Page 1 of 52 1 2 3 4 5 11 51 ... LastLast
Results 1 to 35 of 1808
Thread: THE OFFICIAL X-FLOW SWAP POST!!!!!!
  1. 03-31-2002 05:36 PM #1
    There are alot of vortexers looking for info on the X-Flow swap. I was in the same boat before doing mine, so I've decided to make an offfical detailed post about it.
    Here is the basic info of what I started with.
    1995 OBD1 X-Flow motor (no doner car) $200
    The motor was basic no alternator or tensioners.I had to buy/borrow/ and steal alot of parts. go with the buy and borrow methods if your not confident in your ability to steal
    What I needed
    Alternator (Must be A3) $200
    power steering pump and bracket (MUST BE OFF OF AN A3) $20
    Water pump bracket (MUST BE A3) $Free
    A/C Delete pully (I ditched the A/C) $16
    MAF ($50 for both Coil, and MAF)
    Coil
    New spark plug wires (A2 wirers wont work) $78
    Wire harness (engine and fuel rail) get the VAG harness if you can but its not necessary. $150
    Gaskets (might as well)
    38 inch V belt for the alternator. If you do the A/C delete use this belt! It wont fit exactly but it will stretch on. 38.5 will fit good for about 4 days then it will touch, put the 38 on and let it stretch. beleive me I have 60 dollars worth of belts in my car that I have to return. $20
    ECU Stolen (sorry ma!)
    General notes
    Radiator: You can use the stock radiator with this setup. eliminate the long tube from the overflow bulb to the upper radiator and get the one from the A3 that goes from the back of the block to the overflow bulb. simply cap off the open end on the radiator
    Buy a clutch: You might as well go ahead and do this while its out. get a flywheel too if you can I bought mine from qualityvwparts.com. I love it!
    wiring: This is where the problems are, when the old harness goes out and the new one goes in there are only 4 or so harnesses that are being switched. when that is done there will not be enough power to the comp to make it power up and run the car you will need to tap into some power supplies, Ill post up later and tell you what color they are
    Also, there will be some wires that you wont use hook up everything else that you know of. again this is one of those things that I will have to get back to you on I do know this off the top of my head:
    1. use the alternator wires from your a3 (red and a little blue) place a small slide on terminal on the end of the old herness and stick it onto the BOTTOM pin of the alternator simply cut thesmall blue wire on the A3 HArness.
    2. there is also a singl red/black wire next to the blue alternator wire on the new harness. put a spade termainal into the single harness and connect it to the starter, this is your starter turn on wire.
    The downpipe
    I have a 1992 GTI 8V I used the downpipe that came with my car and the exhaust mani fron the new engine no spacer was needed to make this work, maybe thats only an issue for CIS cars. Im not sure but Im just happy that I didnt have to buy one.
    Ill update this as I remember if there are any questions email me or IM me and Ill include them into this post. HAVE FUN!!!
    Here is the link to the pictures of the swap. Feel free to look at my other albums while your in there
    Modified by X-FlowA2 at 4:07 PM 6-30-2003
  2. Member IwannaGTI's Avatar
    Jul 12th, 2001
    Philadelphia, PA
    02 S2000, '68 Mini Pickup
    03-31-2002 07:35 PM #2
    MAS is MAF (Mass Airflow Sensor) Right?
    Quote Originally Posted by NHDUBN#2 View Post
    Like procreation the Internet should just not be done by some people.
    Quote Originally Posted by GTE77 View Post
    You're are'nt a bot are ya? I can see it in your eyes......You have.....LOVE.
  3. Member IwannaGTI's Avatar
    Jul 12th, 2001
    Philadelphia, PA
    03-31-2002 07:37 PM #3
    forgot to ask...what was ur parts total of all the stuff u listed below minus trans stuff
  4. 03-31-2002 08:01 PM #4
    Sorry MAF is correct. In total I spent roughly 600-700 bucks. A friend at your local VW dealership, Some other VW buddies, and doing the work yourself are almost a must. You dont need these things but it makes the swap harder and more expensive without them I posted prices above.
    I have pics Ill post the link a little later. Play by Play
    [Modified by ilovemy92gti, 5:09 PM 3-31-2002]
  5. 04-01-2002 01:57 PM #5
    nicely done matt
    now someone sell him a turbo
  6. Member IwannaGTI's Avatar
    Jul 12th, 2001
    Philadelphia, PA
    04-01-2002 08:16 PM #6
    whats it take to fit an obd2 engine? What on an obd 2 engine will work on obd 1 and vice versa?
    Thanks
    Matt
  7. 04-02-2002 12:49 AM #7
    OBD 2 works almost the same with the exception of the throttle body. Ive heard that there are some clearance troubles. you simply turn it over from what I understand. Ill ask someone. Oh yeah Ive poted the link to my site so that everyone can see how things went. Oh yeah and if someone is sellin a turbo let me know!
  8. Member sirhc's Avatar
    Sep 23rd, 1999
    29' Model A, 02' F350, 03' Land Cruiser
    04-02-2002 01:20 AM #8
    Are you sure? Not sure about swapping into a MkII, but I used all the stuff from my MkI for my swap. Just had to be a little creative with the pulley combination.
    Chris
  9. 04-02-2002 01:26 AM #9
    I have heard that the pully combo from a rabbit will do the trick. Im sure that there is more than one way to skin the cat but this is the way I did it. Plus I think in order to do the rabbit set up you need multiple pully's. I bought 1 pully and Im using 3 belts- the timong belt, a 38 inch serp. belt that goes from the crank to the waterpump and alt. and a pwer steering belt. How is yours set up? The Pwr steering definatly wont work from an A2, not too sure about the A1
  10. Member thf944's Avatar
    Apr 13th, 2001
    Firestone, CO
    VW
    04-02-2002 01:31 AM #10
    thanks for posting the list. i'm thinking of doing a 2.0 swap also. i would like to keep the ac though. is this hard to do on a 91 gti? also, if you are swapping the comlete motor, would you use all the accesories like ac and alt from the donor car or would you have to mix and match?
    thanks again for the info.
    thad
    Thad
    DCI - Rocky Mountain High
    2000 VW Golf GLS Indigo Blue
    1992 VW Golf GL Calypso Green
  11. 04-02-2002 01:36 AM #11
    The alt is a must. The bracket and alt from the A2 wont fit (clearance) Im sur A/C is a simple matter of plumbing although there is a trick to get it to work. Something to do with the housings, you have to make a hybrid thingy. I dont wanna speak on it because I want to give hard truth answers. Check around Ive seen a couple of posts that talk about what needs to be done to keep the AC.
  12. Member thf944's Avatar
    Apr 13th, 2001
    Firestone, CO
    VW
    04-02-2002 01:38 AM #12
    cool, thank you. btw, what do you think of your car with the swap? was it worth it? would you rather have a vr6 or 1.8t? or a neuspeed charger?
    [Modified by thf944, 11:39 PM 4-1-2002]
    Thad
  13. 04-02-2002 01:51 AM #13
    Im not looking at this for the "now" Im lookin a little further down the line.A VR6 is great but is beatable with a turbo. plus I like the handling that my car delivers, I wanted to keep that. 300 HP is forseeable with some serious work. Thats more than enough for me. But to answer the question, I love it and wouldnt trade it. The power band isnt as spiky as the 8V or the 16V motors. When you put the motor in dont expect to beat those hondas just yet, you will only have another 5 -10 HP. With a little work 150HP isnt that far away. Im getting a chip, 260 cam, and cam gear in about 3 weeks or so. I figure Ill be up into the 140's or so. Do it dude you will love it! ALSO-Get a new fifth gear. I was racing a honda and hit the rev limiter yeasterday (5500 I think) at 105 MPH, pretty embarrassing. but I have a 8V GTI Close ratio tranny. When are you gonna do your swap?
  14. Member thf944's Avatar
    Apr 13th, 2001
    Firestone, CO
    VW
    04-02-2002 02:12 AM #14
    i'm thinking sometime this summer to do the swap. i'm having trouble deciding which way to go. i'm looking for a max of 200hp. its my daily driver so reliability is an issue. i plan on getting another porsche 944turbo later on and will make that my fast car ( maybe 400hp ).
    i'm also debating whether i'll have a shop do it or do it myself.
    Thad
  15. Member thf944's Avatar
    Apr 13th, 2001
    Firestone, CO
    VW
    04-02-2002 02:24 AM #15
    here's what i've come up with so far (just estimates)
    vr6:$2200-3500=174hp stock + a little difficult to upgrade to 200hp but very do-able
    1.8t:$3000-5000=150-180hp stock + easy upgrades to 200hp
    2.0 x-flow: $400-800=115hp stock + neuspeed s/c $2400-2900=170hp, harder to get to 200 but lighter than vr6 and cheaper than 1.8t(slightly)
    this is not including labor if i have a shop do the work. the x-flow seems the easiest and the 1.8t the hardest and they are similar in wieght, the vr6 is more difficult than x-flow but easier than 1.8t but is heavier.
    well, it looks like the easiest way and almost the cheapest is the x-flow with s/c. plus i can do it in stages - engine first , then charger.
    Thad
  16. 04-02-2002 11:01 AM #16
    just remeber one of the main differences, between OBDI and OBDII...the dual O2 sensors for cleaner emmisions. You must use the OBDII downpipe for an OBDII swap...seethe second O2 sensor...
    here is a OBDII harness to 91 GTI fuse box pic, the red/yellow wires on the left should be plugged into the red three pin block thing thats plugs into the fusebox, or use the existing CE2 jumper wire with two red clips...they are not shown on this pic cause I couldn't find em at the moment :
    here is a pic of an OBDII harness I am going to use:
    Modified by PAGTI91 at 6:59 AM 2-21-2004
  17. Member sirhc's Avatar
    Sep 23rd, 1999
    04-02-2002 02:14 PM #17
    Keep in mind that I'm not running power steering or A/C, but here's a pic of my belt setup (not the best, but you get the idea). I mixed and matched pulleys and brackets till I found something that I liked.
    Chris
  18. 04-02-2002 02:40 PM #18
    oh my, looks like turbo and custom intake...I AM shaking
  19. 04-02-2002 03:24 PM #19
    I wanted to keep my A/c as well when getting the swap done. The A2 alt was used, but as you mentioned it is a tight very tight fit and the right belt selection is not easy. I didn't do the swap myself but if you need more info on it i can get you in contact with the guy that did do it for me, (offline) just e-mail me.
    This swap is good for the price. Tranny tops out at 115 getting my fith gear conversion done soon.
    i have a few pics in my sig.
    Good luck on the swap
    [Modified by ALpHaMoNk_VW, 1:32 PM 11-11-2002]
  20. Member IwannaGTI's Avatar
    Jul 12th, 2001
    Philadelphia, PA
    04-02-2002 05:01 PM #20
    can i use the obd2 downpipe with an obd1 set up?
  21. 04-02-2002 09:32 PM #21
    ALPHAMOK! I feel ya brother! mine stoped at 105 I think. My 5th is comming soon as well. Nothin like finding out when racing the rice.
  22. Member Estate's Avatar
    Aug 1st, 2000
    Portland, OR
    Many
    04-03-2002 12:36 AM #22
    Mmmmm, Nutty bars.
    Rob | A6 | GTI | Tiguan | JSW | Cabrio | Rabbit | 5+5
  23. Member
    Oct 12th, 2001
    Redmond, WA
    04-03-2002 12:39 AM #23
    ok I want to do this swap but now how do you change the x-flow to solid lifters, rather then hydraulic lifters? The reason to do that is to get a high reving fast car, hydraulic lifters max out at a certain RPM unlike the solid lifters, that can go on forever (well just about)
  24. 04-03-2002 10:01 AM #24
  25. Member sirhc's Avatar
    Sep 23rd, 1999
    04-03-2002 11:24 AM #25
    quote:
    That looks great all black like that.
    Chris
  26. 04-03-2002 01:37 PM #26
    I cant wait for the new 5th. Question that i do have though. How did you wire up the tach? (I am no DIY guro-pics help me best) I am still running with no tach
  27. 04-03-2002 01:52 PM #27
    I think so, too. But, it FEELS even better due to the fact that it is an SC
  28. Member
    Sep 15th, 2001
    The PNW
    '12 CW Golf TDI, 2013 Evil Undead
    04-03-2002 02:26 PM #28
    You can use the stock tach wire and put it onto one of the terminals on the power output stage. That's what I did and it's been working fine. I don't remember which terminal it is but you can check the wiring diagram in a bentley manual to see which one the tach was originally hooked up to.
    Later,
    Jason
    Lately I have been testing "tip-in events". Just the tip-in. Just to see how it feels. Response time is typically on the order of 2-3 seconds. Sometimes the injection timing is a little off...
  29. 04-03-2002 10:46 PM #29
    Im soooooooo jelouse. I WANNA A Super Charger!!!! The tach is something that I havent figured yet. What color is hte damn wire from the cluster?
  30. 04-04-2002 03:31 PM #30
    wait a sec...do you have to use the OBDII exhaust mani if you're doing a stand-alone system? i plan on going for broke (literally) and doing a custom turbo setup on mine, and i'm only beginning to comprehend what kind of b!tch this is going to be....but so much fun when it's over!
  31. 04-04-2002 05:22 PM #31
    depends how your stand-alone reads the O2 sensor(s). If it needs two O2 sensors I would get the OBDII downpipe...
  32. 04-05-2002 03:09 AM #32
    So the crossflow engine harness plugs into the A2 fusebox with no problems? How about on the A1 chassis?
  33. 04-05-2002 08:07 AM #33
    to the CE2 A2's! Like 90 and up. You have to splice into the A1...
    [Modified by PAGTI91, 5:09 AM 10-26-2002]
  34. 04-06-2002 09:49 PM #34
    New questions from me (posting under friends name i am really iwannagti)
    Do i need new motor mounts? Or can i use the existing ones?
    Do i need any special tools for the swap?
    Where do i get a MAF cheap?
    Where do i get a harness cheap?
    I Already have an ecu lined up its from a 94...will that work with an obd1 system?
  35. 04-07-2002 03:53 PM #35
    The comp will work fine
    You can use your motor mounts, but you must use the back bracket from the A2 motor.
    You can get a MAF from somebody on the vortex or your local Junk yard
    No special tools are needed, but you must have tools. Air tools are a great asset to the project, almost nessesary
    Did I answer the questions?
