is the 1 yr warranty through you ?or TOP ?
who would i return them to ?
#1
HID'S ON STOCK READY TO SHIPPEDJETTA ECODES H4 COMES WITH HIGH AND LOW BEAM
JETTA NA HEADLIGHTS 9004 COMING SOON.
OKguys i just got 30 set of aftermarket HIDs.these are plug and play not cutting no taping very simple.
the kit comes with:
* Two HID Light Bulbs
* Two Ballasts with Cables
* Wire Harness
* Other Installation Accessories for installation
* User Manual
* 1 yr warranty on the BallastsAny question please Pm me thanks
If you want just send the payment to enemigra@hotmail.com for $150 shipped In the usa CANADA CUSTOMERS PLEASE ADD $6 EXTRA FOR SHIPPING make sure you write what bulbs you need and temperature color 6000k 8000K and 10000k
Modified by Diego_iz_the_vw_man at 2:01 PM 11-17-2006
Modified by Diego_iz_the_vw_man at 6:44 AM 11-18-2006
#2
#3
Quote, originally posted by fst4dr96 » is the 1 yr warranty through you ? or TOP ?
to me as long is not water damage ill take them back and send you the new ballast for free.![]()
#4
12000khottness
#5
if im correct, these are just for the e-codes right? not N/A spec lights.edit: cuz i have a 98 jetta and i use 9004 bulbs.
Modified by eurorice98 at 11:26 AM 11-17-2006
#6
Quote, originally posted by eurorice98 » if im correct, these are just for the e-codes right? not N/A spec lights. edit: cuz i have a 98 jetta and i use 9004 bulbs.
You are correct H4 ecodes only Na jetta haedlights 9004 I just order some sets of this too
#7
dam ui was lookin for a reason to go get e-codes
oh well
#8
Quote, originally posted by eurorice98 » dam u i was lookin for a reason to go get e-codes
oh well
#9
good price!
#10
Quote, originally posted by Deuce34 » good price! H4 GOOD FOR JETTA ECODES
#11
can you show possible installs of these lights? The back of the ecode is sealed and I think it would have to be drilled to run the wiring from the bulb to the ballast
#12
Quote, originally posted by euronated » can you show possible installs of these lights? The back of the ecode is sealed and I think it would have to be drilled to run the wiring from the bulb to the ballast all you have to do is drill a whole on the rear round plastic piece and run the wires there......very simple my friend
#13
I just ordered a set of H4's for my jetta hopefully ill get them in a few days.
#14
Quote, originally posted by EuroRS4 » I just ordered a set of H4's for my jetta hopefully ill get them in a few days. ![]()
#17
Quote, originally posted by CruiseVW » No H1's ![]()
i just order few sets coming wednesday![]()
#18
Cant wait for those 9004s!
#19
Quote, originally posted by Diego_iz_the_vw_man »
Sweeet! GTI ecodes are H1's right? I'm just assuming since that is what is currently in my votex lamps.
Do you have any of the 3000K or 4300K sets? I'd really like one of those.
#20
when the 9004 come, is it high and low beam? or just low?
#21
Quote, originally posted by 98stocker » when the 9004 come, is it high and low beam? or just low? high and low!! bean
#22
Got a light pattern pic for these kits? wondering how they aim and the pattern without a projector.
#23
Quote, originally posted by brandonp » Got a light pattern pic for these kits? wondering how they aim and the pattern without a projector. same question here too
#24
the housing you use these lights in will determine the light pattern, not the light itself. So whatever your current light pattern is will be the same, just brighter. Or a different color depending on the kelvin you choose.
#25
Quote, originally posted by CruiseVW » the housing you use these lights in will determine the light pattern, not the light itself. So whatever your current light pattern is will be the same, just brighter. Or a different color depending on the kelvin you choose. you are good!!!
#26
what if you have dual chamber lights? Do you have to get two sets? I dont know much about lights never really needed to know much more than putting a bulb in.
JFFFJF If you don't know don't ask
#27
Quote, originally posted by BubbasA2 » what if you have dual chamber lights? Do you have to get two sets? I dont know much about lights never really needed to know much more than putting a bulb in. I doubt they will give you 2 sets for that price. If you wanted you could buy a second set for the high beams, but to be honest its not needed. Plus if you do it that way you lose the ability to flash your high beams to warn traffic since HID's don't light up as fast as halogens.
The low beam HID is PLENTY of light. I ran a 4300k set and I RARELY ever used my high beams, the HID's pretty much washed them out anyways.
Quote, originally posted by Diego_iz_the_vw_man » you are good!!!
Thanks!
#29
do you have any sets of 4300k in?also, do you have any pics of the output?
Modified by VR-Jetta at 1:40 AM 11-21-2006
#30
Quote, originally posted by VR-Jetta » do you have any sets of 4300k in? also, do you have any pics of the output?
ONLY 6K and sorry i dont have pics of the ouput!!! ill go out of business if i would test every Hid kit i have!!!
#31
Will you ever have any sets of 4300? Ill buy one![]()
#32
maybe when someone installs these they can give us a pictue![]()
#33
Quote, originally posted by 98stocker » maybe when someone installs these they can give us a pictue ![]()
#35
just sent my paymentcan't wait for them to come in
