Page 3 of 14 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 462
Thread: ***1.8T Intake Manifold Test Results***
  1. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    Seat Ibiza Cupra 1.8t,Audi S6, VW Lupo 1.8t, 16v Scirocco
    02-27-2007 03:36 PM #71
    Quote, originally posted by axlekiller »
    Yes, #1 is closest to the throttle. Lower numbers on 007's in runner #4 are from the taper of the plenum. Once again, under pressure, runner #4 won't suffer from this.
    thanks for clearing that up
    GT35R, Full-Race, DTA S60, SEM, WMI, 8 injectors, SQS Transmission, 1000kg car, >500bhp, Racecar (circuit)
    www.badger5.co.uk
  2. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 03:46 PM #72
    Quote, originally posted by petesell »
    can anyone speculate at what power levels the stocker runs out of breath in order for these manis to have a reasonable cost/benefit ratio? has there even been a back to back dyno with just a manifold swap on a BT setup?
    good thread
    i did a back to back on mine. before was a dual plenum largeport std tbody, then 007mani with R32 tbody
    gains 30bhp & 22lbft from same boost
    www.badger5.co.uk
  3. 02-27-2007 03:56 PM #73
    Quote, originally posted by badger5 »
    Unfortunately the dyno you've mentioned and its results have no data on how they were compared to a OE manifold.
  4. Member IFIWASINMYVW's Avatar
    Mar 20th, 2006
    '05 BMP GLI and '11 F25 X3 GONE: '82 Quantum, '96 Trek, '04 A4Q, '84 Rabbit
    02-27-2007 03:59 PM #74
    What happened to USRT, or did I miss somthing?
  5. 02-27-2007 04:24 PM #75
    It was against a modded intake.
  6. 02-27-2007 04:31 PM #76
    Yea, but I think i get what Stu is getting at... theoretically based on the flow data... a stock largeport OEM intake manifold my have flowed beter than the 'dahlback style' aftermarket one.
    So gains may have been greater, or they have have been less if compared to an OEM stock largeport.
  7. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 04:44 PM #77
    Quote, originally posted by Boostin20v »
    thats right. it gave gains over a dual plenum largeport on stock throttle body, which in turn should have been better than stock itself.
    gains are gains tho my friend.
    www.badger5.co.uk
  8. 02-27-2007 04:47 PM #78
    Which has nothing to do with the question asked, about a comparison of an OE manifold to an upgraded manifold:
    good thread
  9. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 04:48 PM #79
    Quote, originally posted by turbotuner20V »
    yea except DB aint largeport and never will be and my dual plenum was largeport (lower section was stock laregport runner so injector shrouding would'nt be ideal) and upper section was radius air horns and dual plenum.
    On a previous 435whp motor it gave an additional 32bhp/22lbft which is the back to back test I held out to do.
    Props to monstor for making it.
    does what it says on the tin for me.
    www.badger5.co.uk
  10. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 04:49 PM #80
    lol @ you lot
    GAINS.... real ones on an actual engine!
    www.badger5.co.uk
  11. 02-27-2007 04:50 PM #81
    whoa.. those were the gains on the duel plenum custom manifold before swapping on the 007 and gaining MORE power?
  12. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 04:51 PM #82
    yep agreed...
    will never know as the dual plenum i ran has never been flowbenched and has since been sold on.
    happy with the 007 results myself... on my real engine and actual figures recorded before to after.
    www.badger5.co.uk
  13. Member badger5's Avatar
    Nov 17th, 2003
    nr Glos, UK
    02-27-2007 04:53 PM #83
    if i think i understand what you said.. (its late here) the +32bhp/22lb were from my previousl dual plenum mani going to the new 007 mani big port on r32 tbody.
    the motor was never tested on stock mani as there is'nt a largeport manifold for my motor (TT style mani on my seat ibiza)
    www.badger5.co.uk
  14. 02-27-2007 04:55 PM #84
    the motor was never tested on stock mani as there is'nt a manifold for my motor (TT style mani on my seat ibiza)
    oh, ok... i thought you had a 32bhp gain going from a stock oem manifold to the custom dual plenum... then gained even more power going from the custom dual plenum to the 007.
  15. Former Advertiser
    Aug 26th, 2001
    02-27-2007 05:16 PM #85
    Quote, originally posted by silvercar »
    I believe brett@apr designed the APR unit.
    any of you fellas care to chime in on areas you feel are victory or defeat?
    I did indeed design the APR manifold. First let me say that the efforts of all those involved should be applauded and I also applaud everyone that designed and/or produced a manifold for the test.
    My design, the APR unit, was engineered for the absolute best performance running on an engine. I compromised as little as possible in an effort to realize this objective. I did place the throttle body in a location that was most logical for the applications that this unit would see and I did utilize the factory injector seats (for several reasons.)
    The APR manifold was not designed to win a flowbench test such as the one performed (although our unit performed admirably.) As any engine designer worth his weight in salt would tell you, what is optimal on a flowbench and what is optimal on an actual engine are very different. There are several 'dynamic' design considerations on our manifold that would never be measured on a flowbench test. For starters, our plenum is large, does NOT taper, and extends beyond the last runner (I would have extended it even further if I had room.) This is critical. As an intake valve opens, the air velocity surrounding the runner gets high very quickly. This has a tendency to create low pressure in the runner. The runner needs access to higher pressure air as readily as possible. The best way to do this is to utilize a large plenum and make sure that the plenum has volume surrounding all sides of each runner inlet. THIS BECOMES EVEN MORE CRITICAL ON TURBO APPLICATIONS AS INTAKE MANIFOLD PRESSURE INCREASES. In simplified terms this is why the best manifolds are designed this way. Look at the plenums on this engine (Audi R8) ->http://gallery.audiworld.com/a...l.jpg A tapered plenum in a boosted application will have progressively worse flow as you move further down the taper (the runner on the end will be very lean.) This WILL NOT be evident on a flowbench test (in fact a flowbench test will likely show flow as nice and even.)
    This is completely counterintuitive to what someone would think would be optimal by watching a flowbench all day and that's because engines do not operate like a flowbench. Based on the designs that I see here, I would expect the APR manifold to outperform every manifold here in actual engine performance (in fact, I believe it has already proven this as I have not seen any performance figures close to the gains that people have been making on our manifold.) I would expect the HOMEBREW manifold and RMR to be close seconds.
  16. 02-27-2007 05:26 PM #86
    Quote, originally posted by Brett@APR »
    If the manifold is installed on a car, would it be possible to determine if there is a lean condition based on the timing pull for that cylinder?
  17. Former Advertiser
    Aug 26th, 2001
    02-27-2007 05:46 PM #87
    Possibly. The degree to which the condition will occur is relative to the amount of taper and overall area. I don't mean to imply that a tapered plenum is going to be dangerously lean, it's just not the optimal plenum design for an actual turbo engine. The main plenum should be big and open on all sides (a mini atmosphere if you will)- especially on a turbo car.
  18. 02-27-2007 05:51 PM #88
    I would love to reply to this, but I am not supposed to.
  19. 02-27-2007 05:54 PM #89
    Quote, originally posted by monster007 »
    Why not? I would like to hear this response as well
  20. 02-27-2007 05:56 PM #90
    cool, well I'll just keep an eye on my a/f, timing pull and knock voltages. They've all seemed ok so far.
    Any reason why people w/ high power 6cyl 2jzte supra motors would use this design then. I'd imagine the 5th and 6th cyl would be even worse off?
  21. Former Advertiser
    Aug 26th, 2001
    02-27-2007 05:56 PM #91
    Why not? I would like to hear it!
  22. Banned
    Jun 24th, 2004
    02-27-2007 06:01 PM #92
    He's not an advertiser so his posts will be deleted.
  23. 02-27-2007 06:17 PM #93
    Quote, originally posted by fast_a2_20v »
    it's a technical discussion, not an advertisement. let them go at it...professionally of course.
  24. 02-27-2007 06:22 PM #94
    Quote, originally posted by mirror »
    x2
  25. Former Advertiser
    Aug 26th, 2001
    02-27-2007 06:23 PM #95
    Absolutely there is a reason. For one it works well on a flowbench and many people make the mistake of designing off what works on a flowbench. Good engine designers know where a flowbench can be used properly and where the results must be taken with a grain of salt. I am sure that there are some tapered plenum manifolds used at some very high levels of racing. This does not mean it is a good design. I gave an example of a non-tapered manifold used on the Audi R8. This is also just an example and does not mean it is necessarily the best design. And I am certainly not saying that a tapered plenum manifold should be thrown out with the trash. What I am saying is that a tapered plenum is not the optimal design for a turbocharged engine. This does not prevent it from being used all over the place in the automotive performance aftermarket. Since I was posed with the job of designing the best performing manifold for the 1.8T engine that we could I utilized the best design principles that I knew of, not what necessarily was the most popular. (Let's face it, my design looks kind of boring but the results speak for themselves.) Several of our stage 3+ customers have reported over 45 hp at the wheels and a 280-300 RPM reduction in boost onset RPM with the addition of the manifold/throttle-body assembly alone (and widened ports.)
    Also let me reiterate that I have the utmost respect for the people involved in making and testing all of the manifolds here. ESPECIALLY the guys that don't own companies and designed or produced it themselves. I am not trying to get in a pissing match, I just wanted to point out some technical aspects of the manifolds and of course these are just my opinions.
  26. Former Advertiser
    Aug 26th, 2001
    02-27-2007 06:23 PM #96
    Quote, originally posted by SloJTI »
    x2
    x3. I'm cool with that. (Although I really need to be working and may not respond again until tomorrow.)
  27. 02-27-2007 06:53 PM #97
    Quote, originally posted by enginerd »
    I think he is talking about lengthening his plenum, not his runners.
    Giving more entrance length to his plenum should help with distribution.
    That is correct sir. Lengthing the plenum on the throttle side to allow for better flow through runner #1 and leaving the runner lengths alone.
  28. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-27-2007 06:57 PM #98
    How so?With pressure,cylinder #5 & 6 would actually benefit the same as cyl #1--->4.
    Jimmy I think you should type up your post.
    Strangly enough (or not so strange) the 007 manifold performed better than both the Jabbasport & Dhalback manifold on badger5's car.
  29. 02-27-2007 07:00 PM #99
    Quote, originally posted by Wizard-of-OD »
    i know, i support the idea that the 5th and 6th will be just fine. I was posting that as a question to Brett.
  30. 02-27-2007 07:06 PM #100
    I am not an engineer but this picture does not show all that much taper. It does have an angled entry for the throttle body. I think we have concluded that the angle of attack of the throttle body is more benefical to the early cylinders 1/2 in a pure flow bench test.
  31. Former Advertiser
    Aug 26th, 2001
    02-27-2007 07:11 PM #101
    Nope, I disagree entirely. Again, an engine is very different from a flow bench.
    Quote »
    I am not surprised in the slightest it out performed the Dahlback (I don't know anything about the Jabbasport.) I have the utmost respect for Don and his work and the design is good but a non-tapered plenum would perform even better on an engine even though it would likely not do as well on a flowbench test.
    The Dahlback manifold, on the other hand, is an obsolete and ineffective design in my opinion. The logic behind the dual plenum and the longitudinal slit is not sound. I know this was run on some very successful race cars in the 80's but it simply doesn't work as well as other designs and the design has been retired in most circles for 20+ years. There is a reason you don't see many manifolds like this. It may look cool but it simply doesn't perform.
  32. Banned
    Feb 26th, 2005
    02-27-2007 07:29 PM #102
    No arguing with the leg humpers
  33. 02-27-2007 07:29 PM #103
    would you care to detail the reasons that you used "stock" injector bosses? I have laid hand to every manifold in this test, and several have perfect injector placement in billet, properly sealing bungs that arent killing off the port area.
    my second question to the apr runner is: Why is the curve so drastic? It seems to me by the shape that it would hurt port velocity and create turbulence rather than promote it.
    As to your remarks about engine builders liking straight plenums(maybe in a later post than the one i have quoted here): the guys who did the testing liked the shape of my 007 plenum... and all due respect... but i have no doubt that they have a more intimate knowledge of power gained by flow than anyone at APR.
    2002 337 1.8VBT
    2000 Jetta 1.8T stockish
    2011 Jetta TDI 55MPG
  34. 02-27-2007 07:40 PM #104
    must have been a posting issue so ill say it again. ..........
    If we were so bold to ASSUME that you didnt LOSE power on your previous dual plenem manifold, could we not further assume that your 007 is at least 30 hp better than an OE large port?
    2002 337 1.8VBT
  35. 02-27-2007 07:54 PM #105
    the experts are out in full swing.
