VWVortex.com - Flashing Check Engine Light
    Results 1 to 7 of 7
    Thread: Flashing Check Engine Light
    1. 04-06-2007 10:56 AM #1
      The other morning, I started my car (Jetta 2.0T), and the engine was shuttering and the check engine light was flashing. I turned off the car, waited 30seconds, started it again, and it was like nothing had happened (started up normail the second time). Has anyone experienced this before?
    2. Member bbong73's Avatar
      Sep 12th, 2002
      2006 MKV GTI 1995 MK3 GTI
      04-06-2007 11:02 AM #2
      Was it cold outside?
    3. Former Advertiser
      Mar 29th, 2005
      Warwick, NY
      2004.5 GLI BT, 20AE BT, 09 Tiguan with some goodies
      04-06-2007 11:13 AM #3
      A flashing check engine light is indicitive of an ignition based problem. The shuttering at idle is also inline with ignition based problems. When a car is misfiring, sometimes it feels like the engine wants to jump right out of the car.
      Have you had the car scanned for codes as of yet?
    4. 04-06-2007 01:13 PM #4
      If it happens again, tighten your gas cap. Sounds dumb, but I had the same problem, and the loose gas cap was the reason.
    5. Member sebasEuRo's Avatar
      Feb 26th, 2006
      Seattle/Europe
      '17 Passat SEL, '17 Sportwagen 4motion
      04-06-2007 01:27 PM #5
      Quote, originally posted by windsorfox »
      you have GOT to be joking me
      *****AMBER CluB*****
      Volkswagen AktienGesellschaft In North America
    6. 04-06-2007 02:28 PM #6
      not yet, but i'm going to make an appointment at the dealer. Would the error be kept in memory?
    7. Former Advertiser
      Mar 29th, 2005
      Warwick, NY
      04-06-2007 03:59 PM #7
      Quote, originally posted by 89vw »
      Yes, the codes are stored in the ECU until cleared or the problem is ultimately fixed.
