or st2's will raise the height of the motor up slightly, and give more ground clearance ?
  32. 01-19-2007 02:14 PM #32
    If your stock mounts are old and have collapsed with new mounts, ours or others, the motor will sit higher than it did but the same as it would with new OEM mounts
  33. 01-20-2007 05:24 PM #33
    I have stage 1's all the way around including the tranny mount. I would recomend replacing all the mounts at once because the stage 1's were too much for the 'heavy duty' rado mount causing it pop. Also, after the mounts were installed i noticed my motor sitting slightly higher than before, it actually would hit the underside of my hood when i would start to slam gears causing it to dent. After i installed the stage 1 tranny mount about 3 weeks ago i noticed that my tranny sounded like it was whinning, but apparently thats normal if you put a solid tranny mount on a VR. I love the way my VR drives now, it feels very solid, and as my friends say 'feels like a go-cart' cause of the mild vibration.
  34. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    01-20-2007 09:39 PM #34
    so a few nights ago, the girl said "i like the vibrations!"
    thats in a stage one. and yes, it was vibrating pretty good. but then again, it was almost -40
  35. 01-21-2007 06:46 PM #35
    How do the stage 1 vibrate compared the the vf mounts?
    I am currently on the turn2 front mount which needs to make way for a complete set.
    The only problem I can see now is that you don't ship outside NA. Any chances for this to change anytime soon?
