Hope you swapped the tie rods too, they are different between manual and power.Part numbers from ETKA as follows,
for '87
shaft for manual, 171 419 951 C
shaft for power, 175 422 951 A
shaft for power with air bag, 155 419 947I have no idea why an air bag shaft was included in '87 listings, but it was.
I checked a few other possibilities, Scirocco shafts are not an option, different part numbers.
Rabbit numbers for U.S. produced cars are identical to those for Cabriolets, Plenty of those in CA junkyards, same in OR?
Got pics of your VoltsCabby?? Or is it a Cabriolect?
Modified by tolusina at 11:01 PM 1-29-2007
I also don't have enough power on tap to run the pump from the 12V system.
