Results 1 to 9 of 9
Thread: Vacuum Reservior Relocation?
  1. Senior Member bluefox280's Avatar
    Dec 17th, 2003
    Westminster, CO
    02-08-2007 11:54 PM #1
    For you 1.8T owners, where do you relocate the vacuum reservior on the valve cover?
    I want to omit it, but can't since it's psuedo-critical to the vacuum system.
    - Erik
    Pattern Draft Imaging.com - "...Where Engineering Discipline and Photography Merge as One..."
  2. Member euro-steez's Avatar
    Oct 25th, 2003
    Georgetown, On
    02-09-2007 12:04 AM #2
    I have seen a few on the drivers side fender, mind you they were running CAI which allows more room.
    I've been thinking of where to move it also.
  3. 02-09-2007 12:21 AM #3
    No need to relocate what so ever. Just take it off and cap the tube. Neen running for 10,000 without probs. IM for questions of pics.
    Search vacuum res for info threads
  4. Senior Member bluefox280's Avatar
    Dec 17th, 2003
    Westminster, CO
    02-09-2007 08:53 AM #4
    Quote, originally posted by Sketchykid »
    Odd; I checked the archives...
    » No Results Found
    Your search for vacuum res returned no results.
    Please try different search criteria or a different data set.
    Did find some results with "vacuum box".
    However, I'm not wanting to bypass the N249 (DV) valve...
    And what the DV to properly work.
    Sketchy, what's your take on the set-up with that modification?
    - Erik
  5. Banned
    May 20th, 2004
    02-09-2007 08:59 AM #5
    My car runs 1000x better without the silly n249. After that was bypassed, the vacuum canister was promptly removed. Been running like this for 2+ years now, not a single problem.
    I have the DV running off a T from the FPR line, same as my boost guage.
    Modified by vengeance18t at 9:01 AM 2-9-2007
  6. Member SHUMopper's Avatar
    Jan 2nd, 2002
    Long Island
    2008 Touareg V6, 2011 A3 TDI
    02-09-2007 09:04 AM #6
    i relocated my vac reservoir to the garbage can.
  7. Senior Member bluefox280's Avatar
    Dec 17th, 2003
    Westminster, CO
    02-09-2007 09:09 AM #7
    Quote, originally posted by vengeance18t »
    With the removal and vacuum bypass, you're not concerned of the DV reacting to "slow" to open when the throttle is lifted?
    And the car doesn't fight back at ya'?
    I was reading up on the archives in the 1.8T forum and there were mixed reviews.
    - Erik
  8. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    02-09-2007 09:16 AM #8
    SAVwKO should be able to help you with this.
    http://forums.vwvortex.com/zerothread?id=2901711
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  9. 02-09-2007 12:00 PM #9
    I still have all the valves and elevtronics set up. Its my understanding that the vacuum res is present to allow the n249 to open the diverter valve whenever it wants. this leads to a surging prob somtimes.
    you can sort of see the hard line on the right with a rubber cap and hose clamp on it. Only pic i have.
