VWVortex.com - Volkswagen Tool # 3104
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 67
    Thread: Volkswagen Tool # 3104
    1. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      1991 VW Golf GTi 16v
      01-04-2007 03:14 PM #1
      To align the shifter after replacing bushing, where can I get one aside from the local dealer?
    2. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      01-04-2007 03:16 PM #2
    3. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      01-04-2007 03:17 PM #3
      This is what I'm looking for:
    4. Member vwtoys's Avatar
      Mar 31st, 1999
      Mk2 GTI, Mk1 TT, Q5, and a Ecoboost Transit
      01-04-2007 03:21 PM #4
      Use an old cassette tape. Or just have someone hold the shifter in the middle of the opening while you tighten the clamp. I've done it on several A2's without the tool and it's been fine.
    5. 01-04-2007 03:28 PM #5
      I beleive someone posted a picture of an actual size stencil you print off your computer then cut it out of steel or aluminum.
      anyone chime in on that?
    6. 01-04-2007 03:40 PM #6
      Bump for the printable stencil..!! LOL
    7. Member timmy5150's Avatar
      Jul 31st, 2004
      PNW
      90 Corrado G60
      01-04-2007 03:40 PM #7
      Techtonics Tuning has them for $12
      http://techtonicstuning.com/
    8. 01-04-2007 03:43 PM #8
      i remember seeing a picture where someone used the bentley as a shifter align tool.
    9. 01-04-2007 03:47 PM #9
      if someone has the printout i can plasma cut them out in my welding class for a couple dollars
    10. 01-04-2007 03:53 PM #10
      yes....thats what we need...Mass production for cheap.
    11. 01-04-2007 04:13 PM #11
      Ef, I have that pic somewhere...
    12. Member peecee's Avatar
      Sep 28th, 2005
      Davidsonville, MD
      01-04-2007 04:21 PM #12
      A cassette gets the job done, but the real deal is so much nicer. The paper deal is the suck because the paper can move after you put it into place. I thought about getting one and making it out of plexiglass. Now that would be cool... It's well worth the $15 or so to have one - I've used mine about 10 times in the last year to fiddle around with my shifter alignment.
    13. Member compu_85's Avatar
      Aug 17th, 2004
      Springfield, VA
      01-04-2007 04:22 PM #13
      Quote, originally posted by vwtoys »
      This method works great! Just put the tape in a ziplock, set it in there open side up, and have someone hold the shifter.
      -Jason
      2012 Passat TDI SE DSG. 99,000 miles. LED tails, VCDS tweaks (wipers, alarm, cluster)
      2004 Touareg V10 TDI. 150,000 miles.
      1999 Jetta "GLX" TDI. 309,000 miles. RCIII, BV49, S520, Knois.
      1991 Mercedes 350SDL. 230,000 miles, 60k on the replacement motor
      Past: 91 Jetta ECOdiesel. Totaled. 92 Jetta ECOdiesel. 87 Audi 5000S Q. 85 Jetta 1.8.
    14. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      01-04-2007 05:30 PM #14
      Who's got one for sale?
    15. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      Barbie Jeep Power Wheel
      01-04-2007 05:32 PM #15
      Quote, originally posted by GXL »
      Who needs one? At worst it takes 3-4 tries to get it right. The side to side alignment is what matters, forwards back can be where you'd like it.
      The width of a casette tape is the proper distance from peg to lockout plate.
    16. 01-04-2007 06:46 PM #16
      Quote, originally posted by The_Hamster »
      I've never used any alignment tools when aligning the shifter. Sometimes it takes 2 or 3 tries, but its easy to adjust.
    17. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      01-04-2007 08:36 PM #17
      I would still like the tool. The sad thing is that I own one, but after 4 house moves I have no idea where it could be.
      So, who what's to sell me one?
    18. Member gti2.0016v's Avatar
      Mar 17th, 2005
      duncansville, pa
      92 gti, 90 corrado, big ole' jeep, 98 Boxster
      01-04-2007 08:53 PM #18
      This might help
      Just make somethin real quick, cardboard even
      [IMG][/IMG]
      Modified by gti2.0016v at 8:55 PM 1-4-2007
      Modified by gti2.0016v at 8:59 PM 1-4-2007
    19. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      01-04-2007 08:58 PM #19
      I see that they're both the same lengh, but how am I suppose to use a floppy drive instead of the vw tool when they look so apart - different?
    20. Member gti2.0016v's Avatar
      Mar 17th, 2005
      duncansville, pa
      01-04-2007 09:02 PM #20
      It is only to gauge the size and shape so you can make one. [IMG][/IMG]
      Here's a fun pic for sihts and giggles
    21. Senior Member Big Dac With Fries's Avatar
      Feb 1st, 2002
      Spatula City
      6000 SUX
      01-04-2007 09:05 PM #21
      Just use a cassette.
      Put it in, ribbon up, in between the lockout plate and the lockout lever.
      Have a buddy sit in the car and hold the shifter rod so it sandwiches the cassette in between the lever and the plate.
      Try not to use a good cassette. Ace of Base cassettes work amazingly.
      "I was thinking about what a friend had said, I was hoping it was a lie."
    22. Banned cbacon411's Avatar
      Jan 19th, 2006
      01-04-2007 09:18 PM #22
      dude stop asking to buy one from someone, you can use a cassette, or buy one from techtonics or german auto
    23. 01-04-2007 09:30 PM #23
      search works. "shifter alignment"
    24. Member GXL's Avatar
      Mar 31st, 1999
      Raleigh, NC
      01-05-2007 02:09 PM #25
      Nice link! I'd still like a tool. I like everything perfect
