Results 1 to 19 of 19
Thread: Cannot Clear Airbag Light from a Crashed Cluster
  1. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    02-12-2007 02:13 PM #1
    I have a cluster from a mk3 that was in an accident and the front airbag(s) were deployed and put it in my mk3. The airbag light is on and I cannot clear it with Vag. When I scan or go into the airbag controller there are no errors or codes. The light goes off but as soon as I exit the controller the light comes back.
    What do I need to do to clear the airbag light?
    Thanks
  2. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    02-12-2007 02:28 PM #2
    Is the airbag control module new, if so is it already coded? You may want to post a complete Auto-Scan.
  3. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    02-12-2007 03:42 PM #3
    The only thing I changed was the instrument cluster (97 jetta)
    Where would the airbag conrol module be?
    I can post my results from a vag scan, but there were no codes or errors from the airbag controller, I did include airbags in the AutoScan.
    Thanks
  4. Forum Sponsor Uwe's Avatar
    Jan 16th, 2000
    Lansdale, PA
    Too Many
    02-12-2007 04:38 PM #4
    It's possible your "new" instrument cluster is defective or simply not compatible with the airbag controller in the car.
    Unfortunately, Mk.3 clusters are not diagnostics-capable. Still, it couldn't hur to post the part numbers from both the original and the new cluster.
    -Uwe-
    VCDS® -- Satisfaction guaranteed or double your fault codes back!
    I reserve the right to be a prick if people make unreasonable demands.
  5. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    02-12-2007 10:36 PM #5
    VAG-COM Version: Release 512.4-D
    Monday,12,February,2007,11:44:41
    Chassis Type: 1H - VW G/J/V Mk3
    Scan: 01 02 03 08 12 15 25 41 56
    Address 01: Engine
    Part No: 037 906 259 E
    Component: MOTRONIC M5.9 HS V09
    Coding: 00004
    Shop #: WSC 00066
    3 Faults Found:
    16826 - EVAP Emission Control Sys: Small Leak
    P0442 - 35-00 - -
    16556 - Fuel Trim; Bank 1: System Too Rich
    P0172 - 35-10 - - - Intermittent
    00750 - Warning Lamp
    31-00 - Open or Short to Ground
    Readiness: 0000 0000
    Address 15: Airbags
    Part No: 6N0 909 603 D
    Component: AIRBAG VW2 V00
    Coding: 00068
    Shop #: WSC 00066
    No fault code found.
    End --------------------------------------------------------------------------------------------------
    Here is the part number from my original cluster:
    1HM 919 910D
    1 812 012 0588
    Thanks
  6. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    02-13-2007 10:04 AM #6
    Quote, originally posted by tjm0852 »
    Please update to a current version of VAG-COM.
    Here you go... Obviously there is something wrong with your wiring...
  7. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    02-13-2007 10:35 AM #7
    Quote, originally posted by Theresias »
    The wiring in the car is OK, well it works fine with 2 other speedo's(no airbag light) so I imagine your refering to wiring inside the cluster?
    I know the CEL bulb is burnt out perhaps that is the warning lamp open or short.
    I will update to the most current verison.
  8. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    02-13-2007 12:11 PM #8
    I'm getting to a point where I think the new cluster is incompatible. Back in the time when I retrofitted an MK4 cluster in my MK3 we noticed that the actuation of the airbag warning lamp differs based on the model year of the car. To confirm, please post the part numbers of all cluster you tried and also note which worked and which not.
  9. 03-01-2007 05:08 PM #9
    FWIW - I have the same problem. I swapped to a 97 cluster in my 96 and the exact same thing happened. For now, I have the airbag light pulled from the cluster...
  10. 03-03-2007 10:20 PM #10
    I tested a good 98 GLX VR6 cluster in my 96 GTI VR6. Both cars were 5 speeds and both clusters worked correctly in their respective original applications (the 98 GLX was a rear crashed parts car so it could not be driven to see if the speedo/odometer really worked properly). But the 98 GLX cluster airbag light worked backwards when I tested them with my VAG1552. What is the model year of the cluster you are trying to use? I also think that the clusters are incompatible.
  11. 03-03-2007 11:53 PM #11
    My car was built 1/96 and the cluster part number was 1HM 919 930FI. The cluster I put in it was dated 5/1/97 with part number 1HM 919 930 T
    Feb 13th, 2001
    Boston
    2001 Passat Wagon FWD V6, 2012 Touareg Lux
    03-05-2007 08:26 AM #12
    If you were in a crash and even just one airbag was deployed, you MUST replace the airbag control module and recode it.
  13. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    03-05-2007 10:05 AM #13
    Quote, originally posted by gwebel »
    As you can see in the above scan the control module is OK and coded.
  14. 03-05-2007 11:14 AM #14
    Between the 96 model year and the 98 model the A3 G/J airbag control module design was changed sufficiently to prevent interchangeability. I wonder if that is part of the reason that the airbag light remains on for swaps (or works backwards with the VAG 1552 scan tool).
  15. 03-05-2007 08:54 PM #15
    I was talking to the guy that I bought my car from and he said that there was an issue with the VAG-COM and you should never do the airbag diagnostics on the car or it would cause the airbag light to be permanently on. He said they used to have warnings right on their website that said not to do it???
  16. 09-09-2012 09:50 PM #16
    I know this thread is old, but I have experienced the same thing with 2 1997 Jettas when trying to install three different 98 manufacture date clusters. Bentley schematics seem to indicate I should be able to do this, but the airbag light works exactly backwards- on when it should be off, then turns off when it should be on, such as when scanning with the Vag-Com. I would greatly appreciate any thoughts on resolving this issue. There are no fault codes stored in either car's airbag module, and the light works correctly in the one car when replaced with the original cluster. Thanks!
    Ray
  17. 09-12-2012 11:31 AM #17
    Quote Originally Posted by rayvwbug View Post
    Ray
    As I posted above I believe the part number change between the 96 and 97 model year versus 98
    indicates that the swap is incompatible. I do not believe there is an error in the airbag system as I have repaired many VW and Audi cars with deployed airbags--just incompatibility between model years I/P clusters.
  18. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    09-12-2012 08:39 PM #18
    Quote Originally Posted by Peter Badore View Post
    I agree. I've seen a few cars, typically used car lots that purchased auction cars with unknown history, with this issue. New and remanufactured clusters were still available at that time but it could be difficult to simply order a direct replacement now due to the age of the vehicle?
    Based on memory alone I believe the Airbag light bulb sockets moved a few times over the years making the actual location inside the cluster vary and some of the really old Mk3 models had that lamp above the headlamp switch instead of the cluster at all.
    Dana Marie
    P.S. No Scan = No Soup
  19. 09-29-2012 11:56 AM #19
    Thanks to both of you. I have accepted the "reverse light phenomena" as something I will live with, or at least until I can find a 1997 manufacture date cluster.
    Ray
