VWVortex.com - 18613 code
    Results 1 to 8 of 8
    Thread: 18613 code
    1. Member 3G3T7I's Avatar
      Sep 30th, 2005
      Exeter Twp, PA
      |16GTI|13XC70T6|12CSBE|
      11-08-2006 06:22 PM #1
      This code has shown up after replacing the coolant sensor and establishing readiness. Any ideas how to fix this. Bentley suggests checking the harness and if that doesn't work out, replace the ecu. That seems pretty drastic for a coolant sensor.
      The car car has 44000 miles and GIAC X+ otherwise stock.
      VAG-COM Version: Release 607.2-UD
      Control Module Part Number: 06A 906 032 PL
      Component and/or Version: 1.8L R4/5VT G 0003
      Software Coding: 07510
      Work Shop Code: WSC 65728
      Additional Info: 9BWDE61J824058923 VWZ7Z0A4434738
      1 Fault Found:
      18613 - Performance Malfunction in Cooling System
      P2181 - 35-00 - -
      Readiness: 0000 0000
    2. 11-08-2006 06:30 PM #2
      Ross-Tech Wiki Says...
      http://wiki.ross-tech.com/inde...08577
      18613/P2181/008577 - Performance Malfunction in Cooling System
      Possible Solutions
      * Check Engine Coolant Temperature Sender (G62)
      * Check Coolant Thermostat
      * Check Engine Cooling System
    3. Member 3G3T7I's Avatar
      Sep 30th, 2005
      Exeter Twp, PA
      11-08-2006 07:07 PM #3
      Hey thanks for the info. I picked up the wiki Ross post through the archived threads. I saw mention of replacing the connector, I might try that next. The cel appeared recently immediately after I hit an expansion joint on the highway and I thought maybe it is really a mechanical issue with the connector. Then again today I was cruising on smooth highway at steady speed and the cel lit. My temp is rock steady too once it reaches operating temp. Perhaps before I replace the connector I'll try some connection enhancing solution instead of the dielectric compound someone else used.
    4. Member 3G3T7I's Avatar
      Sep 30th, 2005
      Exeter Twp, PA
      11-09-2006 07:46 PM #4
      I started a log file for my drive home from work tonight and the cel showed up but I didn't see any change in the data. I logged voltage, rpm, coolant temp and ambient temp. I marked the approximate time of the cel as indicated below.
      526.03 2560 14.07 77 28
      526.34 2560 14 77 28
      526.63 2520 14 77 28
      526.94 2520 14.07 77 28
      527.23 2520 14.07 77 28
      527.53 2520 14.07 77 28
      527.86 2520 14.07 77 28
      1 528.15 2520 14 77 28
      528.44 2520 14.07 77 28
      528.74 2520 14.07 77 28
      529.05 2520 14 77 28
      529.36 2520 14.07 77 28
      529.65 2560 14.07 77 28
      529.95 2560 14.07 77 28
      530.25 2560 14.07 77 27
    5. Member 3G3T7I's Avatar
      Sep 30th, 2005
      Exeter Twp, PA
      11-18-2006 04:35 PM #5
      OK, I applied some Stabilant 22 to the connector but still tripped the cel on the way from work today. I'm thinking thermostat next. The story continues
    6. Forum Sponsor TyrolSport's Avatar
      Mar 4th, 1999
      New Yawk
      Mk6 GolfR, Q7 4.2, G60 Corrado, 5.0 Fox, '55 Roadmaster, R52 JCW
      12-30-2006 12:33 PM #6
      Any update on this?
    7. 01-10-2007 07:08 PM #7
      Is there an Auxiliary Water Pump on this car?
    8. Member climbingcue's Avatar
      Feb 2nd, 2001
      Kremmling, CO
      '12 VW GOLF R, '03 Toyota 4Runner, '12 RZR 900 XP
      01-20-2007 07:09 PM #8
      Change themostat, I had this same code... Just need to wait a couple of days to make sure it does not come back...
      United Motorsport 12.311@112 mph on 93 octane
      Georgia 1/2 mile 2014 135.78 mph
