Results 1 to 20 of 20
Thread: The ASR button
  1. 04-12-2007 07:35 PM #1
    Like i know what its meant for but what does it mean and what does it exactly do.
    All i know is i can launch faster in every gear with it on.
    (im a new vw owner and the car does not have a owners manual.)
  2. 04-12-2007 07:42 PM #2
    i'm not sure wat it stands for but it takes off your traction control so you can spin the tires. i dont think it does anything for your engines power, but since it doesnt shut down your throttle when you lose traction you will be able to launch the car better.
  3. 04-12-2007 07:43 PM #3
    it prevents wheels from spining, i think it closes the TB
  4. 04-12-2007 07:46 PM #4
    Quote, originally posted by chay G. »
    I get a more wheel spin(was raining today) with it on :X.
    one more question, is keeping it on a good idea? or it doesnt matter.
    Gas mileage wise and engine matienace
    Modified by vdubyaluv at 7:48 PM 4-12-2007
  5. 04-12-2007 07:47 PM #5
    it stands for Anti Slip Regulation.
    prevents the wheels from spinning.
  6. 04-12-2007 07:50 PM #6
    Quote, originally posted by vdubyaluv »
    ASR detects wheel slippage and applies braking force to that particular wheel. Working with the Electronic Differential Lock at speeds below 25 mph, ASR controls throttle response to maximize traction and minimize slipping as well.
    Hope that helps.
  7. Banned ea187's Avatar
    Apr 23rd, 2004
    04-12-2007 07:53 PM #7
    i think you mean with it off. when you push the button it turns it off not on.
    i'd like to know how you can launch in every gear. that's impressive
    Modified by ea187 at 4:54 PM 4-12-2007
  8. 04-12-2007 07:54 PM #8
    Quote, originally posted by Bugeye1.8 »
    Hope that helps.
    thats wierd man, i get more wheel spin with it on. I went to one of my friends house and met a guy that works for VW as a mechanic, i let him drive my car because he loves VW's and he told me to get better launch push this button in and make sure the light is on. Also he was peeling out chirpin in 2nd and 3rd gear with it on. I had never knew about this button til today and never knew my car could chirp 3rd, but if its anti with it on then why does it only work when its on.
  9. 04-12-2007 07:56 PM #9
    There is know way your car is chirping into 3rd.
    Your already doing 65-70 at redline in second.
  10. 04-12-2007 07:56 PM #10
    Quote, originally posted by ea187 »
    Im not a fluent english speaker, sorry for the confusin
  11. 04-12-2007 07:58 PM #11
    Quote, originally posted by uroslvt »
    nope, i was at about 50-56 in 2nd and i redline around 6,500.
    If u read above, rain means a wet road.
  12. Senior Member bluebora20v's Avatar
    Jun 14th, 2001
    Bay
    2000/VW/MK4 Jetta
    04-12-2007 08:00 PM #12
    I think you are confusing when the switch/light is ON/OFF versus when the ASR is ON/OFF.
    Light ON = ASR OFF
    If you turn OFF the ASR then you will be able to spin the tires. You should be able to launch better with the ASR off because you are then able to modulate the throttle pedal however you wish without the intrusive ASR from kicking on the brakes. There is a delay time after ASR kicks on to when it turns off which I have found to be very dangerous in some situations. If you ever try to launch your car TURN OFF YOUR ASR.
  13. Banned
    Nov 24th, 2001
    04-12-2007 08:00 PM #13
    this is well discussed. FAQ's and SEARCH can provide more info.
  14. 04-12-2007 08:01 PM #14
    Quote, originally posted by bluebora20v »
    Light ON = ASR OFF
    yeah i relize this now. thnaks for the info eryone
  15. Member uberwagn's Avatar
    May 18th, 2006
    w00sta county
    1999 B5 Audi A4 1.8T
    04-12-2007 09:10 PM #15
    cmon dude, you buy the car - and you dont even see what each button is for and need someone to tell you? i figured out that button the instant second i drove my jetta off the lot. god.. whats up with people these days.
  16. Member utjrod7's Avatar
    Mar 26th, 2006
    Austin
    2003 Jetta GLI
    04-12-2007 09:17 PM #16
    Wow, what a pr*ck. Sorry, not everyone is an acronym master like you. God, I'll tell you, some people.
  17. Member uberwagn's Avatar
    May 18th, 2006
    w00sta county
    04-13-2007 12:57 PM #17
    Quote, originally posted by utjrod7 »
    you tellin me you test drive the car, and dont even ask what the ASR is for if you dont know what it is? i dont understand how someone could drive their car for a while not knowing what that certain feature does, at least press it and experiment.
  18. 04-13-2007 01:31 PM #18
    yesss here we go! round 1 fight!!
  19. Member scanlory's Avatar
    Jan 17th, 2007
    1983 GTI, 2012 GTI
    04-13-2007 01:42 PM #19
    yoink.
  20. Member vagwhpt's Avatar
    Jul 28th, 2006
    Northern VA
    Bicycles are more important than my B5.5 wagon.....
    04-13-2007 01:47 PM #20
    ok class, lets say it together....... S-E-L-F C-O-N-T-R-A-D-I-C-T-I-O-N
    The Possesion of anything begins in the mind.
