VWVortex.com - MK1 Fuel Filler Neck to Tank Replacement Hoses
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 76
    Thread: MK1 Fuel Filler Neck to Tank Replacement Hoses
    1. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      '09 TTS / '12 Golf R
      04-02-2007 02:20 PM #1
      A few months ago, when I first brought my car home, like many of you have probably experienced, I had what amounted to a small fuel leak. I determined it to be from rusting hose clamps and a deteriorating filler neck to tank hose.
      Being a large supplier of universal silicone hose products, I immediately came to the realization that we could find something to easily work as a replacement.
      Since standard silicone rubber isn't suitable for oil nor fuel transfer, a special flourolined silicone must be used instead, so I immdiately placed an order for the appropriate stuff.
      I have finally received the right stuff to offer a suitable replacement product.
      41mm ID Flourolined Silicone Fuel Hoses
      Cut to length for a direct swap with your worn out OEM filler neck to tank hose.
      These hoses are temperature rated to 338 degrees F and have a burst pressure rating of about 17 BAR (246.5 PSI). Clearly overkill for their intended useage. The clamps are approved for military use by NATO and have a smooth inner band so as not to damage the hose as normal worm drive clamps can.
      There are two versions. though I am not 100% sure which cars use which version, but both are available.
      7 inch hose w/ clamps - $28.00 + shipping
      16 inch hose w/ clamps - $56.00 + shipping
      Please feel free to contact me if you have any questions.
      Modified by Mike@ForgeMotorsport at 1:44 PM 6-11-2008
    2. Member Cubster's Avatar
      Nov 26th, 2002
      Fort Worth, Texas
      04-02-2007 02:37 PM #2
      I have a '77 and I'm prretty sure the smaller hose is what I need.
    3. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-02-2007 02:51 PM #3
      Mine is an '80 and also uses the shorter hose, but I know there is some application that uses the longer version.
      So far, I've cut about 6 short ones and 2 long ones from the meter lengths I ordered and I'll be doing more tonight, so I'll have plenty to go 'round! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 04-02-2007 02:56 PM #4
      bump, cuz ill need this eventually.. just not right now [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Member goofydug's Avatar
      Feb 5th, 2004
      Boulder CO
      '81 rabbit / '17 taco
      04-02-2007 03:00 PM #5
      seems to me my 81 needs the longer version, i'll have to measure tonight
      -doug
    6. 04-02-2007 04:37 PM #6
      Quote, originally posted by whytie »
      haha, me too
    7. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-03-2007 10:33 AM #7
      Bump! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 04-03-2007 10:44 AM #8
      I think my 81 uses the longer, I will check, too. I'll be needing this very soon
      Aug 4th, 2000
      Kailua, HI
      MK1 GTI, '95 Golf 2.0T
      04-03-2007 11:07 AM #9
      I need to check mine and I'll order one.
    10. Member
      Nov 11th, 2002
      North Iowa
      '84 Rabbit VNT-15, '91 golf TD, '87 Jetta GLi, '84GTi 1.7TD, '84 Rabbit diesel
      04-04-2007 01:59 AM #10
      I'm not sure if I need the short or long version,... my ruler always says things are longer than they actually are
      Might be worth swapping on one of the longer metal filler necks so I can get a cheaper short hose.
      Are they rated to handle biodiesel?
    11. 04-04-2007 03:30 AM #11
      Not to hijack, but thats really spendy for what it does. There is no need for a high end hose in this application. Industrial supply houses carry large diameter fuel line for only a few bucks a foot.
    12. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-04-2007 07:11 AM #12
      Quote, originally posted by fatmobile »
      There should be no problem with biodiesel, but I'll check the specs. to be certain and I'll let you know. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote, originally posted by F0xz0r »
      Not to hijack?
      Funny, that's exactly what you're doing.
      If you don't like it, don't buy it.
      I'm not forcing it on anyone, and coincidentally, the pricing for this is exactly the same as buying the OEM rubber hoses from the dealer or anywhere else which will eventually dry-rot and wear out all over again.
      The half-life of silicone is overkill, yes, but I'm sure there are those people who would rather spend an extra few dollars to be sure there are no failures/leaks ever again.
    13. 04-04-2007 09:32 PM #13
      Quote, originally posted by Mike@ForgeMotorsport »
      And I'm not. I'm simply informing the folks that are not millionares such as myself that a alternative is avaliable.
      I wish you all the best of luck with your sales.
    14. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-04-2007 09:52 PM #14
      Meanwhile, thanks for the bump! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. 04-04-2007 09:58 PM #15
      Anytime
    16. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-06-2007 09:11 AM #16
      I still have 9 short hoses and 8 long hoses left.
      I'll be ordering more soon! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-08-2007 11:06 AM #17
    18. 04-08-2007 01:08 PM #18
      i'll probaby pick one of these up as soon as I figure out the one I need, I have a 78.
    19. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-08-2007 01:15 PM #19
      If I hapen to come accross any kind of listing specifying what years or applications use which hose, I'll be sure to make a post about it.
      Until then, it shouldn't take more than 30 seconds for anyone to peak under the car to see which one is needed. Unless of course, for those of you whose cars are so low, you can barely slide a credit card under the body!
    20. Member
      Nov 11th, 2002
      North Iowa
      04-11-2007 01:14 AM #20
      I just ventured into the deepest part of my garage/shed and found 2 filler necks for the shorty hoses.
      I think they are off '80 and earlier Rabbits.
      Any info on biodiesel compatability yet?
    21. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-11-2007 09:38 AM #21
      I have confirmed that the hoses will, indeed, be compatible with all diesel fuels and vegetable oils.
      - Diesel
      - Bio-Diesel
      - SVO (from rape, corn, linseed, sunflower, peanut, etc.)
    22. 04-11-2007 10:10 AM #22
      very nice man! good to see you putting out stuff for these little bastards! Met you at the beepers and phones that one night you were out with the red beast.
      Dub Cult Forever, Forever Dub Cult
    23. Former Advertiser
      Jul 31st, 2002
      Orlando FL
      04-11-2007 10:12 AM #23
      Yes, having one handy on a daily basis may mean a few more things might be offered eventually!
    24. 04-11-2007 10:13 AM #24
      haha.. see you on the ghetto man!
    25. Member goofydug's Avatar
      Feb 5th, 2004
      Boulder CO
      04-11-2007 11:00 AM #25
      for what it's worth, my '81 uses the longer hose
      -doug
