VWVortex.com - Fuel Gauge and tachometer not working
    Results 1 to 7 of 7
    Thread: Fuel Gauge and tachometer not working
    1. 04-04-2007 05:48 PM #1
      I am trying to fix these 2 gauges on a 1990 cabriolet along with the power windows.
      The gauges are on the off position and do not move at all. I found a nice writeup on the power windows so I should be fine on that aspect. Every other component works and all other gauges and warning lights work also.
      I thought I should ask where to concentrate on, the grounds or test the back of the cluster or somewher else maybe someone has had a similar issue, thanks and sorry for the long post.
      Current 1991 audi 200 20v turbo waggen, 1990 vw cabby 16v, 1980 bmw 745i turbo, 1987 mitsu starion esi-r
      Past- 82 vw scirocco, 93 mitsu mirage, 83 vw GTI, 79 BMW 733i euro, 86 mercedes 16v cosworth, 1988 bmw 325 IC, 1990 saab 900 turbo,
    2. Member Holden McNeil's Avatar
      Jul 26th, 2004
      Hennepin Co, Minnesota
      2013 Fiat 500 Turbo
      04-04-2007 05:58 PM #2
      Not sure who wrote this up but this might help....
      Quote, originally posted by Someone on the Vortex.... »
      How to Fix the dash in the cabby…
      My tach, fuel gauge, temp gauge and all the idiot lights/turn signal lights went out in the cluster. occasionally, hitting a bump would send them working again, before they'd crap out again. son of an electrical engineer that I am, I discovered that I could get this set working again by reaching up under the dash and wiggling the main plug that attached to the cluster. But this didn't always work, and I eventually forgot to reset my odometer and ran out of gas - because the gauge happened to be out.
      My trusted VW mechanic told me his experience with this common issue and gave me the fix, which I performed myself. The problem lies with the flimsy/worn contacts on the cluster's main plug. (the "male" side) You will notice that the contacts simply wrap over the plastic male end of the plug. The fix is to pull back the contacts and wrap a bit of electrical tape over the plastic. When you rewrap the contacts back over the tape, you will now notice that you'll get a tighter fit when you plug the male end into the female side. Of course, spray it all with contact cleaner before you reattach it all and hopefully auto's cured.
    3. 04-05-2007 01:20 PM #3
      thanks, I will do this when I get back today, anyone else have any input
    4. Member Halo2x's Avatar
      Oct 31st, 2005
      Maryland
      T4R
      04-26-2007 02:09 AM #4
      Did you try this? Did it work?
    5. 04-26-2007 08:41 PM #5
      I am awaiting on a new ecu since the car won't start, I have not gotten around to checking this yet [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. Member Halo2x's Avatar
      Oct 31st, 2005
      Maryland
      T4R
      04-26-2007 10:35 PM #6
      Ah got ya. Good luck [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member Moljinar's Avatar
      Sep 20th, 2001
      Indianapolis, IN
      87 Cabriolet, 85 Cabriolet, 90 JettaGL
      04-27-2007 09:24 AM #7
      Been there and done that. That connector was a particularly brainless design.
