VWVortex.com - THE MK2 gear shift linkage repair guide
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 109
    Thread: THE MK2 gear shift linkage repair guide
    1. 03-14-2007 09:46 AM #1
      GSF sell the linkage repair kit:
      71709C - GEAR LINKAGE REPAIR KIT - £5.75 + VAT
      This is what you'll receive:
      1x big red bush (in the large bracket that holds the gearlever shaft)
      4x hard plastic bushes (only 2 needed, for bracket bolted to the gearbox)
      2x big clear soft rubbery bushes (for the relay shaft)
      2x small white soft rubbery bushes (for the ends of the shift rod)
      2x rivets (un-needed, used for the red bush housing but no need to drill out old ones)
      4x soft foamy washers (used on the short & long link rod ball joints)
      Its also worth buying an uprated relay shaft bush from:
      http://www.iol.ie/~locoblade/bushes.html
      Will improve the forward back feel a great deal
      Ok pop the bonnet and this is what you'll see, note I've already fitted the weighted shift rod:
      Remove the header tank and place it out of the way, this gives you loads of room to work in. Pre 90 spec ones are just slotted into the bracket, 90 spec ones are held on with 2 bolts/studs under the black plastic trim bit. Don't forget to disconnect the level sensor if one is fitted!
      The short & long rods with the plastic end caps have little clips to clamp the ends, carefully unclip these, I snapped one off and had to make an emergency visit to the scrappy! Both rods should then pop off with a little persuasion.
      Lever the spring clips out of the metal shift rod and remove, make sure these don't ping off & disappear!
      Undo the 13mm nut on top of the relay shaft, and remove the large metal arm.
      Loosen the 13mm pinch nut & bolt on the clamp on the gearlever shaft bracket, until it can be removed (you might want to mark its position but Chances are the alignment will be out after refitting all the bushes anyway!)
      Remove the 3 13mm bolts holding the relay shaft bracket to the steering rack, and remove. This is tricky, you have to wiggle the bracket about whilst holding the gearlever shaft as far back as it will go, there is only just enough clearance!
      Your engine bay will now look like this (note 2 of the gearbox linkage bracket bolts are circled):
      Now you have 2 choices, either remove the bracket bolted to the gearbox, or just unbolt the lever from the bracket. If you wish to change the gearbox it would be a good plan to do it at the same time as the only way to do it is to remove the linkage bracket. It also makes it easier to fit the replacement bushes and refit the lever, plus you can clean it up nice
      To remove the bracket:
      Undo the large bolt through the middle of the gearbox mount.
      Jack the gearbox up as far as possible, go slowly as the clutch arm will hit the inner wing.
      Remove the bolts holding the linkage to the gearbox and it should slide out nicely
      If you want to replace the gearbox mount, there are 2 smaller bolts holding the gearbox mount in the subframe, remove these and you'll have JUST enough clearance to remove it and swap in the new one.
      To remove the lever from the bracket:
      Simply remove the 13mm nut & bolt and the lever will slide off
      Ok now you'll have a pile of linkage bits on your workbench, after cleaning em up with a wire brush you'll have something like this:
      (notice I forgot to put the small plastic linkage and the lever mentioned above in the pic)
      It should now be pretty obvious which bushes go where, if you are unsure I've listed the locations above. The tricky one is the big red bush but it is possible to rip the old one out and fit the replacement without drilling out the rivets, put it in a tub of warm water first to make it a wee bit more flexible. Then as the red book says, re-assembly is the reverse of removal, make sure you grease up the moving parts while you put it all back together
      Now to set up the alignment, there is an alignment tool to make the job easy:
      go on ebay, search for 'tool' in the car parts section and select 'vw' from the manufacturer, theres usually a few on there.
      But being a tight Northerner I just used an old cassette tape held in the gap between the reverse gate & lockout lever with duck tape! Make sure you do the pinch bolt up tight, I made the mistake (twice!!) of not doing it up enough and lost all my gears a day or so afterwards as a result
      Job done:
    2. 03-14-2007 09:47 AM #2
      Gearstick housing replacement:
      It's pretty straightforward to do but a bit fiddly. You can still get the repair kit from VW, part number is 191 798 116A. I would recommend you get the genuine kit, this isn't a job you want to be doing twice! It also helps if you get an alignment tool from Dave2227 off ebay, but this is not essential.
      1. Remove the gearstick gaitor & centre console to give you more room to work
      2. Undo the 2 10mm nuts either side of the gearstick.
      Raise the car on ramps, or jack it up, if it's too low for ramps. Observe safe practice - use axle stands, apply the handbrake, chock the wheels. Select neutral. Or if its a poverty spec you can probably not bother raising it at all! on my 8v std GTI and driver suspension you could just go straight under there and do it.
      3. Remove the exhaust centre heat shield by removing the 6 nuts/clips holding it on, then rotate it round the exhaust an off the car
      4. Shove the housing up into the car, it is only held in by gravity & grease at this point, then remove the 4 13mm nuts holding the shiftbox to the car
      5. Now get back in the car, pull up on the stick and push down on the shiftbox, and Jiggle the gearlever housing about until you can get it out, bit of a fiddle but it can be done!
      6. If the ball looks like it is worn you can remove it, if it looks OK I wouldn't bother! Its tricky, you need to press the ball upwards while someone holds the gearlever down, then you need to remove the split pin. Not an easy task!
      It's much easier if you drop the gear lever down and out through the hole left by the absent ball housing. You need to wiggle the stop plate gently through the aperture, then the white plastic detent block through the same hole. A little pressure to move the exhaust sideways a fraction helps and it's much easier with two people - one in the car and one under it. It will come out, but needs fiddling.
      7. Refit the gearstick if you removed it in the previous step. Remember to be careful getting the stop plate through the housing. Install the new ball housing its just as fiddly as getting the old one out, some swearwords may need to be spoken!
      Other useful pics:
      Gearstick removed (new ball fitted)
      Wear inside the ball housing - certainly enough to get you reverse instead of first. On my GTI you could actually see through the bottom of the housing!
      Old and new balls; wear looked quite minimal, but in for a penny...
      Big thanks to Gary Woods for supplying the pics for this guide and some extra hints
    3. Banned skillton's Avatar
      Sep 26th, 2002
      03-14-2007 10:00 AM #3
      Nice write up, but I just got rid of my shift linkages all together, the're sitting somewhere in the garage right now, I put in an 02A with cable shift
    4. 03-14-2007 12:16 PM #4
      thanks, this is good to know, mostly just for the ball part. everything else on my car is getting replaced with my USRT kit.
    5. 03-14-2007 12:17 PM #5
      every mk2 owner should check their balls [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Hello my name is John and I'm a dub addict.
      My wiring diagrams and other documents have moved here:
      VAG Documents & Downloads
      You'll need to sign into google/gmail for the link to work! (its free!)
    6. 03-14-2007 12:19 PM #6
      Quote, originally posted by rubjonny »
      deal.
      yep they're there.
    7. 03-14-2007 12:22 PM #7
      cool, has been known for them to fall off!
    8. 03-14-2007 12:24 PM #8
      especially up here in the north.
      that said, most of the snow here is actually gone, summer tyres are coming out soon.
      as are a variety of small, and some much larger projects.
    9. 03-14-2007 12:49 PM #9
      all new linkage parts, well greased = Mmmmm [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member Burnitwithfire's Avatar
      May 14th, 2005
      Quebec, Canada
      2005 Legacy GT LTD 1992 Miata sunburst yellow
      03-14-2007 01:40 PM #10
      So that's what they are for!!! Nice write up, good job!
      Quote Originally Posted by SAV912 View Post
      Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
    11. Banned zeroman's Avatar
      Nov 19th, 2006
      03-14-2007 01:47 PM #11
      this would of been so nice before i took it to a shop to have this done! good write up
      i got my self a weighten shift rod my self like 30 mins ago, duno what to tell because i dont feel a difference but its on there $0 too <3 junk yards
    12. Banned hipfin's Avatar
      Mar 16th, 2006
      03-16-2007 02:48 AM #12
      im really really glad that this was written up. i just bought an mkii with shift linkage problems so i searched for shift linkage under mkii forums and its the only thing that came up! yyyay thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. 03-16-2007 04:54 AM #13
      glad its of use guys, hipfin good luck with the repair [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Banned hipfin's Avatar
      Mar 16th, 2006
      03-16-2007 11:17 AM #14
      haha i quoted you in my sig. idk why i just LOLed when i read it
    15. Member Chutem16V's Avatar
      Sep 19th, 2004
      Central NJ
      1988 GTI 16v
      03-16-2007 01:35 PM #15
      Check this place out for all the shift linkage info you need. Great parts.
      http://www.4crawler.com/Diesel...shtml
      It's very informative.
    16. Member Rugrat Anklebiter's Avatar
      Dec 5th, 2000
      PSL, FL
      2017 GTI Sport DSG LP / 2016 Jeep Renegade Latitude
      09-24-2007 08:11 PM #16
      Potterman's has the entire rebuild kit for $99.
      http://www.parts4vws.com/catal...98211
      Modified by Rugrat Anklebiter at 5:12 PM 9-24-2007
    17. 09-24-2007 08:21 PM #17
      just swap in an O2A and get one of these...
      I sit in the car and shift gears ...
    18. 09-28-2007 05:58 AM #18
      Quick addition, heres a link to a nice clear engineers diagram for the alignment tool [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://vwtech.no-ip.info/image...5.png
    19. 09-28-2007 06:32 AM #19
      Quote, originally posted by 1.9..16vTurbo &raquo;
      gtfo?
      Quote Originally Posted by Pineapplegti ! View Post
      Brand enthusiasts are idiots.
      Klutch Republik - Live Fast , Drive Hard
      SCCH Cylinder Heads & Suspension Components
      OSD #16
    20. Member
      Jun 1st, 2001
      92 GTI 16V 2.0; B5.5 Passat GLS; 13 CC R-Line; 90 Jetta GL(deceased)
      09-02-2008 03:10 PM #20
      Thanks for the write up. I rebuilt my linkage and shifter with parts from GAP this past weekend and it went perfectly! I also installed a weighted shift rod. It's like driving a new car.
      P.S.
      Spend the $12 plus shipping and get the Shifter Alignment Tool from TT. It worked the first time. No having to re-adjust multiple times like with the cassette trick.
    21. Member 959Lover's Avatar
      Jan 20th, 2006
      91GTI 12v, 87 951 trackcar, some more...
      09-02-2008 03:16 PM #21
      good writeup. Should def be added to the DIY thread.
    22. 01-13-2009 10:55 PM #22
      If I think I'm looking at what I'm looking at, my shift ball is falling through the cup.88 Cabriolet manual 5 speed, I not only have 5 speeds, I have 3 elevations of the gear shift. With the gear shift knob almost bottomed out I can get 2nd and 3rd,sometimes. Then in the mid elevation position I am eternally stuck between 3rd and forth, with the gear shift in the "almost out of it's socket"position I am able to grope for 1st or reverse.I am trying to anticipate the parts to order, on the list is the bushing kit, what is the part # for the receiving cup and am I going to order the ball separately? I am R&Ring water pump, both trans axles,radiator so this is not the end of me. I am being green by recycling this ole Dub.You pictures are great and helped me understand the immensity of this project. Chapman VW in Tucson Arizona is a regional dealer here and they carried the o ring for the oil cooler for six bucks and two bits. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Banned
      Aug 2nd, 2008
      03-26-2009 06:20 PM #23
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member sin bar's Avatar
      Jan 12th, 2008
      sin bar ga
      wagoon.
      03-26-2009 07:27 PM #24
      Quote, originally posted by shellshocked &raquo;
      check parts4vws or germanautoparts.com, and you'll have everything you need. did it myself with a little bit o help from my friends.
      the parts from either of these places will be even less than your local dealership, and you'll get either a sticker or a bag of candy, depending on from whom you order!
    25. 03-29-2009 08:34 PM #25
      Quote, originally posted by rubjonny &raquo;
      I have a MKIII & also having problems getting into 2nd & 4th after messing with my shifter lever pivot, after deciding not to mess with it.
      - can I re-align from the engine bay to get 2nd & 4th back?
      - if I do decide to replace the shift lever pivot ball do I have to drop the exhaust & remove the heat shield to do this?
      Thanks!
