Page 1 of 11 1 2 3 4 5 ... LastLast
Results 1 to 35 of 351
Thread: TRANS and parts, 5th gears, ring and pinions, gears etc. (020 & o2a trans)
  1. 11-19-2006 10:24 AM #1
    Trans are rebuilt,
    Bringing a few to Show and Go (October 16) p>2.0L 8V trans codes DFQ/CHE
    2.0L 8V trans.
    1.8T EHA trans, can also install a 3.389 Ring and Pinion for overall taller gear ratios. >VR6 GTI/Passat/Jetta CCM trans
    VR6 Corrado CDM
    VR6 and 1.8T $700, modified ( tall 5th gears, tall ring and pinion )$780
    2.0L modified $750
    Stock 2 Liter 5 speed trans, CHE, DFQ, with diff bolt kits. $750 for the trans outright shipped, $650 with your old trans (no holes in the case CHE or DFQ codes) all with new seals, bearings, clips, reverse gear, synchros, throw out bearing, throw out bearing arm, etc, speed sensor included. $20-$40 off with your blown up trans!
    Peloquin diffs can be added to any trans ( extra )
    .75 and .71 5th gears can be added (extra)
    axle flanges for O2A trans $40 for 2, shipped
    100 mm axle flanges $25 for 2, shipped (for 020 trannies)
    90 mm flanges $25 for 2, shipped
    .71 5th gear set for 020 trans ....... $110 Shipped in the U.S.
    .75 5th gear set for 020 trans........$90
    .80 5th gear ... for 020 trans .........$80
    3.89 ring and pinion sets ...$60 plus shipping
    3.67 ring and pinion sets ...$80 plus shipping, 3.94 020 ring and pinion $90.
    Gears from many codes, im for more info.
    IM for more info.
    Modified by HGB at 4:25 PM 11-19-2006
    Modified by HGB at 4:30 PM 11-20-2006
    Modified by HGB at 8:28 PM 12-7-2006
    Modified by HGB at 9:00 PM 1-5-2007
    Modified by HGB at 5:33 AM 8-25-2007
    Modified by HGB at 4:46 PM 10-9-2007
    Modified by HGB at 11:58 PM 11-10-2007
    Modified by HGB at 7:54 AM 1-8-2008
    Modified by HGB at 7:55 AM 1-8-2008
    Modified by HGB at 6:52 AM 1-16-2008
    Modified by HGB at 8:11 AM 2-25-2008
    Modified by HGB at 7:11 AM 2-28-2008
    Modified by HGB at 12:24 AM 4-3-2008
    Modified by HGB at 2:47 PM 4-3-2008
    Modified by HGB at 8:33 AM 4-18-2008
    Modified by HGB at 8:47 AM 5-4-2008
    Modified by HGB at 9:43 PM 5-31-2008
    Modified by HGB at 3:03 AM 9-24-2008
    Modified by HGB at 3:09 AM 10-20-2008
    Modified by HGB at 12:38 AM 11-27-2008
    Modified by HGB at 7:10 PM 12-9-2008
    Modified by HGB at 8:55 AM 7-26-2009
    Modified by HGB at 11:56 AM 11-8-2009
    Modified by HGB at 6:33 AM 12-8-2009
    Modified by HGB at 5:14 AM 4-2-2010
  2. 11-19-2006 11:31 PM #2
    i'll definitely take a .71 5th gearset w/ no chipped teeth 'n such
    ready to paypal
    email: jimmytj@gmail.com
    Modified by jimmytj at 8:41 PM 11-19-2006
  3. 11-19-2006 11:58 PM #3
    Have any 02A/J RP'S 3.94 left? Thanks!
    Mobile One Inc VW and Audi performance tuning 847.724.7097
    / General maintenance / Mig+ Tig welding / Standalone eng. management / 2WD Dyno on site
    Authorized Unitronic Dealer For Illinois
    http://www.mobileoneinc.com https://www.facebook.com/MobileOneInc
  4. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    98 740iL, 86 TD Jetta, 66 Sunroof Bug, rusted 69 Beetle Vert
    11-20-2006 12:13 AM #4
    IM sent about some gear sets and stuff...
    If voting actually changed things it would be illegal.
    http://forums.vwvortex.com/showthrea...5#post75364055
    Quote Originally Posted by eatonrabbit View Post
    But if you're looking for a water cooled Euro club/group that specializes in VW's then http://www.kch2o.org is a good place as well.
  5. Member Wraith04's Avatar
    Jun 24th, 2004
    DFW
    11-20-2006 12:48 AM #5
    IM sent.
  6. 11-20-2006 02:06 AM #6
    I'm not so sure on how this all works so I'll ask. I got my CHE stuck in third and was told to get rid of it. I did and the only thing available to me at the time was a 2Y, something happened 5k miles later and I thought it was the transmission I had just put in. As my luck would have it, the only thing I could find was another 2Y. Took down the old one and put in the new just to find out the tranny was fine. Now I have 2 close ratio transmission in good order. My question is ... Can I do something to get the same gear ratio I had like in my CHE, believe it or not my car is now slower with this transmission and is rubbish on the freeway. Sorry for writing so much in you fs post.
  7. 11-20-2006 10:08 AM #7
    No problem with writing too much man. The 2y should have accelorated better up to hi way speed. The 5th gear will cause the rpm to be up a little as its a .91 compare to the che .80. The che can be repaired. You can even use the 5th from the che, dfq, or aws (.80 5th ) Sending IM for more details.
    Modified by HGB at 10:37 AM 11-20-2006
  8. 11-20-2006 11:25 AM #8
    OH man, the 3.94 was used already, its in a corrado 16v now.
  9. 11-20-2006 11:26 AM #9
    All IMs returned.
  10. 11-20-2006 09:20 PM #10
    IM sent
  11. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    11-22-2006 06:38 PM #11
    Money order sent for discussed parts
  12. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    11-22-2006 09:38 PM #12
    Bump
    And remember..some of the later 16v transmissions used a SLIGHTLY larger inside diameter on the 4th gear. So an 86-87 (what ever the 1st year was) trans might not have the same ID 4th as a 92 trans 4th.
  13. 11-26-2006 04:43 AM #13
    An o2o tranny will fit a 02.5 and up 1.8t correct?...
  14. 11-26-2006 08:34 AM #14
    will bolt to the block
  15. 11-26-2006 02:49 PM #15
    Are any of the 020 FN transmissions in good working order? If so, how much shipped to 98026?
    Steve
  16. 11-27-2006 12:58 AM #16
    Id like to pick up the 02A if its in decent shape, if youl ship IM me price and stuff
  17. 11-28-2006 07:06 PM #17
    All the fn trans were taken apart, only have parts left, unless you want a full rebuilt unit. IM me.
  18. 11-28-2006 07:07 PM #18
    o2a might be sold will let you know.
  19. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    11-28-2006 11:24 PM #19
    Woohoo...I got a tracking number..
    Bumperooo
  20. 11-29-2006 01:42 PM #20
    hey i need a tranny for an mk3 2.0 let me know asap if you want to get rid of it
  21. 11-29-2006 07:11 PM #21
    I have 2 2.0L 8v trans for now, one has a bolt kit and one is stock.
    The bolt kit trans is $500, the stock one is $400.
    Both have all new input shaft seals, push rod seal, axle flange seals.
  22. 11-29-2006 09:43 PM #22
    sent IM....have cash
  23. 12-01-2006 06:22 PM #23
    got my 5th gearset today. thanks!!
  24. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    12-01-2006 07:21 PM #24
    My stuff is sitting in my PO box...now if I can just get away to get it.
  25. 12-01-2006 07:41 PM #25
    Sent you IM with tracking number, package was sent off.
  26. 12-01-2006 07:42 PM #26
    No problem.
  27. Member Kudagra's Avatar
    Sep 12th, 2005
    The Middle
    12-01-2006 10:13 PM #27
    Yea Ive been checking it everyday...USPS is kinda lame since it showed that it was picked up...then 3 days later it said it was waiting for me at the Post office.
    Look great and YEA!! Extra parts!
    Buy some stuff from this guy...he rocks.
  28. 12-02-2006 02:53 AM #28
    prop shaft???? LMK GOT $$ if u got it!
    EDIT: CCM
    Modified by blackMKAY3 at 11:55 PM 12-1-2006
  29. Member PBWB's Avatar
    Sep 12th, 2004
    NoVA
    91 GTI, 97 GTI VR, 06 MkIV Golf
    12-03-2006 09:46 AM #29
    Got a .7x 5th gear that will fit a g60 o2a?
    -Apple
    Articulated Speed Solutions FTW
    *******FS: Autronic SM4 standalone engine management********
    Quote Originally Posted by slcturbo View Post
    I dont care what you or anyone else "thinks" they have done. We're all just racing for fun on here whether you run 9's or 17's.
  30. 12-03-2006 02:37 PM #30
    Going to check on the gears. Will send IM.
  31. 12-04-2006 12:55 PM #31
    have paypal ready if you have the .71 5th for a o2a.
  32. 12-04-2006 09:51 PM #32
    The .71 5th gears were for the 020 trannies. I only have a .79 02a 5th gear set.
  33. Member ubercruizinvr6's Avatar
    Jul 5th, 2002
    Orange County, SoCal
    98 GTI VR6s, 2011 GTI
    12-10-2006 08:21 PM #33
    have a later style 02A shift tower/shift turret assembly? For a CCM Mk3 tranny. thanks!
  34. 12-11-2006 11:29 PM #34
    o2a selector shafts complete... sold out.
  35. 12-13-2006 09:41 AM #35
    Hit me bak as soon as posssible I'm willing 2 go and pik some stuff up hit me bak @ 5168056574 I can come this weekend
