VWVortex.com - EIP Releases its Mk5 6 Speed Short Shift & STS
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 35
    Thread: EIP Releases its Mk5 6 Speed Short Shift & STS
    1. 01-12-2007 04:14 PM #1
      EIP now offers for the Mk5 6 Speed our Street and Competition Series Short Shift and STS(side-to-side)
      Both the Street Series and the Competition Series versions retain the OEM weighted shifter design for smooth gear changes, and are simple to install, requiring only the removal of a single 13mm bolt and a few spring clips. You can install it on the ground with no lift necessary, pop the hood install and go it’s as easy as that.
      Plus full PDF downloadable instructions are available here and on the EIP web site.
      All Short Shifts and STS are available in (OEM Look) Silver or EIP Blue. Both Short Shifts carry a Lifetime Warranty.
      Get 10% Off the Retail Price by Typing the Coupon Code "vortex10" When Prompted During Checkout.
      Mk5 Street Series FTB(front-to-back) Short Shift: Features a moderate throw reduction which creates a shorter feel but shifting remains as easy as stock.
      Front to Back Shifter Throw Reduction 40%
      2005.5 - UP 6 Speed GTI, GLI FSI *Requires VIN to order…..$99.99..........With vortex10 its only $89.99……….Buy It Now
      Mk5 Competition Series FTB(front-to-back) Short Shift: Which offers a level of reduction requires slightly more attention as such little input is needed to go from gear to gear. Very sporty, still smooth.
      Front to Back Shifter Throw Reduction 50%
      Mk5 Street Series STS(Side-To-Side) Shifter: Is now available for use with any EIP New Gen Short Shifter for all (O2Q) 6spd transmissions. This is a moderate reduction design that does not in any way compromise the gear selection and actually works to make shifting easier, smoother and sportier.
      Side-To-Side Throw Reduction 20%
      2005.5 - UP 6 Speed GTI, GLI FSI…..$79.99……….With vortex10 its only $71.99……….Buy It Now
      Mk5 Competition Series STS(Side-To-Side) Shifter: Offers a more pronounced reduction and can be installed with current EIP Short Shifters with some modification or will work without modification when purchased in conjunction with our re-designed New Gen Short Shifts, all of which are pre-clearanced for use with our STS upgrade.
      Side-To-Side Throw Reduction 30%
      EIP ALSO OFFERS A COMBO KIT!!!
      The Mk5 Short Shift & STS Shifter Combo kit allows you to choose the series and color of your STS and Short Shift seperatly, not to mention buying the combo kit saves you money!!
      2005.5 - UP 6 Speed GTI, GLI FSI *Requires VIN to order…..$169.99..........With vortex10…..$152.99……….Buy It Now
    2. 01-12-2007 05:37 PM #2
      I love this short shifter.I have a Neuspeed SS on my MKIV and it is short,but the EIP comp SS is a true short shifter.You wont be disapointed.
      EIP SS [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Truth is the light / Never give up the fight. -Bob Marley
    3. 01-12-2007 06:01 PM #3
      ordered mine! cant wait ...
    4. 01-12-2007 06:22 PM #4
      I have B&M SS and have heard you can use your side-to-side SS with it...or even both...is this true?
    5. 01-12-2007 06:52 PM #5
      Quote, originally posted by dalasdhn »
      Yes this is true, at least we know they can both be installed as they replace different components, although we do not feel the B&M components are necessary.
      -Rich
    6. 01-12-2007 07:05 PM #6
      Quote, originally posted by eiprich »
      -Rich
      Thanks!!! B&M has me sold on the lift up notch for reverse...i like it way better than going into reverse the stock way! I have heard of people running the B&M and your Side-to-side SS so i might be in the market for doing the same thing! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. 01-12-2007 07:12 PM #7
      You guys had this available for a while now. How is this different? I'm confused and i just got my wisdome teeth out. you do the math.
      but seriously whats the difference?
    8. 01-12-2007 08:10 PM #8
      Quote, originally posted by glydingsoul »
      I have the same question EIP. I bought an SS in early December for my MKV. Why are you saying its just released?
    9. Member dekoone505's Avatar
      Aug 21st, 2005
      fiveohfive!
      06 GLi
      01-13-2007 02:17 AM #9
      Quote, originally posted by JeepNGLI »
      x2
      I bought a set from a guy that had it on his MKV GTI and it looks a lil different... it could be just me though...
    10. Member Pretarion's Avatar
      Jun 13th, 2003
      Plano, Texas
      '12 TTRS in Phantom Black
      01-13-2007 02:25 PM #10
      Can you explain the difference in front to back and side to side and how each part works?
      Do you need both parts to make a complete short shifter, or can you just use one part?
    11. 01-13-2007 03:27 PM #11
      You are absolutely correct. The MKV short shift kits have been available for some time now. However there was a production break on the late 06 and up models requiring a slight modification in order to work.
    12. 01-13-2007 03:32 PM #12
      Quote, originally posted by Pretarion »
      The difference between STS and front to back is just that. The front to back reduces front to back throw and STS reduces side to side throw. You can use one part if you prefer but that will only give you a reduction in some throw. For instance...if you just installed the front to back piece, you would only be reducing front to back throw.
    13. Member Pretarion's Avatar
      Jun 13th, 2003
      Plano, Texas
      01-13-2007 03:43 PM #13
      Why do you need the VIN numbers to purchase these?
    14. 01-13-2007 03:49 PM #14
      So how do we know if we have the right one? When I received mine, the package said MK4 on it. I called and they assured me it was the same thing. But now your saying its not. ???
    15. 01-13-2007 05:23 PM #15
      Quote, originally posted by brendan@eiptuning.com »
      so my early 06 would require what?!
      or is that why you need the VIN?
    16. Member dekoone505's Avatar
      Aug 21st, 2005
      fiveohfive!
      06 GLi
      01-13-2007 06:29 PM #16
      damn.... so this is the same as the MK IVs? and now u guys need the VIN# to "double" check?
    17. 01-13-2007 11:25 PM #17
      Anybody have this on their car? And if so, how do you like it?
    18. 01-14-2007 11:14 PM #18
      Quote, originally posted by Shainz »
      x2
    19. 01-14-2007 11:18 PM #19
      Quote, originally posted by michaelmark5 »
    20. 01-15-2007 11:49 AM #20
      because some cars from various production runs require a cable adjuster in order to use the shifter lever.
    21. 01-16-2007 10:05 AM #21
      No. If you read my post it says "late model 06 and up."
    22. 01-16-2007 10:06 AM #22
      Because of the production break. We want to verify when your vehicle was made so we can make certain you receive the correct parts.
    23. 01-16-2007 10:09 AM #23
      They are the same...later model MKVs require the additional cable adjuster. It either works or it doesn't. If you have it installed on your vehicle....it is the correct part.
      Modified by brendan@eiptuning.com at 7:11 AM 1-16-2007
    24. 01-16-2007 10:11 AM #24
      Quote, originally posted by Borisbsp »
      BINGO! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. Member electricme's Avatar
      Aug 8th, 2005
      Pottstown PA
      2011 4dr GTI
      01-16-2007 10:13 AM #25
      Has anyone done a DIY on this? I know how to do the front to back, it is very easy. But I have never done the side to side... Where do you change this part at?
      *EDIT* OOPS I found the PDF sorry.
      Modified by electricme at 10:17 AM 1-16-2007
      "Before you try thinking outside of the box, make sure your damn good at thinking inside it."
