    Page 5 of 5 FirstFirst 12345
    Results 141 to 175 of 175
    Thread: Wheel size, Rolling Pulling Fenders, offset, et, suspension, your moms horoscope
      Nov 19th, 2001
      Calgary, Alberta, Canada
      90 Corrado VR6, 2008 E90 M3, 2009 E88 135i
      11-15-2012 11:33 PM #141
      I am currently rebuilding a set of 3 piece rims and trying to determine how much my rim can go past the outside of my fenders without rubbing. I have rolled and pulled all four fenders. My current set up I want to run I have measured that the outside of the rim will protrude past the front and rear fenders by 3/4".
      Rim specs will be
      Front 17x8-1/2" et 14
      Rear 17x8-1/2" et 1
      Planning to run 215-40's all around
    2. Member cata's Avatar
      May 19th, 2006
      Canada eh
      11-16-2012 04:37 AM #142
      That's the size tire I want as well. The pros have recommended 8.0" (or 8.5" rim if you want the stretched look for some pointless reason). Ideal ET is 35.. with a rear fender roll
    3. Member bunkkaws's Avatar
      Feb 7th, 2008
      Alexandria, VA
      08 Passat VR6 4Motion; 92 Corrado SLC
      12-17-2012 04:57 PM #143
      Quote Originally Posted by 90radorotrex View Post
      Rim specs will be
      Rear 17x8-1/2" et 1
      I don't know how much poke has to do with rubbing vs tire size and how low you are!
      et1 is going to be a lot of poke. I am running 17x9 et 15 on pulled and rolled fenders and I have about 15 to 20mm poke. So poke will be close to mine if you do the math.
      oh yeah I am also running 215 x 40 on the 9 and have a 1 finger gap. It rubs on bumps, potholes at 30+ MPH
      .....vortex stalker extraordinaire.
    4. Member TheBurninator's Avatar
      Jan 7th, 2009
      Colorado
      Corrado, Mk1, Mk3, CC
      12-17-2012 05:37 PM #144
      i am currently rebuilding a set of 3 piece rims and trying to determine how much my rim can go past the outside of my fenders without rubbing. I have rolled and pulled all four fenders. My current set up i want to run i have measured that the outside of the rim will protrude past the front and rear fenders by 3/4".
      Rim specs will be
      front 17x8-1/2" et 14
      rear 17x8-1/2" et 1
      planning to run 215-40's all around
      lolol rub rub rub rub.
      SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
      Quote Originally Posted by ein View Post
      * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
      Quote Originally Posted by dogger View Post
      Is society really getting dumber or is it just this forum?
    5. Member eurosportgti's Avatar
      Jan 15th, 2003
      Manchester, CT
      00' Chevy Silverado, 90 Non sunroof Corrado
      12-22-2012 10:12 PM #145
      Thats beyond rub.....i think u should remeasure and do a tiny bit more research and thinking
      Best way to get ahold of me is email....AdamsPainting82@gmail.com or text me 860-593-2459
      http://www.spoonfedtuning.com/
    6. Member corrado-correr's Avatar
      Jul 8th, 2004
      Royal Oak, MI
      04-08-2013 06:18 PM #146
      Wheel specs:
      BBS, RX II, 5x100, 16x7, offset 35mm
      Spacer or adapter specs:
      H&R 15mm front, 15mm rear
      Tire specs:
      BFG, G-Force Sports, 205/45/16
      Suspension:
      KW V1 Coilovers
      Brake Specs:
      Factory DE (11.3) brakes at all 4 corners with ECS slotted Rotors
      Body Specs:
      "Rolled Like A MoFo"
      Clearence Summary:
      Perfect
      ReliableSummerWheelsSLC by rrotsaert, on Flickr
      Raven
      92 Corrado VR6t | 93 Corrado SLC | 90 Miata (because racecar)
      DCC - Detroit Corrado Club
    7. Member PinoyVR6's Avatar
      May 23rd, 2003
      Norwalk, CT
      90 Nugget Yellow Corrado, 2003 Jetta W>E
      04-09-2013 08:44 AM #147
      Subscribed
    8. Member ajhvw93's Avatar
      Oct 26th, 2009
      PA
      80 Rabbit Diesel....87 16V Scirocco...87 8v Gti..93 vr6 Corrado
      04-09-2013 01:16 PM #148
      Audi TT Fat Fives
      205/40/17
      OE Brakes
      VR+
      Koni adj.
      Neuspeed Race Springs 1.5 Drop
      Vr Fenders
      Rear rolled
      Does not rub
      (before rears were rolled drivers side back only would rub on big bumps)
      Jul 22nd, 2011
      1991 corrado g60, 1994 corrado VR6
      05-13-2013 07:48 PM #149
      Wheel specs:
      Schmidt modernline 1-piece, 16x9 4x100, et25 front and et15 rear
      No spacers
      Tire specs:
      Falken 512, 205/40/r16
      Suspension:
      FK silver line plus dampening and height adjustable coilovers
      Brake Specs:
      Factory G60 brakes, oem rotors all corners
      Body Specs:
      Untouched G60 fenders
      Clearence Summary:
      Perfect, no rubbing
      Front angle:
      Rears:
    10. Member 1broknrado's Avatar
      Jul 6th, 2005
      Queens/CT
      24v Corrado
      09-03-2013 09:59 PM #150
      bump this back from the dead.
      My 24v Vr6 Corrado Build Thread
      Click Here to Vote "Yes" so Standalone Tuning can have its own Technical Forum
      Quote Originally Posted by Inkarnata View Post
      Corrado's come with cocaine in the dash vents, blows it straight into your face and gets you hooked....
    11. Member ewillard's Avatar
      Apr 21st, 2007
      Lewisberry PA
      1990 16vt corrado
      10-09-2013 06:42 PM #151
      Need help. Trying to determine what offset and size I can fit on my 90 corrado. Car is getting ready to brake 500+ whp. Need to try and keep as much traction as I can. I must run 17" my brembo big brakes wont clear anything smaller. I will be putting drag radials on. And I will raise the front coils up to fit some poke of 9 or 10. Im not the best with offsets and fitment.
      Sent from my ADR6425LVW using Tapatalk 4
      Quote Originally Posted by VR6W8 View Post
      Is it a sickness? Yeah, I think so. Why I still tinker with it, and still own it, I have no idea really.
      my build thread pic heavy http://forums.vwvortex.com/showthrea...k-build-therad click for corrado bently PDFhttp://www.4shared.com/zip/eVgLVViZ/corrado.html
    12. Member Radvr6T's Avatar
      Jun 3rd, 2003
      Vancouver Canada
      1993 Corrado VRSEXT & The Daily Yoda Echo hatch
      10-09-2013 09:10 PM #152
      Wheel specs: BBS RSS
      (RS321)Fronts= 17x9 ----Backspace of 6/14 + I run a 5mm spacer to clear coils/brakes= total BS of 6= ET 25
      (Rs 329)Backs = 17x9 ---Backspace of 5.75= ET of 19
      5mm in the front
      Tire specs:
      Falken 452s, 205/40r17 all around
      I ran 215/40 in rear and they rubbed. Recently switched to 205
      Brake specs:
      Stock OE calipers with slotted and drilled rotors/ freshley painted calipers
      Suspension specs:
      KW V2 coilovers, Lowered but still tons of thread
      Body specs:
      VR front fenders rolled
      Rear Fenders rolled --they need work due to PO running a cup kit and killing the rear fenders
      Clearance summary:
      Doesn't rub in front and hardly rubs in the back with the exception big scary bumps
      ▀▄▀▄▀▄▀ Proper▀▄▀▄▀▄▀ <<<<YouTube Video
      My OCD Corrado build thread,My Mk4- 337 cleanup thread
      CarOccasionallyRequiresRacingAnd DangerousOutings
    13. Member bunkkaws's Avatar
      Feb 7th, 2008
      Alexandria, VA
      01-17-2014 08:49 PM #153
      bump from the dead!
      Wheel specs:
      Zauber Monoblocks
      Front 17x8 ET 45
      Rear 17x9 ET 45
      Adapters 5x114 to 5x100 32mm front and 35mm rear
      Camber
      -1.5 front
      -4 rear (camber shims)
      Final ET: 13 Front
      10 Rear
      Tire specs:
      Falken 912 205/40/17 Front
      205/45/17 Rear
      Brake specs:
      Stock VR6
      Suspension specs:
      FK Streets
      Body specs:
      Pulled and Rolled Fenders all around
      Clearance summary:
      Rubs in rear on big dips. Coils with adjustable dampening should solve that
    14. Member cyrus88's Avatar
      Feb 13th, 2008
      Long Island, New York
      comsic green nose candy
      01-17-2014 09:44 PM #154
      I think I'll play along. I've actually been trolling this thread for a couple years and I think I'm ready to make a contribution.
      Wheel Specs:
      H.R.E. Custom 525- 526
      16x8 et42 front
      16x9 et50 rear
      5X100 to 5X130 20mm adapters all around
      Tire Specs:
      Falken 512's all around
      Brake Specs:
      Stock OE Calipers with blanks in the front and cross drilled in the rear
      Suspension:
      B&G RS II's
      Lowered but still have some threads
      Body Specs:
      G60 fenders rolled front and rear
      Clearance Summary:
      Doesn't rub in the front, some minor rubbing in rear over big bumps
      Picture time:
      The Usuals
      Instagram: usual_primetime88
    15. 01-17-2014 11:04 PM #155
      First picture is Gorgeous. ^^^^
    16. Member
      Jun 23rd, 2009
      2 93 corrado slc's
      01-18-2014 08:51 AM #156
      keep this thread alive!
    17. Member 1broknrado's Avatar
      Jul 6th, 2005
      Queens/CT
      24v Corrado
      01-18-2014 10:45 AM #157
      Love your cosmic green rado
    18. Member eurosportgti's Avatar
      Jan 15th, 2003
      Manchester, CT
      01-18-2014 11:13 AM #158
      ill play today.....Arches pulled and rolled something feirce, Wheels are Volk GR-C, Et is 40 something. I ROCK NO SUSPENSION. Thats how hard I am! (probably gonna bag it tho). and my mom is dead!!!
      [IMG][/IMG]
      20mm and 35mm respectivaly
      [IMG][/IMG]
    19. Junior Member
      Sep 15th, 2013
      Pittsburgh PA
      1992 Corrado slc
      01-19-2014 01:34 PM #159
      Contributing to an ongoing helpful thread..
      Wheel specs:
      Bbs e75 5x130
      Fronts - 15x8.5 et25
      Rears - 15x9.5 et40
      Adapters/spacers:
      5x130 - 5x100 adapters
      Fronts - 15mm + 5mm spacer to clear brakes.
      Final et:5
      Rears - 22mm
      Final et:15
      Tires specs:
      195/45r15 all around
      Break specs:
      Factory vr calipers, slotted rotors
      Suspension:
      Air ride
      Body specs:
      Rolled Vr fenders
      Clearance summary:
      No rub unless riding extra low
      Pics:
      ...possibly going to pull fenders to fit better and or a small amount of negative rear camber
    20. Member eurosportgti's Avatar
      Jan 15th, 2003
      Manchester, CT
      01-19-2014 04:30 PM #160
      Quote Originally Posted by Alexx_slc View Post
      Wheel specs:
      Bbs e75 5x130
      Rears - 15x9.5 et40
      Adapters/spacers:
      Final et:5
      Rears - 22mm
      Final et:15
      Tires specs:
      Break specs:
      Suspension:
      Air ride
      Body specs:
      Rolled Vr fenders
      Clearance summary:
      Pics:
      Sitting purdy!!!!! lets talk air ride.....Im gonna msg u
    21. Junior Member dsvictorious's Avatar
      Feb 20th, 2011
      U.S.A.
      93 Corrado SLC VRT, 2012 Jeep Wrangler Sahara 4dr lifted
      02-14-2014 02:07 AM #161
      Thank you for starting this thread!!
      “We the people......” “A well regulated militia.....”
      -Founding Fathers
      "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -George Orwell
    22. Member Rhino74's Avatar
      May 31st, 2010
      Ontario, Canada
      A couple corrados, a couple mk3's and a mk2
      03-16-2014 02:51 PM #162
      Looking to run CCW lm5t's 16X8.5 all around et27 with a 205/40/16.
      Running drivers edition calipers up front with 11.3" rotors. Stock vr6 fenders.
      How am I looking for brake clearance?
      Instagram: blakereinhart
      www.berlinklassik.ca
    23. Semi-n00b
      Mar 1st, 2014
      Lancaster, PA
      Black 1991 g60
      03-16-2014 09:06 PM #163
      SO MANY OPTIONS
      Zauber Monoblocks, Schmidt Modernlines, BBS RS all look so good no matter how many times I see them.
    24. Member post-it-note-killer's Avatar
      Mar 25th, 2004
      Mesa, AZ.
      Two VW's, A BMW, a Porsche, and one of those toaster things
      04-05-2014 01:53 PM #164
      I'll play along. I've been running these wheels on my Corrado since November of 2011. I almost never see them. Not even on Porsche. They were introduced in 2002 for the Porsche Carrera (996) but since they're only 17" almost no one ordered them. Most 996 buyers wanted larger wheels. However. There is another Corrado on page 4 that has these same wheels. So I'm not the only one.
      Wheel specs:
      Porsche 996 Carrera 2
      Front: 17x7 ET: 55
      Rear : 17x9 ET: 50
      Adapter specs:
      Custom made by a vortex member in PA.
      4x100-5x130
      Front: 40mm
      Rear: 30mm
      Tire specs:
      Front: 205/40/17
      Rear: 215/40/17
      Brake specs:
      Front: Grilling 60 calipers, braided steel lines, cross drilled rotors (stock diameter)
      Rear: Stock calipers, rotors, and lines.
      Suspension specs:
      FK Street-Line coilovers, all factory otherwise.
      FWD
      Body specs:
      G60 body with a VR6 motor swap.
      Fenders lightly rolled front and back
      Clearance summary:
      Very rarely rubs in front. Only with a particularly harsh dip/bump at high speeds. Or when making a sharp turn at very very low speeds and combined with some kind of elevation change. I.E. Speed bump while turning or aggressive driveway entrance while turning sharply.
      It used to rub in the rear all the time before I rolled the panels. With current height and lightly pulled panels, it no longer rubs.
      I know it said "one picture" but... Here's more than one.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      I buy and sell cars. So if you need something let me know. I have cars, people want cars, I can sell my cars to people, that's basically how this stuff works.
      480-274-4188
    25. Member onavarro8's Avatar
      Oct 3rd, 2006
      Washington
      VW Corrado VR6 '93
      04-09-2014 12:09 AM #165
      Wheel specs:
      CCW D11L
      Satin black centers, gloss black lips
      Front: 16x8 ET: 16 (2" Lips)
      Rear : 16x8.5 ET: 16 (2.5" Lips)
      Adapters: None
      Tire specs:
      Falken 912s
      205/40/16 all around
      Brake specs:
      Stock calipers, EBC slotted front, Brembo rear
      Suspension specs:
      Koni
      Body specs:
      Stock VR6 fenders
      Clearance summary:
      No rubbing on front. Rarely rubs on rear, mainly on big bumps. Will roll rear fenders at some point.
      Nice cars turn heads...Corrados break necks!
    26. 04-09-2014 01:17 AM #166
      I freaking dig those^^^
      Love the Black on black^^^
    27. Member jds92slc's Avatar
      Nov 27th, 2004
      Boston MA
      92 Corrado VR6 - 09 TDi JSW
      05-25-2014 08:03 PM #167
      Quote Originally Posted by onavarro8 View Post
      Wheel specs:
      CCW D11L
      Adapters: None
      Tire specs:
      Falken 912s
      Brake specs:
      Suspension specs:
      Koni
      Body specs:
      Stock VR6 fenders
      Clearance summary:
      Digging this one!!!
    28. Member TxJet98's Avatar
      Jun 29th, 2012
      Houston, TX
      2014 Golf TDI and 1993 Corrado SLC
      06-19-2014 12:43 PM #168
      Wheel specs:
      Porsche Turbo Twists from a Cayman S
      Front: 17x7 ET50
      Rear : 17x8.5 ET55
      Adapters:
      25mm all around, 5x100 to 5x130
      Tire specs:
      Falken 912s
      205/40/17 all around
      Brake specs:
      Stock
      Suspension specs:
      VR+ Weitec Race Coilovers
      Body specs:
      Rolled front fenders, rolled and pulled rear fenders
      Clearance summary:
      Front rubs on the edge of the bumper and fender liner (should eventually melt and be okay) and rear will occasionally rub over big bumps. I AM rolled on all 4 corners though, and pretty low...
    29. Member blumpkin88's Avatar
      Sep 11th, 2006
      Pasadena, MD
      94' Corrado VR6 - 2012 Hyundai Sonata 2.0T (Daily) - 2006 GTI 1.8Turd (SOLD)
      08-13-2014 09:15 AM #169
      Wheel specs:
      BBS RS
      Front: 16x7 ET25
      Rear : 16x8 ET35
      Spacers:
      Front: 5mm
      Rear: none
      Tire specs:
      Yokohama S.drive XLs
      195/40R-16 all around
      Brake specs:
      Stock (shaved down front carriers)
      Suspension specs:
      Airlift slam series air ride w/ switchspeed management
      Body specs:
      VR6 fenders slightly pulled (about .5") all around
      Clearance summary:
      Good clearance all around unless I try to ride crazy low...which I don't.
      IG: @sghalpe
      My Corrado "Build"
    30. Member RedYellowWhite's Avatar
      Apr 21st, 2008
      Limassol, CYPRUS (That's in Europe,lol)
      '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
      08-13-2014 04:46 PM #170
      Quote Originally Posted by blumpkin88 View Post
      Wheel specs:
      BBS RS
      Front: 16x7 ET25
      Rear : 16x8 ET35
      Spacers:
      Front: 5mm
      Rear: none
      Tire specs:
      Brake specs:
      Suspension specs:
      Body specs:
      Clearance summary:
      ^^Nice one - clean and classic style
      Ever thought of color matching the sideskirts?
      ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
      My Corrado (sort of) build thread / On Database
      My MK1 build thread
      SpoonFedTuning
    31. Member DeckManDubs's Avatar
      Sep 26th, 2004
      Mass
      Corrado SLC , TT 225QC , E39 540i, 9-3ss, 2500HD 8.1
      08-14-2014 07:53 AM #171
      17x7 BBS LM's
      205/40/17 Tires
      H&R Ultra-Ultra Lows
      Wilwood Billet Dynalites
    32. Member Rhino74's Avatar
      May 31st, 2010
      Ontario, Canada
      08-14-2014 10:53 AM #172
      Wheel specs:
      BBS RS 269. 16X8.5 all around ET28 w/1.5" lips all around.
      No spacers or adapters
      Tire specs:
      205/40R16 Falken 912
      Brake specs:
      mk3 drivers edition 11.3"
      Grinded calipers, machined brake pads. Its a tight fit. Upgrading to Wilwoods for next year.
      Suspension specs:
      VR+
      KW V2 dampening adjustable coilovers
      Body specs:
      Stock, unrolled, unmolested VR6 fenders/quarters.
      Clearance summary:
      no rubbing in front with a tinge of negative camber. My guess would be -1.5 degrees. Very rarely will rub on fender liners over big dips.
      slight rubbing in rear on one side. Rear axle beam is slightly off so the side that sticks out more rubs slightly. Once I fix the axle issue I expect there to be zero rubbing.
    33. Member Golfatron3's Avatar
      Mar 6th, 2002
      Ottawa, ON
      94 Ice Grey Violet VR6, 92 Tornado Red VR6 Syncro Wagon
      08-14-2014 06:21 PM #173
      ^Blake, I was waiting for you to post. IMHO this is the perfect fitment for a Corrado. The wheels also look sexy as hell.
    34. Member Rhino74's Avatar
      May 31st, 2010
      Ontario, Canada
      08-14-2014 07:25 PM #174
      Quote Originally Posted by Golfatron3 View Post
      Thank you sir. Couldnt have done it withoutcha. Perfect figment.. lol.
    35. Member torquesteer's Avatar
      Jul 26th, 2008
      Hartland, VT
      12 JSW - 09 Tiguan - 81 Caddy - 92 Corrado SLC Summer Ride - 91 Jetta Coupe VR6 Project
      08-26-2014 09:05 AM #175
      Wheel specs:
      Volks Racing / Rays Engineering, GTP, 5x100, 16x8 , not sure on off set.
      Raceland, 5x100/5x112 10mm Front / 15mm Rear
      Suspension specs:
      Raceland Ultimos Coilovers
      Body specs:
      SLC VR6 body
      Fenders rolled and seam sealed
      Modified front fender well plastics
      Clearance summary:
      Rubs or doesn't rub in front
      No rubbing
