    Page 6 of 6 FirstFirst ... 23456
    Results 176 to 181 of 181
    Thread: Wheel size, Rolling Pulling Fenders, offset, et, suspension, your moms horoscope
    1. Member CamberKraut1.8t's Avatar
      Sep 26th, 2005
      Shaw AFB, SC
      Corrado VR- Gt3582r
      09-01-2014 02:50 PM #176
      Just put these wheels on finally. Going to be transporting the car soon. Most likely not under it's own power due to unforeseen problems.
      After I get home from this work trip im going to adjust the suspension a little and roll & pull the fenders a little. I'm chalking the front right and back left clearance issues up to a poorly adjusted suspension. & the tires are old ones that have been on the wheels since they were on my other car. They'll be getting replaced.
      Wheels: SSR DeColte GP-0's, +54 offset.
      I'll have to measure the adapters. But they're huge.
      Coilovers. Cheapo's put on by previous owner.
      M.L.G Ridiculous in every aspect
      I live outside the box
    2. Junior Member MaxM97's Avatar
      Aug 11th, 2012
      Canton CT
      93 VW Corrado SLC
      10-11-2014 04:45 PM #177
      Does anyone know how an 18x8.5 et35 would fit? How would they look? I know most people say 16s are usually the best size for corrados. I was looking at a set of 3sdm 0.06 specifically.
    3. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat 97 Triple White New Beetle 2.5 6SP Auto (JUA)
      10-12-2014 07:16 PM #178
      Quote Originally Posted by MaxM97 View Post
      Yes, they'll fit. Only a 225/35/18 tire will work. Coilovers not needed for clearance. The rear may or may not try to peel the sidewall against the fender lip on the bigger bumps. This can only be eliminated by not taking the car to loowww or shaving the inside of the fender lip between the 10 & 12:00 area.
      ¡¡ opɐɹɹoɔ ǝɥʇ!!!ƃuıʇɔǝdsǝɹ !!!
      !! odarroɔ ǝht gnitɔepser !!
    4. Member Benstanczik's Avatar
      Apr 11th, 2011
      Ft. Myers
      Mk5 Diesel, VR6 SLC Corrado
      11-08-2014 04:11 PM #179
      Need some help here.
      I've got BBS RS 010's
      15X7 and 15X8 et 36
      Trying to figure out what adapter specs I would need
      I've been thinking 18mm front and 20mm rears?
      Any insight from someone?
      "You can drink lava, but only once"
      Corrado build
    5. Junior Member MaxM97's Avatar
      Aug 11th, 2012
      Canton CT
      93 VW Corrado SLC
      11-08-2014 05:56 PM #180
      I have et35s and run 15 front 18 rear and the rear rubs slightly.
    6. Member Benstanczik's Avatar
      Apr 11th, 2011
      Ft. Myers
      11-10-2014 02:18 AM #181
      Can you send me a photo of it?
      Corrado build
