Page 5 of 5 FirstFirst 1 2 3 4 5
Results 141 to 149 of 149
Thread: Wheel size, Rolling Pulling Fenders, offset, et, suspension, your moms horoscope
    Nov 19th, 2001
    Calgary, Alberta, Canada
    90 Corrado VR6 (build in progress), 2008 E90 M3, 2009 E88 135i
    11-15-2012 11:33 PM #141
    I am currently rebuilding a set of 3 piece rims and trying to determine how much my rim can go past the outside of my fenders without rubbing. I have rolled and pulled all four fenders. My current set up I want to run I have measured that the outside of the rim will protrude past the front and rear fenders by 3/4".
    Rim specs will be
    Front 17x8-1/2" et 14
    Rear 17x8-1/2" et 1
    Planning to run 215-40's all around
  2. Member cata's Avatar
    May 19th, 2006
    Canada eh
    11-16-2012 04:37 AM #142
    That's the size tire I want as well. The pros have recommended 8.0" (or 8.5" rim if you want the stretched look for some pointless reason). Ideal ET is 35.. with a rear fender roll
  3. Junior Member bunkkaws's Avatar
    Feb 7th, 2008
    Fairfax, VA
    92 Corrado SLC
    12-17-2012 04:57 PM #143
    Quote Originally Posted by 90radorotrex View Post
    Rim specs will be
    Rear 17x8-1/2" et 1
    I don't know how much poke has to do with rubbing vs tire size and how low you are!
    et1 is going to be a lot of poke. I am running 17x9 et 15 on pulled and rolled fenders and I have about 15 to 20mm poke. So poke will be close to mine if you do the math.
    oh yeah I am also running 215 x 40 on the 9 and have a 1 finger gap. It rubs on bumps, potholes at 30+ MPH
    .....vortex stalker extraordinaire.
  4. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    12-17-2012 05:37 PM #144
    i am currently rebuilding a set of 3 piece rims and trying to determine how much my rim can go past the outside of my fenders without rubbing. I have rolled and pulled all four fenders. My current set up i want to run i have measured that the outside of the rim will protrude past the front and rear fenders by 3/4".
    Rim specs will be
    front 17x8-1/2" et 14
    rear 17x8-1/2" et 1
    planning to run 215-40's all around
    lolol rub rub rub rub.
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  5. Member eurosportgti's Avatar
    Jan 15th, 2003
    Manchester, CT
    00' Jetta, 90 Non sunroof Corrado
    12-22-2012 10:12 PM #145
    Thats beyond rub.....i think u should remeasure and do a tiny bit more research and thinking
    Best way to get ahold of me is email....Eurosportgti@yahoo.com
    http://www.spoonfedtuning.com/
    http://www.centralctcoatings.com/index.html
    contact me for all powdercoating/ceramic coating/thermal barrier/sandblasting and glass beading needs
  6. Member corrado-correr's Avatar
    Jul 8th, 2004
    Royal Oak, MI
    04-08-2013 06:18 PM #146
    Wheel specs:
    BBS, RX II, 5x100, 16x7, offset 35mm
    Spacer or adapter specs:
    H&R 15mm front, 15mm rear
    Tire specs:
    BFG, G-Force Sports, 205/45/16
    Suspension:
    KW V1 Coilovers
    Brake Specs:
    Factory DE (11.3) brakes at all 4 corners with ECS slotted Rotors
    Body Specs:
    "Rolled Like A MoFo"
    Clearence Summary:
    Perfect
    ReliableSummerWheelsSLC by rrotsaert, on Flickr
    Raven
    92 Corrado VR6t
    93 Corrado SLC
    The DCC took urr jorbs!
  7. Member PinoyVR6's Avatar
    May 23rd, 2003
    Norwalk, CT
    90 Nugget Yellow Corrado, 2003 Jetta W>E
    04-09-2013 08:44 AM #147
    Subscribed
  8. Member ajhvw93's Avatar
    Oct 26th, 2009
    PA
    80 Rabbit Diesel....87 16V Scirocco...87 8v Gti..93 vr6 Corrado
    04-09-2013 01:16 PM #148
    Audi TT Fat Fives
    205/40/17
    OE Brakes
    VR+
    Koni adj.
    Neuspeed Race Springs 1.5 Drop
    Vr Fenders
    Rear rolled
    Does not rub
    (before rears were rolled drivers side back only would rub on big bumps)
    Walldoctor
    These cars are like women. You always have to make them happy... Other wise it will tend to f....k u in the bad way.
    Jul 22nd, 2011
    Vancouver, BC
    1991 corrado g60, 1994 corrado VR6
    05-13-2013 07:48 PM #149
    Wheel specs:
    Schmidt modernline 1-piece, 16x9 4x100, et25 front and et15 rear
    No spacers
    Tire specs:
    Falken 512, 205/40/r16
    Suspension:
    FK silver line plus dampening and height adjustable coilovers
    Brake Specs:
    Factory G60 brakes, oem rotors all corners
    Body Specs:
    Untouched G60 fenders
    Clearence Summary:
    Perfect, no rubbing
    Front angle:
    Rears:
