    Page 23 of 79 FirstFirst ... 131920212223242526273373 ... LastLast
    Results 771 to 805 of 2737
    Thread: Ask a VW Parts Guy....U.S. Version
    1. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:13 PM #771
      Quote, originally posted by socal07rabbit »
      Thanks.... still looking for the bumper parts though....
      Rear bumper cover GTI/Rabbit - 1K6-807-417-C-GRU (without park assist) $280.80
      Rear bumper cover GTI/Rabbit - 1K6-807-417-D-GRU (with park assist) $280.80
      Rear lower spoiler Rabbit - 1K6-807-521-C-9B9 $141.68
      Rear lower spoiler GTI - 1K6-807-521-E-9B9 $128.18
    2. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:14 PM #772
      Quote, originally posted by BurntGauge »
      Simple question
      Are the US GTI stock sideskirts (not the Votex ones, just the standard ones) the same length/size etc as the US R32 sideskirts?
      I know they are different part #'s b/c the US R32 sideskirts are smooth/not textured.
      Thanks.
      I have to assume they are the same. I ordered a set of R32 sideskirts and the customer has already installed them on his MKV GTI.
    3. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:24 PM #773
      Quote, originally posted by MkV395 »
      Never saw a price on the High-Def kit for the B6 Passat - painted to Candy White. Just the body kit, no wheels.
      Thanks! -Brendan
      This is not sold as a kit in color, only in primer. Color matched pieces are sold individually.
      Front- 3C5-071-609-RS-B9A $1065.63
      Sides- 3C5-071-685-RS-B9A $575.00
      Rear- 3C5-071-610-RS-B9A (non 4Motion) $1043.13
      One Piece Lip Spoiler - 3C5-071-640-RS-B9A $552.50
      Exhaust tips - 3C0-071-912 $221.14
    4. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:27 PM #774
      Quote, originally posted by vwzig »
      part # for the open GLI/GTI open honeycomb grille for the driver's side. might want to post #s for both sides incase anyone else is looking. thank you for all your hard work for everyone.
      LH- 1K0-854-661-M-9B9 $26.70
      RH- 1K0-854-662-F-9B9 $32.00
    5. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:28 PM #775
      Quote, originally posted by Justin W »
      OK, yes, but it is essentially an aftermarket part... because US dealers can't get them... because they are not a US part.
      I believe that places like OEMpl.us gets them from the part manufacturer - not VW.
      Yes, U.S. Dealers can get them. But the number in ETKa has a block off plate that you simple remove. (no dremil tools, just a couple of snaps).
    6. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-26-2007 04:32 PM #776
      Quote, originally posted by poops »
      Will the following Driver Gear Springs work for a 2007 4dr, 6MT GTI?
      Front spring number is 1KM-071-676HA, Rear spring number is 1KO-071-677VA
      Modified by poops at 4:12 PM 6-21-2007
      The part number for the set is 1K0-071-678-A
    7. Member Justin W's Avatar
      Jun 1st, 2001
      Los Angeles, Woodland Hills, CA
      13 GLI Autobahn NAV w/DSG, 08 Passat Wagon Turbo w/Tipt
      06-26-2007 05:27 PM #777
      Quote, originally posted by SoftballBud31 »
      What would we do without you?
      Thanks for clearing this up... sorry for the misinformation guys.
      Oct 5th, 2004
      Sterling, VA
      2K6 1K2 BRM / 2K8 7L6 BWF / 85 19 MF
      06-27-2007 01:07 PM #778
      What is the part no. of the rubber cap on the self-leveling sensor plugs?
    9. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-27-2007 01:43 PM #779
      Quote, originally posted by maloosheck »
      It looks like a piece called a grommet which is part number 6N0-906-102.
    10. 06-27-2007 02:24 PM #780
      I'm interested in this 20hp upgrade on the 08s and I'm hoping you can answer.
      I know that it involves intake and software changes, but I've received mixed messages as to the ability for current 2.5L owners (06/07) to get the power upgrade. I have an 06 rabbit, and I've been told that it would be impossible to get changes made at my dealership, but I've also read that it will be fairly easy to do.
      Can anyone give the definite answer?
      Thanks in advance
    11. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-27-2007 02:33 PM #781
      Quote, originally posted by Shorty Long »
      Thanks in advance
      I do not have a difinitive answer, but what I have heard is that the upgrade is not programming, but mechanical...larger intake, bigger valves. I will try to confirm this.
    12. 06-27-2007 04:24 PM #782
      I need a list of part numbers from the 2007 Jetta. I have the diagram below. I tried to search but I'm not sure if it was the same part that I want....
      1-Upper grille
      6-Frame moulding
      7-Lower outer right and left grill
      8-Lower grill centre
      9-Lower right and left moulding
      Thanks in advance!
    13. Member
      Oct 5th, 2004
      Sterling, VA
      06-27-2007 08:31 PM #783
      Thanks. Why vw made is so hard to find things like that
      Actually, I have another question: the bracket from the picture below in my Jetta has no spot for the self-leveling controller. Could you find out the part no. for the one with the spots to install the controller (GTI/GLI I guess)? I would be grateful for the drawing (I need to know how big it is and if the replacement requires taking out the whole dash board) and price.
    14. Member Sump's Avatar
      Jul 14th, 2006
      Chicagoland, IL
      04 R32 02 WRX
      06-28-2007 09:40 AM #784
      I can't find the part # on 1st vw parts, but its for the trunk cover in a GTi. I don't know the name of it but its carpeted and hangs from the back window. Privacy Cover maybe? Mine's mia
    15. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-28-2007 10:01 AM #785
      Any pic from the catalog will be pretty generic, but I will post it up and see if it helps you. When you say the self levelling sensor, are you talking about the Yaw Sensor?
    16. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-28-2007 10:07 AM #786
      Quote, originally posted by sump22 »
      I think most manufacturer's call it a package tray. There are two choices, one for vehicles with luggage net and one without.
      1K6-867-769-F-HH2 without luggage net
      1K6-867-769-G-HH2 with luggage net
      Both retail for $286.18. The second item listed does not come with a luggage net, in simply is set up to accomidate one.
    17. Member Sump's Avatar
      Jul 14th, 2006
      Chicagoland, IL
      04 R32 02 WRX
      06-28-2007 10:09 AM #787
      Sweet Jeebus. Hopefully the guy's house I left it at still has it. Thanks though.
    18. Member
      Oct 5th, 2004
      Sterling, VA
      06-28-2007 10:51 AM #788
      It is self-leveling (or headlight range or auto-leveling) controller (the sensors for this controller are at the suspension arms), located under the dash on the passenger side. Here is a link to the thread I was trying to locate it: http://forums.vwvortex.com/zerothread?id=3309542
      It seems it is installed in a slightly different way then Bentley describes, hence the whole research of the right bracket.
    19. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-28-2007 10:51 AM #789
      Quote, originally posted by GLI_girl »
      1-Upper grille
      6-Frame moulding
      Thanks in advance!
      Here is the pic from ETKA for a Jetta Front Grille:
      The part numbers are listed below by item# in the pic:
      #1 1K0-807-243-2ZZ (LEFT - CHROME)
      #1 1K0-807-244-2ZZ (RIGHT - CHROME)
      #3 1K0-853-101-2ZZ (CHROME)
      #4 1K5-853-653-A-9B9 (BLACK GRILLE)
      #5 1K5-853-761-A-2ZZ (CHROME)
      You may notice no number assigned to the grill inserts where the fogs are located, they are in a different catalog. The numbers for those inserts are:
      LH- 1K0-853-665-F-9B9
      RH- 1K0-853-666-F-9B9
      Center - 1K0-853-677-C-9B9
      Modified by SoftballBud31 at 8:25 AM 6-28-2007
    20. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-28-2007 11:19 AM #790
      Quote, originally posted by D_U_k_E_S »
      Hi there was wondering if u could help me find a gli skirt package for my 07 2.0t it's the texture one i have some part #'s maybe u could help me out
      Front 1k0805903b9b9
      Rear-1k5807521b9b9
      sides-1k5853859a9b9 left
      860a9b9right
      thx for your help and i hope the part #'s r the same as your's
      1K0-805-903-B-9B9 $152.72
      1K0-807-521-B-9B9 $163.37
      1K5-853-859-A-9B9 $49.98
      1K5-853-860-A-9B9 $49.98
    21. 06-28-2007 11:47 AM #791
      Greta thread thanks for all the help.
      I'm wondering if you can get a part number and price for the A-pillar trim covering the airbag on a 06 Jetta TDI in light grey? I scuffed it am wondering what I'm looking at to replace.
      Thanks
    22. 06-28-2007 11:59 AM #792
      Thx's
    23. 06-28-2007 12:32 PM #793
      did a quick search couldn't find much info.. with a 08 Rabbit or GTI with TPMS standard, would you have to get a 2nd set of TPM valves for a set of winter tires? or you can run a 2nd set of rims without em? if you have to get em how much are they a piece?
    24. Member Green Hare's Avatar
      Oct 20th, 2003
      7th VW... 8 others...
      06-28-2007 12:43 PM #794
      Definitely interested in this answer.
      Bud, did you find out about the parts I inquired about for the valance?
      ===== Mine: 2010 Black Golf TDI
      ===== His: 2006½ United Gray GTI
    25. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      06-29-2007 04:53 PM #795
      Quote, originally posted by Canadian_R32 »
      My understanding is if you don't mind the light, drive the car. Your other options would be to vag the car and turn it off. Buy a set of sensors, or swap them on and off ehich is a PIA every time you switch from winter to summer and back.
    26. 07-02-2007 01:53 PM #796
      so essentially if you don't want to spend extra $ drive with the warning light on in winter time or Vag it ... either way you won't have that function avail in the winter anyways.. if the sensors are relatively cheap I'd get a set though.. how much do they run?
    27. Member
      Jan 16th, 2002
      Southern NH
      2007 Altima, 2010 Forester
      07-02-2007 02:37 PM #797
      I need the part # for the mud guard on the underside of the front bumper (GLI). This is the full-width plastic guard that needs to be removed to change the oil. I broke mine in half somehow
      TIA
    28. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      07-02-2007 03:16 PM #798
      Part number for the sensors is 1K0-907-253-D and they retail for $72.19 each.
    29. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      07-02-2007 03:17 PM #799
      Quote, originally posted by Varrr6 »
      TIA
      The number for that splash shield is 1K0-825-235-AB and it retails for about $60.00.
    30. 07-02-2007 03:59 PM #800
      How bout the front driver side lower front wheel well splash guard?
      Burnt a hole in mine while testing out the FMIC w/o the bumper on.
    31. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      07-02-2007 04:58 PM #801
      Quote, originally posted by Arin »
      That has a two piece fender liner. Are you looking for just the front piece, or do you need both pieces?
    32. 07-03-2007 11:42 AM #802
      THanks a lot for all the help. I have a couple of questions regarding this.
      1-On the ETKA, the #4 item (1k5-853-653-A-9B9), the black grill, is there chrome on it? if not is there a part number for the one with chrome?
      2- Do you have the number of the lower side (left and right) grills with the fog insert?
      3- On the ETKA, part #3 (1K0-853-101-2ZZ) do you have one without chrome? Cause I'm probably going to color match it.
    33. Member
      Jan 16th, 2002
      Southern NH
      07-03-2007 03:33 PM #803
      thank you, sir!
    34. Member SoftballBud31's Avatar
      Apr 26th, 2006
      Huntersville, NC
      2013 Audi Q5
      07-03-2007 04:06 PM #804
      1) Yes, it does have vhrome as well.
      2) 1K0-854-661-M-9B9 & 1K0-854-662-F-9B9
      3) Sorry, it only comes in chrome.
    35. Junior Member d21bfish's Avatar
      Jun 22nd, 2007
      Coventry Rhode Island
      07' Volkswagen Rabbit
      07-03-2007 10:10 PM #805
      got a guestion...i have a 07 rabbit 2 dr. i tried to 2-tone my front emblem and within days i noticed it already chippied. so now i just want to go bak to the chrome and black. i was wonderin if i could buy that emblem from my local vw parts dept. at my dealership. and i was also wonderin if i can what is the p# and how much would it cost?
