The 82mm piston set you showed. is that for a stock bore? or for a slight over-bore to a 2.9? thank you. Awesome prices by the way.
#71
Good to hear matt.
:: www.FourSeasonTuning.com
:: Wössner-APR-C2-United-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
#72
OPENROADTUNING
#74
1MM overbore on a stock 2.8 ( the piston is from the 2.9 ABV Euro Corrado )
#75
@James FST: Can you give me a quote forMK4 Jetta VR6
Lower control arm
4 piece R32/TT Bushings
2 rear shock mounts
Front Strut mount and Bearing setWith shipping to my APO Address (zip 09096)
Also your 8mm spark plug wires, are they much better than the original wires and do they fit in the engine cover grooves like the original wires?
Modified by Notabora2 at 6:52 PM 5-7-2008
#76
Pm Sent
Modified by FourSeasonTuning.com at 5:58 PM 5-7-2008
#77
How are the LSD's comin. I recall the person i talked to saying they would be shipped out directly from the guy who makes them at the end of the month (April). Just checkin in...pistons i got look great I cant wait to put them in.
dürtydübs
DBC member #![]()
#78
There was a slight delay with Peloquin,the diff should be shipping in 2 weeks.
#79
Are the kolbenshmidt 82mm pistons at this price at the current time. I am curious since the price is 475 and my order placed today has 495.
#80
I will edit the post, the web price is correct. The price has gone up due to the currency exchange rate. Thanks for the order.
#81
No thank you for providing good quality oe affordable parts and service.
#82
#83
If someone can contact me. I'm looking to buy ALL necessary pieces to rebuild my 93 corrado vr6 engine. I would like to run the 82MM pistons. the bearings, oil pump, water pump, int. shaft bearings. If someone could either email me with a price on everything I will need. I would also like to run the mk4 head gasket.dohc91gli@yahoo.com thanks.
Modified by DOHC91GLI at 11:21 AM 7-11-2008
OPENROADTUNING
#84
Im sent.
#86
No
#87
Just wondering if there's a package deal for the following:For OBDII VR6
- Autotech 262 Camshaft
- GIAC Chip (Cam profile)
- Autotech HD Valve Springs
- OEM Lifter SetCheers,
Mike
#88
- Autotech 262 Camshaft $259.95
- GIAC Chip (Cam profile) $135
- Autotech HD Valve Springs & OEM Lifter Set $195
#89
was buying some dealer only parts today, and got asked by the parts guy (after he'd heard that i've got a mk2vr6) "do you know a good place for vw parts?"gave him the link to your site, hopefully he orders from you too
2002 Lexus IS300 - Trac off is just Japanese for sideways on
#90
Thanks
#91
Quote, originally posted by FourSeasonTuning.com » - Autotech 262 Camshaft $259.95
- Autotech HD Valve Springs & OEM Lifter Set $195IM Sent with ECU #
Will call on Monday to complete the order
#92
I looked at Wössner 12v VR6 Piston Set 82MM and your site says 8.0:1 and bildon's website says 8.5:1 which is it. Is one going off of the metal gasket and the other the organic one?I'm looking to buy and it looks like you have free shipping.
#93
They are 8:0.1 And going with a mk4 HG would make it closer to 8:5.1
Modified by FourSeasonTuning.com at 9:43 PM 1-29-2009
#94
Cam Specs:Advertised Duration: TT 268
Intake Duration @.050" 231
Exhaust Duration @.050" 228.9
Lift: INT/ EXH 0.44854
Lobe Center 115Advertised Duration: CatCams 263
Intake Duration @.050" 231.9
Exhaust Duration @.050" 228.1
Lift: INT/ EXH 0.45421
Lobe Center 115Advertised Duration: Schrick 268 (older ver)
Intake Duration @.050" 224.9
Exhaust Duration @.050" 224.2
Lift: INT/ EXH .4476/.448
Lobe Center 115Advertised Duration: DRC 268
Intake Duration @.050" 230
Exhaust Duration @.050" 230
Lift: INT/ EXH 0.441
Lobe Center 112Advertised Duration: Schrick 264/260
Intake Duration @.050" 223.9
Exhaust Duration @.050" 222.9
Lift: INT/ EXH .447/.439
Lobe CenterAdvertised Duration: TT 264/260
Intake Duration @.050" 223.7
Exhaust Duration @.050" 220.6
Lift: INT/ EXH .448/.43925
Lobe Center 115.6Advertised Duration: TT 258
Exhaust Duration @.050" 223
Lift: INT/ EXH 0.435
Lobe Center 117Advertised Duration: FST 256 (older ver)
Intake Duration @.050" 222
Lift: INT/ EXH 0.432
Lobe Center 118Advertised Duration: FST 256
Lift: INT/ EXH 0.440
Lobe Center 118Advertised Duration: Schrick 260
Intake Duration @.050" 221.8
Exhaust Duration @.050" 221.2
Lobe Center 117Advertised Duration: Autotech 262
Intake Duration @.050" 220
Lobe Center 118.5Advertised Duration: CatCams 261 ( Turbo Grind )
Intake Duration @.040" 222
Exhaust Duration @.040" 222
Lobe Center 117
cant find the cam doctor sheet @ .050
Advertised Duration: CatCams 256 ( old turbo grind)
Lift: INT/ EXH 0.443
Lobe Center 117
#96
Replied
#97
hey man do you by any chance make 3 liter pistons for a vr6 12 valve?
#98
We can supply those in 83MM and 83.50MM. Both high and low compression ratio's.
#100
The TT 268 has performed well in turbo applications.
#101
Do you recommend getting the CAT valve spring kit with the CAT 261s or a H/D valve sping kit with FST 266/256s. Lastly, should I get titanium retainers if I get either of them?
#102
Im sent. Go with the TT 268 and the Supertech H/D springs.
Cams
http://www.fourseasontuning.com/?product=256
Springs
http://www.fourseasontuning.com/?product=476
Retainers
http://www.fourseasontuning.com/?product=208
#103
Thanks for the help. All ordered up.![]()
#104
Your welcome.
#105
just picked up a project, its a 2000 vw jetta glx vr6.The car has about 82,000 miles.
From the looks of it everything is stock, what can you guys recommend that will need to be replaced or what should be replaced at such high miles.
Thanks in advance!
