VWVortex.com - 2.0 FIRING ORDER
    Results 1 to 16 of 16
    Thread: 2.0 FIRING ORDER
    1. 03-26-2007 12:01 AM #1
      hello,
      i'm new here so what's up everyone. anyway i just replaced the rotor and cap on my 98 wolfy and now it's not starting? i know the firing order is 1342 but for some reason i get nothing. i se the number 1 on the side of cap so i assumed it was #1 cylinder am i correct? if someone can help please i'm starting to pull my freaking hair out. thanks everyone who looks.
    2. Member georgekelp's Avatar
      Aug 15th, 2005
      Arizona
      03-26-2007 12:02 AM #2
      It is 1, 3, 4, 2. Clockwise.
    3. Member georgekelp's Avatar
      Aug 15th, 2005
      Arizona
      03-26-2007 12:04 AM #3
      Courtesy of Dan J Reed.
    4. 03-26-2007 12:05 AM #4
      yup that's how i have it now. so the number 1 does represent the 1st cylinder? also what else could it be? before i swapped it everything was fine. any ideas where i should start next? thanks in advance
    5. 03-26-2007 12:07 AM #5
      aha, thanks alot geoge u saved me with that diagram. i'll do that in the mornig then. thanks again and take care.
    6. Member georgekelp's Avatar
      Aug 15th, 2005
      Arizona
      03-26-2007 12:08 AM #6
      Yeah so #1 is the first cylinder.
      So do you have the plug wire going from cylinder 1 to the top of the cap?
      Because the the firing order is 1, 3, 4, 2. With 1 being at the top of the cap.
    7. 03-26-2007 12:20 AM #7
      nope i had it wrong but just did like the diagram and she fired right up thanks alot u really saved me butt. take care and thanks for the super fast response.
    8. Member georgekelp's Avatar
      Aug 15th, 2005
      Arizona
      03-26-2007 12:21 AM #8
      Quote, originally posted by 98_WOLF »
      Anytime [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Be sure to check in once in a while.
    9. Member X-E-0-3's Avatar
      Jun 14th, 2004
      O'Fallon Illinois
      2001 Audi TT Roadster - Red
      03-31-2007 08:11 PM #9
      ok ... If I am at TDC what position should the rotor button be? I have pics but cant find my camera cable.
      Should it be directly lined up with position number 1? Right now its def. not right I've moved it a few times.
      Whuch joo guys think?
      Modified by X-E-0-3 at 12:42 AM 4-1-2007
    10. 03-31-2007 08:40 PM #10
      1234
      9
    11. 03-31-2007 09:10 PM #11
      Quote, originally posted by X-E-0-3 »
      1
    12. 03-31-2007 09:39 PM #12
      2
    13. Member X-E-0-3's Avatar
      Jun 14th, 2004
      O'Fallon Illinois
      03-31-2007 11:25 PM #13
      wtf ?? 1 or 2 ?
      1 position spark plug or the notch?
      Modified by X-E-0-3 at 5:07 AM 4-1-2007
    14. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      04-01-2007 01:26 AM #14
      Notch.
      Parallel with the hall sender plug.
    15. n00b
      Feb 27th, 2016
      NYC
      98 Mk3 Jetta 2.0, 2010 Mk6 gti
      06-01-2016 07:47 PM #15
      Am going through aswell i just have a question does the notch have to face the first cylinder meaning 1 cause i just double checked mine the oder is correct but car still won't run and if the notch has to be in the a certain position how can i turn it ? i don't want to brake anything
    16. Member csrgti's Avatar
      Aug 18th, 2009
      Central Florida
      past Scirocco, Gli16V, Scirocco16v, Cabriolet, present 84GTi,96GTi
      06-02-2016 12:48 PM #16
      You can't turn the distributor its pinned to be non adjustable on an ABA engine.
      The rotor should line up with the notch in the top of the distributor housing , when all your timing marks for your timing belt are set correctly. If they aren't you need to loosen the belt and retime it correctly.
