Page 13 of 67 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 23 63 ... LastLast
Results 421 to 455 of 2315
Thread: VR6 coilpack atlernative
  1. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-13-2007 06:31 PM #421
    Yea, I wrapped mine completely in tape and eventually it burned itself out on a really hot day
  2. 06-13-2007 10:03 PM #422
    For what it's worth, I believe Cubix used the radio shack resistor.
    The MSD or Accel resistors are much larger and can therfore handle
    more heat, but def. don't wrap it either way.
    Modified by jamesn67 at 10:06 PM 6-13-2007
  3. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-14-2007 12:31 AM #423
    Thats correct, I am using the Radio Shack resistor
    BTW, I'm selling my car, hit me up for info
    Time to get started on jetta the third
    edit:
    er... was using the radio shack resistor
    still not using one
    3200 mi+
  4. Member
    Dec 30th, 2005
    2002 Jetta VR6 5-spd
    06-14-2007 02:05 PM #424
    Ive been following this since the original thread. We had a CEL last week. VW dealer tells us we need another coilpack and wires (at $900)!
    This will be the cars 4th set if we replace it: original/factory, 2nd set at 38K miles (under warranty), 3rd set at 54K miles (only 14 months after 2nd set!, got 50 percent back from VWoA after some fighting), and now we have 79K miles and only 18 months on the current (3rd) set. Dealer says misfire willl ruin the Cat Cons.
    Im not sure Im ready to go for a complete aftermarket solution but am looking to less expensive alternatives to the dealer. Im sure I can R/R the coil and wires myself. Ive been looking online and found several places that list the coil (VW 021 905 106 C) and wires (VW 021 905 430 DA thru DF). Im not sure if there is a VW part number for a wire set? Id like some feedback on an ad I saw at Ebay for the coil and wires - Im not sure if I posted the link if that violates the thread rules. Please let me know.
    Thanks,
    Paul
  5. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-14-2007 03:25 PM #425
    First of all, 900 is ridiculous
    You can get OE wires from Fourseasontuning.com and a coil pack (OE) from Rennen.us, that'll be about ~350
    I can't see why you'd need to replace it so often, thats pretty crazy.
    Find someone in your area to scan your car. and don't take it to that deal again. I mean, if you are replacing with OE, you can do it in all of 30 minutes with 1 allen key and the spark plug wire remover, anyone can do it, seriously.
    If your coil is blowing so much, maybe its time to do this alternative
  6. Member kevwithoutacorrado's Avatar
    Jun 9th, 2000
    OREGON
    93 SLC, 07 Legacy GT, 93 YJ
    06-14-2007 04:20 PM #426
    When the same part breaks over and over....IT'S NOT THE PARTS FAULT....that dealer should be figuring out what is causing the coil to break...not just replacing it...
    Sep 8th, 2005
    Pahoa, HI
    1995 GTI VR6, 1992 Jetta Carat
    06-14-2007 04:33 PM #427
    $900?!
    are they replacing your wires too every time? if they are your getting definitely screwed cause wires dont fry like that even if your coil blows. one of my vr has 95k and factory wires were perfect while its coilpack was disintegrated with peices of it chipping off.
    I even question your coil blowing that frequently. I know they are ****ty but one of my vrs has the stock coil at 90k and it still goes. I had to jb weld some cracks tho. there must be something electrical causing your ICM on the coils to blow or something like that....
  8. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    06-14-2007 08:27 PM #428
    Quote, originally posted by kevwithoutacorrado »
    x2.
    that is not a coil issue. its something else. plugs perhaps?
    Dec 30th, 2005
    06-14-2007 11:36 PM #429
    Quote, originally posted by Cubix »
    Thanks for the reply. We know the dealer is ripping us off but they are ALL crooks. That is how they make a ton of $$$. They just built a brand new building for their dealership. Taj Mahal. We know we are paying for it. They say the CEL we had was the misfire code and that the coil is cracked and arcing. Its my wifes car and its not that she will not allow me to install an aftermarket setup, its that I do not feel comfortable with her driving a car in the city (Boston) with a setup that is not stock and may or may not be reliable...
    So I feel the best alternative is to R/R the parts myself using stock replacements and shop for best price. Did I read somewhere that to R/R the coil I need to remove the battery cover and thats a PITA? Also why would I need a spark plug wire remover - the wires we have have the little handles on them.
    Perhaps this is a question for the moderator:
    I found an 'OEM' coil (Beru) and wire set (Bremi) listing on Ebay for $319 shipped - can I post a link to it for feedback?
    Thanks,
    Paul
    Modified by mwr02jetta at 11:40 PM 6-14-2007
  10. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-15-2007 12:45 AM #430
    Best thing to do would probably start up a new thread so we can keep this one on topic.
    You can PM me the link, and I'll tell you about the auction
  11. 06-15-2007 10:46 AM #431
    And for what it's worth, several companies won't stock the Beru coil pack because of failure issues.
  12. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-15-2007 12:17 PM #432
    Really?
    I thought Beru was one of the better quality coils
  13. 06-15-2007 02:41 PM #433
    Just a warning to everyone, make sure you wrap/heatshrink the terminals coming out of the ICM. Mine rubbed against the bracket (took a couple of weeks to wear off the powder coating) and shorted one of the outputs to +12V and killed my ICM. Got a used ICM and it's working again.
    Next step, regapping the plugs.
    Clayton
  14. Member
    Dec 30th, 2005
    06-15-2007 02:53 PM #434
    Ok,
    At this point we have pretty much decided to replace only the coil. I still need to know if I need to remove the battery box to get the coil out. Do I need to remove anything else?
    One more sort of off topic question: Who actually is the manufacturer of the stock VW coil? Ive dissassebled one that was replaced at the dealer (I had requested the VW dealer to give it to me). There are three main parts: the coil(pack) itself, a cast aluminum spacer, and the IDM. There is also a small plastic 'cover' over the terminals between the IDM and the coil. The coil has 'BERU' molded onto the bottom of it, the IDM has 'TELEFUNKEN eletronic' molded into the top of it, and the little plascic cover has 'TEMIC' and the part number '021 905 106C' molded on the outside and 'BERU' molded on the inside. I know 021 905 106C is the VW part number for the entire 'coilpack' assembly.
    Based on the 'BERU' marking next to the main part number (on the plastic cover) I would say that BERU is the manufacturer, but who is 'TEMIC' and 'TELEFUNKEN electronic'?
    Ill bet when I buy the 'Beru' part the only difference from the VW part will be that the little plastic cover does not have the VW part number on it. That and the fact that the VW dealer gets $530 for the part and I can buy the BERU part for $249 shipped.
    Thanks,
    Paul
  15. Member bwolfgti's Avatar
    Oct 28th, 2002
    iowa
    02 gti 1.8t
    06-15-2007 03:22 PM #435
    No you don't have to remove the battery box. Just the plastic engine cover over the coil pack and then only 4 screws holding the coilpack to the motor. It is real easy to do and can be done in 20 minutes or so.
    Keep your old icm. you can sell that to someone on the vortex im sure.
  16. Member
    Dec 30th, 2005
    06-15-2007 04:31 PM #436
    Quote, originally posted by bwolfgti »
    Thanks,
    And after I replace this coil I will have TWO old ICMs.
    Paul
  17. 06-15-2007 04:36 PM #437
    So yours was one that was made out of steel?
  18. 06-15-2007 05:42 PM #438
    Aluminum, it's the one from 4seasonstuning. I should have used heat shrink the first time, I know better.
    Clayton
  19. 06-15-2007 07:37 PM #439
    Yeah, I also coverd my bracket with the plasti-dip spray stuff as an
    extra precaution.
  20. Member
    Dec 30th, 2005
    06-15-2007 08:37 PM #440
    Do I need to remove the entire engine cover (covers?) or can I just remove the part over the coil?
    Thanks
    Paul
  21. Member bwolfgti's Avatar
    Oct 28th, 2002
    iowa
    02 gti 1.8t
    06-16-2007 12:17 AM #441
    you will have to remove the cover that is nearest the throttle body and the center cover that says dohc vr6 on it along with the one covering the coil. I think it is only 3 screws that hold them all on.
  22. Member Shikaroka's Avatar
    Dec 12th, 2002
    Charleston, WV
    06-16-2007 08:40 PM #442
    I think you may be thinking about a MKIII.
    MKIVs have 3 plastic cover peices. You will have to remove all of them, but it's easy. The small on on the passenger side and the small one with the "VW" symbol hold down the main one in the middle. And, you'll have to remove that main one to get to the coil pack.
  23. Member
    Dec 30th, 2005
    06-16-2007 10:53 PM #443
    Quote, originally posted by Shikaroka »
    Thanks,
    I found a DIY that showed that you need to remove those covers to change the spark plugs too. Is that right?:
    http://forums.vwvortex.com/zerothread?id=1792683
    Paul
  24. Member Shikaroka's Avatar
    Dec 12th, 2002
    Charleston, WV
    06-17-2007 10:15 AM #444
    Pretty good DIY, but I don't really think you need to remove the covers to change the spark plugs.
  25. Member vr6freak's Avatar
    Apr 4th, 2003
    Rentin
    Purple. RWD. Boosted
    06-21-2007 03:00 AM #445
    whos car is this? or anyone else running this coil pack
    PM me with your Garrett Turbo and TiAL needs
    www.wideopentuning.com
  26. Member Cubix's Avatar
    Jul 26th, 2002
    Bensalem, PA
    06-21-2007 11:05 AM #446
    Thats the GM coilpack
    should be discussed early in the thread
  27. 06-21-2007 11:23 AM #447
    magnavox coilpack used on grand nationals to be more specific, and a few other fwd buicks as well
    Modified by 708VR6 at 1:22 PM 6-21-2007
  28. Member vr6freak's Avatar
    Apr 4th, 2003
    Rentin
    06-21-2007 02:04 PM #448
    Quote, originally posted by 708VR6 »
    magnavox coilpack used on grand nationals to be more specific, and a few other fdw buicks as well
    right i just received mine.
    the wiring looks as if it will need to be different than regular msd packs.
  29. 06-21-2007 02:24 PM #449
    Quote, originally posted by vr6freak »
    I could kick myself, some lady was selling a brand new one on ebay for $10 and I passed on it... oh well maybe next time
  30. 06-21-2007 09:21 PM #450
    Thanks to all who have helped me with this swap. Heres some pics of my setup.
    Modified by DJP944 at 6:23 PM 6-21-2007
  31. 06-21-2007 09:40 PM #451
    how bout some feedback? how does she run now?
  32. 06-22-2007 09:37 PM #452
    she runs like a beast- aka ferrari f50....nah hahah but the spark timing is perfect gapped at .40
  33. 06-22-2007 09:47 PM #453
    Quote, originally posted by DJP944 »
    sweet..oh wait! wheres the biga$$ wing?
  34. 06-23-2007 10:29 AM #454
    looks like the accel one to me
  35. 06-23-2007 10:53 AM #455
    Quote, originally posted by sinisterh22a »
    accel & stock look identical, still a magnavox style coilpack
