VWVortex.com - DIY: Multi-Function Steering Wheel Retrofit
    Page 1 of 20 1234511 ... LastLast
    Results 1 to 25 of 491
    Thread: DIY: Multi-Function Steering Wheel Retrofit
    1. 11-20-2006 02:53 AM #1
      by the.ronin
      This document is for informational purposes only. Any vehicle modifications should be done by a certified VW mechanic. Neither the author nor this site will be held liable for actions taken resulting from the information set forth herein.
      The retrofit should take you no more than 1 hour. This DIY will show you how to retrofit the steering wheel with or without button functionality.
      Stock steering wheel (SW) from a MY06 2.5L Jetta 6sp tiptronic package 1 build date 11/05 without MFD ...
      Retrofitted multi-function steering wheel (MFSW) from a MY06 Jetta GLI standard transmission (i.e., no DSG paddles) package unknown and build date unknown likely with MFD ...
      Parts Needed
      MFSW p/n 1K0 419 091 BC TDL (p/n with DSG paddles unknown)
      MFSW Airbag Harness p/n 1K0 971 584 L
      MFSW Control Module p/n 1K0 953 549 AJ (superceded with AL)
      Note: Stock SW control module p/n 1K0 953 549 AH has been tested (and recoded with Vag Com) and does NOT work with the MFSW. Control module p/n 1K0 953 549 AF has also been reported not to work. Control module p/n 1K0 953 549 AK has been reported to be used with the MFSW with DSG paddles.
      Note: Some have reported that they needed to replace their slip ring with p/n 1K0 959 653C. Since I had no problems with my slip ring, I'm not sure exactly what the incorrect slip ring even looks like.
      Tools Needed
      * Required tools. All others will just make your life a whole heck of a lot easier.
      * VAG-COM and Hex+CAN cable
      * Wrench 10 mm (to remove battery connector)
      * Square Bit 12 mm (to remove steering wheel bolt)
      * T25 torx bit (to remove lower steering column cover)
      * Pocket knife or strong small blade
      Precision flathead screwdriver 2.5 mm or 3.0 mm (to remove airbag wires)
      Adjustable Torque Wrench (steering wheel bolt at 37 ft lb / 50 Nm)
      Trim Tool (to disassemble steering column)
      Mechanics mirror or small mirror (to look behind steering wheel for airbag removal)
      Removal of SW and SW Airbag
      1. As a precautionary measure, let the car sit for 30 minutes. Pop the hood and disconnect the negative (-) battery cable using the 10 mm wrench. For good measure step on the brake a few times too to discharge any capacitor that may have some juice stored. Wait 10-15 minutes before proceeding.
      2. Unlock the steering column and pull the SW as far as it will go towards you and in the highest (up) position. Put the key into the ignition and turn to the “on” position so you can turn the wheel. Keep the key in the ignition throughout this entire process even while you are reconnecting the battery when the swap is finished – this will keep any power surges out of the airbag circuit (according to Bentley).
      Turn the SW 90 degrees from center to the left (counterclockwise) so you can reach back there with a flathead screwdriver and unlock the SW airbag from the SW. Use the mechanics mirror to get a good view of the latch holding down the airbag.
      The following photo shows the MFSW removed with the MFSW airbag (blown) attached to show the airbag securing bail you are disengaging from the SW mounting lug.
      Disengage the left side of the airbag from the SW by inserting the flathead screwdriver as shown above and turn left (counterclockwise).
      Turn the SW 90 degrees from center to the right (clockwise) so you can repeat the above process and disengage the right side of the airbag from the SW.
      3. Turn the steering wheel back to center and carefully remove the airbag partially out of the SW. The SW airbag will be connected by a wiring harness with 1 connector.
      Disconnect this harness by pulling on the orange locking tab and pulling on the harness connector. Set the airbag aside with the VW emblem facing up so if it does blow up, it won’t shoot off like a rocket.
      4. Remove the center bolt (red circle) using the 12 mm square bit.
      5. Note that this bolt may be used 5 times only. Mark the bolt after each removal. I’ve marked mine off with a permanent marker. Mine actually has two hash marks now since I had to go back and remove the wheel after testing functionality with the stock control module. Yeah, you owe me huge.
      6. Pull the SW off the column and set aside. If you are not planning on button functionality, skip ahead to step #19 taking note of applicable procedures (most will not apply). However, if you are planning on going all out, forge on, pilgrim.
      Control Module Swap
      7. Adjust steering column downward as far is it will go. Keep it pulled towards you as far as it will go. Carefully pry off the lower instrument cluster trim using the trim tool and/or your trusty pocket knife.
      The following shows where the lower instrument cluster trim latches onto the dash on the right side. The same latch is on the same location on the left side.
      8. Remove the upper steering column cover by carefully and slowly prying it off with the trim tool or said trusty pocket knife. The images below show where they latch on the right. The left side is identical. Note there is a latch in the far back. Use a bit of pressure to pry the cover off.
      9. Once the top cover is removed, it will reveal two screws in front face to remove the lower steering column cover. There is also one more screw underneath to the left of the column adjustment locking lever that needs to be removed. Use the T25 torx bit to remove these screws. Release the locking lever in order to remove the lower cover.
      10. Now take a step back, light up a smoke, and meet your nemesis ... that heartless mistress otherwise known as the steering wheel control module.
      11. According to the Bentley manual, you would need to undo that tiny little screw with some sort of special elven torx bit that can only be forged in the volcanic icelands of Narnia and proceed to unlatch the rear locking mechanism with a 2.5mm drill bit along with some unholy arcana.
      Eff that noise, man. We're going to replace the circuit board and bottom cover (which contains the relevant info anyway) and keep that bastard top cover secured to the steering column. Start off by slitting the "I know you effed with it" tamper seal and proceed to unlatch the six latches securing the lower cover from the top cover. The image below shows the control module disassembled. The red circles indicate the latches.
      12. Once you've got the bottom cover off, use your trusty pocket knife to slowly and carefully pry the circuit board away from the top cover. The image above shows where the connectors (blue circles) are and be particularly careful with these. Note that the main connectors are part of the circuit board (green circles).
      13. Once you've got the circuit board pried off, disconnect the main connectors by pulling out the red latch on the black connector and pulling out the orange latch on the yellow connector. The image below shows what these connectors look like once they have been disengaged.
      14. Swap out the circuit board from the MFSW with your stock circuit board. Be careful they look exactly the same and I wasted about 5 minutes trying to remember which was which. There will be an audible response in re-engaging the two connectors. Carefully ease the pins back into the upper cover and relatch all six latches from the lower connector to the upper cover. Behold, the ghetto hack completed.
      15. Reinstall the lower steering column cover and then the upper cover just by doing the above procedures in reverse. And now it's on to rewiring the airbag. Just pray it doesn't blow up and mame you forever.
      Rewiring Airbag
      16. Use the precision flathead screwdriver or equivalent tool to help you remove the three grounding wires (red circles) behind the airbag. Note that the blue circle is not a grounding wire and should not be removed.
      17. Remove the right spring and proceed to undo the rest of the wiring harness. Use the flathead precision screwdriver to disengage the two orange and green connectors. Disengage the yellow pieces in the center.
      18. Weave the MFSW wiring harness into the airbag. Remember to disengage the yellow pieces in the center of the orange and green connectors and push down on these yellow pieces to keep the connectors secured in place. Study the image below and weave the harness as shows. Note the three clips (blue circles) should be used to guide the harnesses. Remember to replace the right spring once you have the harness in place.
      Install MFSW and Airbag
      19. Carefully slip the MFSW onto the steering column. Note the has mark on the steering column and align it as best you can with the hash mark on the MFSW (the hash mark on the MFSW isn't as visible in the image below but you will be able to see it). Secure the MFSW to the steering column with the bolt using the 12 mm square bit and an adjustable torque wrench set to 37 ft-lb (50 Nm).
      20. Reconnect the airbag with the MFSW wiring harness. Note that the black connector connects to the receptacle in the lower spoke. When connecting the main yellow connector through the steering wheel to the steering column, there will be an audible click. Carefully but firmly push the airbag into the MFSW and you should feel the right and left latches engage. Make sure the airbag is firmly secure.
      21. Before reconnecting the battery, insert your key and turn it to the “ON” position. Go to the hood and reconnect the battery. If you did everything correctly, there should be absolutely no error codes or lights on your dash. Just kidding. Your dash is going to light up like it's effing Christmas. Fear not for some vag com magic will set you straight.
      Control Module Coding
      The following is the label file for 16 – Steering Wheel which needs to be rejigerred.
      * 0?xxxxx: Vehicle Type
      o 0 = Normal
      o 1 = Special Purpose (e.g., Taxi)
      * 0x?xxxx: Transmission
      o 0 = Manual Transmission
      o 1 = Automatic Transmission
      * 0xx?xxx: Steering Wheel
      o 0 = Steering Wheel without Multifunction
      o 1 = 3-Spoke Steering Wheel without Multifunction
      o 2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise Control
      o 3 = 3/4-Spoke Steering Wheel with Multifunction with Cruise Control
      * 0xxx?xx: Additional Equipment
      o +1 = Tiptronic (Shift Paddles)
      * 0xxxx?x: Board Computer / Cruise Control System (CCS)
      o 0 = w/o Board Computer and w/o Cruise Control System (CCS)
      o 1 = with Board Computer and w/o Cruise Control System (CCS)
      o 2 = w/o Board Computer and with Cruise Control System (CCS)
      o 4 = with Board Computer and with Cruise Control System (CCS)
      * 0xxxxx?: Rear Wiper
      o 1 = Rear Wiper not installed
      o 2 = Rear Wiper installed
      The original soft code on my car was as follows:
      00xxxxx = normal vehicle type
      0x1xxxx = automatic transmission
      0xx0xxx = steering wheel w/o multifunction
      0xxx0xx = no shift paddles
      0xxxx2x = w/o MFD and w/ cruise control
      0xxxxx1 = no rear wiper
      0010021 = old soft code
      The revised code was as follows:
      0xx2xxx = 3-spoke steering wheel w/ multifunction
      0012021 = new soft code (note that 0013021 might also work)
      Vag Com Adaptation Procedures
      Refer to this link from the Ross Tech Wiki to perform the steering angle adaptation and steering limit stop adaptation to get rid of these lights:
      Ross Tech Wiki:
      http://wiki.ross-tech.com/inde...ation
      You may also need to rejigger your steering assist settings. Select "44" for the control module ("Steering Assist"). Choose "10 Adaptation" and then read channel "1". For my car, the settings ranged from 0 (hardest steering) to 5 (highest assist). I'm an even keeled 3-man myself.
      Lastly, window adaptation should be performed after every battery disconnect. Roll down each window all the way and then roll up each window. This will re-activate auto window up.
      That's it. You are now sporting the coveted leather multi-function steering wheel. Prepare to get laid.
      ******* End of DIY *******
      Thanks to TDI-4-RD (Vortex), edisonr (Vortex), ~kInG~ (Vortex), chadcronin (Vortex), aric (UK-MKIVs), A32Have (Audi Forums), 2.5MODSPLZ!! (Vortex), Brickyward Imported Car Parts, OEMPL.US, Ross-Tech and many others.
      Modified by the.ronin at 8:45 PM 1-11-2007
    2. Member svander's Avatar
      Oct 31st, 2003
      Seattle Metro
      '11 S4
      11-20-2006 03:07 AM #2
      WOW...
      Excellent writeup my friend!!
      Added to the FAQ [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 11-20-2006 03:12 AM #3
      Thanks svander ... least I could do for everyone that's helped me out so much.
      I drove over 200 miles since the retrofit. Man, there is nothing quite like that leather steering wheel feel. And the buttons light up.
    4. Member svander's Avatar
      Oct 31st, 2003
      Seattle Metro
      '11 S4
      11-20-2006 04:04 AM #4
      Yeah, this steering wheel is quite possibly the best feeling one I've personally owned. It's beefy and contoured perfectly; great ergonomics all throughout. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      So, all told, how much did this mod come to?
      It'd be helpful to know so those that are thinking about it know how much they're looking to spend.
      Modified by svander at 1:06 AM 11-20-2006
    5. Member Froster's Avatar
      Apr 12th, 2006
      Mississauga, Ont
      07 Rabbit
      11-20-2006 05:04 AM #5
      Any problems with the button functionality? I would love to do this mod, but since I have a Rabbit, I'm 99% sure that I will need the module. If there are any probs with the button functionality, then I might re-think the idea.
    6. 11-20-2006 08:15 AM #6
      God damn! Thank god I got the steering wheel preinstalled. I thought the hardest mod was the dash cubby, because that everloving bolt on the right side of the dash that you can just barely reach drove me crazy. But that right there looks insane.
    7. 11-20-2006 08:44 AM #7
      Awesome write up. Thanks for sharing
    8. Member EL_3grab's Avatar
      Mar 25th, 2006
      AJ - UAE
      MKV GTI, BiTDI Amarok, 2DR LS327 Classic RR, E36 325i, E36 M3 LS2, E66 760, Classic500 Royal Enfiled
      11-20-2006 08:46 AM #8
      I see the Mid-Line MFD .. As i know you can't change tracks with it
      am i right ??
      Too Pee or not To Pee ..
    9. Member jmj's Avatar
      Feb 6th, 2001
      MA
      06 GTI
      11-20-2006 08:54 AM #9
      This is way more of a mod than I would consider doing myself (far too many delicate things to break for my tastes), but I thoroughly enjoyed your writeup!
      Quote Originally Posted by Taipei_E92 View Post
      If you generalize...you are always going to get it wrong.
    10. Member Happy CampeR's Avatar
      May 12th, 2006
      Hamilton, NY
      11-20-2006 09:26 AM #10
      Excellent DIY!! Congratulations. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2006 VW Jetta TDI - 187,000 miles. Amber LED taillights; Hella Dynabeams; Dieselgeek skidplate. Running fine on Mobil TDT oil. Waiting for the R.
    11. 11-20-2006 10:57 AM #11
      Thanks you guys. A couple things ...
      Pricing
      I paid all-in $375 including shipping for the MFSW, the control module, and the airbag wiring harness. I got it from a salvage yard who was kind enough to include all these parts.
      If you were to buy these brand new the following are suggested retail prices (I am pulling these from the OEM parts catalog so they will be inflated - I can tell you now places like Hillside carry the MFSW for $450 to give you an idea of how inflated):
      MFSW p/n 1K0 419 091 BC TDL -- $669.81
      Airbag wiring harness p/n 1K0 971 584 L -- $69.33
      Control module p/n 1K0 953 549 AJ -- $279.32
      Again, these are straight from the parts catalog but it should give you an idea of the upper bounds.
      Button Functionality
      If you do not have the MFD, the only buttons that will work are the radio volume controls. Whether it's worth it is, like any other mod, up to you.
      Difficulty
      As for difficulty, the retrofit is not difficult at all. Maybe it was because I went into such noobian detail that makes it seem difficult but I just wanted to provide steps for those that are mechanically ignorant as myself.
      Thanks for the comments guys. And if you do this retrofit, please post photos!!
      .:Ronin-line FTW!!
    12. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      11-20-2006 11:38 AM #12
      Very well put DIY [IMG]http://*****************.com/smile/emthup.gif[/IMG]. Now I need to convince my wife to swap the SW in her Jetta.
      EDIT:
      Rob, I don't think you need to run the adaptation to get rid off the steering wheel and ESP light. Those lights are normal after disconecting the battery. All you need to do is to drive the car with the steering wheel centered for a few feet to align the steering wheel angle.
      Modified by edisonr at 11:48 AM 11-20-2006
    13. Member FUZE's Avatar
      Apr 13th, 2004
      San Jose, CA
      11-20-2006 11:53 AM #13
      Dude you are the EFFING MAN
      ICinna-Berry
    14. 11-20-2006 11:56 AM #14
      Quote, originally posted by edisonr »
      Oh dude ... trust me, I drove the car FAR cursing every inch of the way hoping that was all it was. I ran vag com and fault codes confirmed that it required adaptation.
      Thanks, FUZE ... that .:R badge is for you man.
    15. Member FUZE's Avatar
      Apr 13th, 2004
      San Jose, CA
      11-20-2006 11:59 AM #15
      I'm diggin' the .:Ronin line man [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ICinna-Berry
    16. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      11-20-2006 01:10 PM #16
      Quote, originally posted by the.ronin »
      Good to know, I guess somehow the car knows that the steering wheel was removed and need aligment.
    17. Member Mad_Max's Avatar
      Oct 5th, 2006
      Lexington KY
      2006 Jetta TDI 5sp
      11-20-2006 02:19 PM #17
      That is very good DIY write up. Thanks for the info ronin.
      I hope it will be placed in the DIY section.
      Max
    18. 11-20-2006 02:24 PM #18
      Quote, originally posted by Mad_Max »
      Max
      Thanks Max ... svander already did me the honor of putting it in the FAQ. I'm famous now.
      I might do a euro cupholder DIY next ... There is that polish blog website that has a good DIY but he ran out of batteries in his camera to really complete it. Only other DIY are some scans from a Bentley manual. Need one for dummies like me. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by the.ronin at 11:25 AM 11-20-2006
    19. 11-20-2006 02:36 PM #19
      Is there a MFD Cluster available for the 2.5 cars? I ask because I wanted to add this along with a factory nav unit to my wife's Rabbit.
      Excellent write up
    20. 11-20-2006 02:38 PM #20
      I believe the MY 2005.5 pretty much came stock with them or was a pkg 1 option. Maybe a pkg 2 option for the MY06s?
    21. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      11-21-2006 07:25 PM #21
      Quote, originally posted by waterpumper »
      Excellent write up
      My wife's 2005.5 Jetta Pkg 1 came with full MFD, same as my GTI. I wonder what happens to the stalk switch when you install a MFSW.
    22. 11-21-2006 07:27 PM #22
      What do you mean by stalk switch? Your wife's 5.5 could even already come with the appropriate control module too. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      11-21-2006 07:33 PM #23
      Her car has the buttons to switch MFD screens on the wiper stalk.
      Can I check with VAG-COM for the module part #? I guess so. I'll check when she gets back from the gym.
      Modified by edisonr at 7:39 PM 11-21-2006
    24. 11-21-2006 07:36 PM #24
      Her car has the bottoms to switch MFD screens on the wiper stalk.
      Ahh right. I would presume both those controls as well as the SW controls would work.
      Yup, vag com ... you might also need a new airbag harness but that's cheap relatively.
    25. Member edisonr's Avatar
      Oct 24th, 2003
      Houston, TX
      11-21-2006 08:35 PM #25
      Here it is, 2005.5 Jetta 2.5L Pkg 1 full MFD:
      Address 16: Steering wheel
      Part No SW: 1K0 953 549 L HW: 1K0 953 549 L
      Component: Lenksäulenmodul 013 0040
      Coding: 0000041
      Shop #: WSC 00066
