VWVortex.com - Review: 42 Draft Designs (42DD) 3" Turboback Exhaust [GLI - prototype]
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 39
    Thread: Review: 42 Draft Designs (42DD) 3" Turboback Exhaust [GLI - prototype]
    1. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-02-2007 08:03 PM #1
      "Finally! Something to give power down stream of the turbo..."
      For some, this has been a long waited post...
      I picked up 42DD's 3" turbo-back exhaust with a GLI-style 4" single tip from 045GLI (thanks!) back in early January.
      And with the cruddy weather Colorado recieved for 3 straight months was horrible, so I couldn't get the sucker on.
      That's up until just over the weekend.
      Evan@42DD [2kjettaguy] packaged and shipped it with 75% hardware (which we agreed on) and with new gaskets.
      The parts:
      * downpipe w/ flex pipe (with EGT bong, and two O2 sensor bungs)
      * straight center pipe with catalyst & resonator (with center wing hanger & post-cat O2 sensor)
      * over-axle pipe (with hanger)
      * Magnaflow muffler + 4" high polished exhaust tip (with hanger)
      I picked up nine 3/8"-11NC x 1.5" bolts for the bolting the adjustable system together.
      Removal of the original exhaust on my vehicle (with 41K miles) was too difficult, but more time consuming since I only tilted the driver side of the car.
      But getting in the new one... wow! A breeze!
      With the individual parts, it was a cake walk to bolt up the downpipe and snug that down (with a new gasket, I purchased) right away.
      Then transfer the center wing hanger from the existing OEM unit to their system...
      And then getting that up and in; bolted down to the floorpan and loosely connected to the DP for adjustment.
      Then installing the over-axle pipe; Evan instructed me that he accidentally placed the hanger extension in the "backwards" position...
      No problem, you can easily rotate the hanger frame 180deg around, no problems.
      And then get the muffler on (with GLI lip I've had sitting around since October!) and get that 'close' to final position.
      Snug up all the bolts starting from the DP and working your way to the muffler...
      And wha-la! Turboback installed!
      So, just how good is in terms of built quality?
      42DD did their homework and got it right the first time!
      There is a great clearance on the DP, and the entire system all the way back to the muffler tip.
      I didn't have to rebend, retweak, cut, modify, bust, remove, or destroy anything on the car or on the system to get it on correctly.
      And there's not a single rattle or clank when I drive the car.
      Evan, I just have only a slight suggestions + comments (if you produce a full line-up):
      * could you add another 1/16" or 3/32" to the radius where the adjustable slots are for bolt up? It's extremely tight to get a socket on and not lodged on.
      * maybe supply a turbo-to-DP gasket as apart of the system (if you produce a full-line)
      * great O2 sensor placements; no problems for install + clearance
      * good placement of the adjustable slots; everything was reachable.
      * downpipe bolt-up was awesome; didn't have an issue feeding the DP through the firewall + heatsheild.
      So how the sound?
      I'm sorry, but I DO NOT have any sound clips or videos to show.
      However, I'll be descriptive as possible.
      Upon first start-up, the idle out of the rear indicates you've got something install.
      At low revs and soft take-offs inside the cabin, there's not much to hear that you have a different exhaust.
      But, the moment you give 50% - 100% throttle, it's quite clear you've increased size and sound output.
      The tone is really refined and does not give any raspy or turbine whirl out of the tailpipe.
      At cruising speeds, you can't hear it over the wind with open windows...
      Expect when you're on the throttle, trying to pass someone on the highway or local business section of town.
      Cabin noise is extremely minimal and medium radio volume (from OEM Monsoon unit) drowns out most of the exhaust noise...
      There is a slight, but healthy buzz when the car is on the gas, but that's probably caused with the engine mounts I have installed.
      Hey, I've been 16 before; and I don't need a loud exhaust anymore..
      This system fits my wants almost 100%!
      Installation Time: 8 (1 = alot / 10 = alittle)
      * great matching of individual componets; some of the bolt=up locations are "tight" to get a tool in
      Learning Experience: 7 (1 = already knew / 10 = read-up and learned new things)
      * the removal of the old exhaust was more difficult since I wasn't on a rack; but learned that this install wasn't difficult at all
      Performance: 7 (1 = nada / 10 = tons)
      * once on, the car does quicken in reaching redline; but no dyno infomation at this time
      Bang-for-the-Buck: 9
      * if produced as a full-line up, it'll be one of the most cost-effective and easily adjustable turbobacks I've ever dealt with
      Overall Rating: 9
      * extremely good craftsmanship, good construction, good R&D, great customer service and communication, etc, etc
      No, I don't have pictures of the install; was too dirty and nasty to bring out the camera and take step-by-step photos
      However, I will have finished photos in 24 hours of this post.
      - Erik [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    2. Geriatric Member Bora_Azul's Avatar
      Dec 8th, 2002
      Hartford, CT / Porto de Mos, Portugal
      01 Sand pail, shovel not included
      04-02-2007 08:04 PM #2
      nice
    3. 04-02-2007 08:09 PM #3
      Awesome write up dude. Wonder if they are going to produce more of them. Hopefullly the quality doesnt go down if they do. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 04-02-2007 08:13 PM #4
      great write up! on their site it says they will produce the turboback once again in winter 2007. cant wait
    5. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      2001 Audi TT Quattro
      04-02-2007 08:44 PM #5
      Good write up so far. I look forward to lots of pictures and a sound clip eventually from you.
    6. Member AUDIPWRD's Avatar
      Feb 20th, 2001
      UT
      2012 VW GTI
      04-02-2007 08:51 PM #6
      Great write up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2012 GTI
    7. Banner Advertiser
      Dec 24th, 2000
      Millersville, MD
      Mk6 GTI, CBR600rr
      04-02-2007 09:08 PM #7
      Erik - thanks for the write up!
      Quote, originally posted by bluefox280 »
      [Evan, I just have only a slight suggestions + comments (if you produce a full line-up):
      * For the production systems I have changed to 5/16" hardware. This allows you to use 1/2" wrenches as opposed to 9/16". I also tightened up the relative width of the slots to force them to rotate and not be so sloppy. The slots are CNC machined, so they rotate easier with hardware installed than the laser cut slots. The laser kerf binds up the rotation.
      *I'm on the fence with the turbo-DP gasket. I don't recommend replacing this gasket unless your car is older than 150k miles or you've removed the downpipe before. The stock gasket is a double layer stainless gasket and holds up very well, given that your DP doesn't leak or you don't park your car in a lake.
      Other improvements over the prototype systems include modular cat/test pipe section, CNC machined flanges, 1-piece over-axle pipe, and I fixed that backwards hanger issue.
      The systems are now available. I am having some major website issues right now and I don't expect the systems to hit the website for a few weeks. I have about half of the tip fitments confirmed, so if you were to place an order for a system there may be a 1-2 week delay depending on what you get. If you are interested in a system please IM me directly and we will go from there. We're selling them already despite not even being on the website.
      Evan
    8. Member Malant's Avatar
      Aug 30th, 2004
      Maryland
      996/A6 Avant
      04-02-2007 09:38 PM #8
      I want one
      Heard nothing but good about these systems!
    9. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-03-2007 12:20 AM #9
      Cheap-o photos of the system and final install.
      Yes, there will be a complete photoshoot later.
      - Erik
    10. Member utjrod7's Avatar
      Mar 26th, 2006
      Austin
      2003 Jetta GLI
      04-03-2007 12:23 AM #10
      - Erik
      God, I hope so. It is complete.
    11. 04-03-2007 12:23 AM #11
      mad props to 42DD, i'd jump on this if i had a 1.8t. awesome company [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-03-2007 12:24 AM #12
      Quote, originally posted by 2kjettaguy »
      You're welcome; thanks for the patience.
      Fantastic; I was doing the math and 3/8" hardware has alot of shear rating on even standard grade 5 bolts...
      5/16" hardware is not a problem; good to hear!
      Mine only had 42K miles...
      But, I'm the type of owner where if a gasket is removed, it's replaced.
      But I understand the logic and the replacement was just as good quality as the OEM unit.
      Excellent to hear!
    13. Member burtondk12's Avatar
      Mar 19th, 2006
      slc
      04-03-2007 12:34 AM #13
      CT / tristate suspension/ airride installs. pm me for details
    14. Member spkn^GRMN's Avatar
      Jul 24th, 2002
      Charlotte, NC
      Segway turbo
      04-03-2007 12:37 AM #14
      -Wes
      2015
    15. Member TheMunky's Avatar
      Sep 20th, 2004
      Atlanta, GA
      2005 VW GTI, 2001 S4, 1993 UrS4, 2003 Evo 8, 1993 RX7
      04-03-2007 12:56 AM #15
      Thanks for taking the time to write that up. Looking forward to more pics/vids [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      syncro > car enthusiast app for iOS
      boosted factory > JDM performance in the ATL
    16. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      04-03-2007 02:14 PM #16
      That tip is sexy. Im just worried about 3 inch all the way back being too loud and raspy.
    17. 04-03-2007 02:15 PM #17
      ditto. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. 04-03-2007 02:32 PM #18
      sweet.. definitely down to buy this winter
    19. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-03-2007 07:47 PM #19
      Quote, originally posted by formerly silveratljetta »
      It's just a tad louder than a Magnaflow 2.5" unreonsated cat-back...
      And almost the same as GHL's 2.5" resonated trubo-back.
      The 3" is deeper; not louder. There's a more audible range you can hear with the larger diameter.
      - Erik
    20. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      04-03-2007 09:12 PM #20
      - Erik
      I know you know someone in your town that can make sound clips?
    21. Banned
      Mar 17th, 2007
      04-03-2007 09:35 PM #21
      Holy crap i cant believe your just now finally installing this thing. Glad your happy with it [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-03-2007 10:50 PM #22
      Working on it... I swear; but my April is jammed packed.
      I'll see what I can do.
      - Erik
    23. Member vwgliin05's Avatar
      Aug 1st, 2006
      Allentown, PA
      MKV
      04-09-2007 10:30 PM #23
      nice man i want one
    24. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      04-09-2007 10:40 PM #24
      - Erik
      deeper and louder are basically the same thing. Just a reiteration of the same concept
      And I also just noticed that you have the resonated version. Im not a fan of resonators. I feel like they take away from the true exhaust note. Its a personal problem
      Modified by formerly silveratljetta at 7:42 PM 4-9-2007
    25. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      04-09-2007 10:42 PM #25
      Ok, fair.
      There is some bass to the exhaust tone...
      However it's only out of the tailpipe.
      There's no resonation or engine noise midsection of the vehicle.
      - Erik
