VWVortex.com - Yes, another VR6-T
    Page 3 of 25 FirstFirst 123456713 ... LastLast
    Results 51 to 75 of 610
    Thread: Yes, another VR6-T
    1. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 09 Vw Passat 4Motion 2.0TDI Highline
      06-08-2007 09:29 AM #51
      More pics:
      Have been running 21750 miles.......
      Turbo on:
      New oilpan on:
      Tech's Corrado 2.9 VR6..
      1996 Golf MK3 GT35R 12V 02M Lugtronic Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page4
      2009 Passat b6 2.0TDI 4Motion Highline
    2. 06-08-2007 10:20 AM #52
      The intercooler plumbig took a little guess work, but the hardest part was the damn oil pan. stripped 2 little bolts and it slowed up the install. I removed alot of crap in my engine bay for cleaning and it made mocking up the IC pipes alot easier.
    3. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-08-2007 10:27 AM #53
      I see. Your car is now running?
      We are so lucky to have tools driven by air pressure. So the oilpan change was like 10 minutes But the 3" DP is damn tight Like proper tight DP was put on AFTER the Turbo/manni..
    4. 06-08-2007 11:36 AM #54
      Broke a injector O-ring so its apart again. should be up and running by Saturday. Yeah no lift and no air tools makes it a PITA. but thats what 's are for right? I'll throw some pics up on here soon!
    5. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-08-2007 12:19 PM #55
      Looking foreward to the pics.
      I have a goal for 350whp at 20 psi. Hope its doable.
      Chris, Oslo.
    6. 06-08-2007 12:30 PM #56
      haha yea , I will try to get them up Saturday. did you use a gasket in between the turbo/downpipe? I did not, and, dont know if I should have or what? My goal is to not blow up my trannie in the first 2 weeks of driving. i'm so used to driving a all motor car i'm going to have to learn to drive different. What spring are you using? i'm running the 9 pound for now. ~John
    7. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-08-2007 12:52 PM #57
      No gasket between turbo/downpipe. Spring is 6 psi, but I have a Kinetic manual boost conroler to fit. My tranny? I have a Peloquin and BFI stage 1 mounts all around. Should be ok .... For a while
      Try to use the tranny carefully. A friend off mine just blow his 8000 USD tranny on his VR5 Turbo WITH AP gearset and Peloquin diff. The diff is ok, but the AP kit is not useable.
    8. 06-08-2007 01:53 PM #58
      Quote, originally posted by Norwegian-VR6 »
      Chris, Oslo.
      at 20psi with 42lb injectors you shuold be at 400whp or more. I've seen someone make 438whp at 20.5psi with the same fueling as you. Looking good.
    9. 06-08-2007 01:53 PM #59
      Yeah I hear ya, I have a stock trannie with over 100K of hard all motor miles on it. I'm not expecting it too last too long before it needs a rebuild. I have a spare trannie, but, I kind of want to put the o2m gears in there. Still trying to make up my mind about which route to go. I heard about the problems with the AP gears. sounds like a bummer, seems alot of people are out alot of $$$$. Hopefully APT will do something to help their customers out.
    10. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-08-2007 02:06 PM #60
      To dyno the car, 20 PSI should be ok. But 15 PSI is what im gonna drive with.
    11. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-09-2007 03:42 PM #61
      ok,question. How do I connect the oilfeeding into the turbo?
      This is what came in my kit, is it the 90 degree bend that I should screw into the turbo? Or do I miss a part?
    12. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-10-2007 05:34 PM #62
      BUMP! How does the oilfeeding fitting into the turbo look like?
      Modified by Norwegian-VR6 at 11:59 PM 6-10-2007
    13. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-10-2007 06:03 PM #63
    14. 06-11-2007 09:37 AM #64
      I do not see the peice you need there? I was missing mine tow! its one of two fitting holding me up (the other I broke) its larger than the two silver ones which are too small ( i'm sure you figured this out) i'm going to try to make time to go get one in the next day or two ...so If i get a part number I will get it to you. PS-which oil sensor did you tap into for the oil send~Turbo line?
    15. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-11-2007 10:08 AM #65
      Havent decided wich sensor yet. Do think its the same?
      I called Garrett Turbo off Norway, and Im gonna get the part. Took him 2 sec`s to find out off my problem
      I think its looking like this:
    16. 06-11-2007 10:40 AM #66
      yup thats the part i'm missing. would you have a part number by any chance?. glad you are making progress.
    17. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-11-2007 01:29 PM #67
    18. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-17-2007 07:00 PM #68
      OK Then....
      First start today. And the car fired RIGHT up, NO ISSUES! No nothing!
      The VW tech told me that he has never seen anything like it. It idles and drives like stock.
      It was a wet road, and on 3rd gear i lost traction. I ran the stock spring in the Tial.. Red I guess 6 psi. With the ZR2 charger I had problems getting the car to LOOSE traction in first gear.
      This is a very big day for me, and all thanx to YOU VWVortex guys and of course Chris and Jeff at C2. MAF is working also.
      Im I one of the first in Europe to have a ECU swap like this?
      Very first ignition:
      http://www.youtube.com/watch?v=vjsYkbNp41k
      Second:
      http://www.youtube.com/watch?v=3ePepHl1a-0
      Once again, THANX!
      Modified by Norwegian-VR6 at 2:14 AM 6-18-2007
      Modified by Norwegian-VR6 at 2:15 AM 6-18-2007
    19. 06-17-2007 07:57 PM #69
      Glad to hear you have it running [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2004 R32 summer daily
      1997 sequoia GTI VR6 turbo. 12.1@124, (best mph)12.2@126mph. I need some slicks
      1992 GTI VR6T. Still not done
      1998 jetta DBW 1.8T Syncro. winter beater
      1994 caged Golf VR6. Daily driver. 14.7@95mph(sold)
    20. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      06-17-2007 08:20 PM #70
      Thanx. The idle is so smooth, and with a US ECU and all. I guess the diffrence is not that much. But I know Jeff has put some time and effort on it. Well, I have the big smile on my face because off him.
      And Alexi: 0.024 gap, no missfire, no nothing. I was awaiting some issues of some kind. But no. Nothing. Car runs like stock.
      2x6pack of to you all
      Here a pic from a Kinetic stage 3 with a 60/1 Garrett Turbo:
      A A4 paper does fit under there............
      Modified by Norwegian-VR6 at 2:23 AM 6-18-2007
      Modified by Norwegian-VR6 at 2:42 AM 6-18-2007
    21. Senior Member jhayesvw's Avatar
      Oct 3rd, 2001
      Tucson, AZ
      12' GTI
      06-17-2007 10:09 PM #71
      good to hear that all is well.
      keep us posted on how it runs in the future. im sure it will be great. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      07-03-2007 02:25 PM #72
      Car is up and running, with complete 3" exhaust. 1 long muffler under the car and a muffler in the back with C2 OAP. Its loud as a f... !
      The C2 OAP fitts great, you just need to take your time and do it right.
      The ECU needed 4-6 start ups to "settle" The Idle was a little up and down. But after 1 our driving is all good.
      Car drives like a dream.
      Im boosting only 6 psi now. Im not gonna do anything before I get the widebang hooked up tommorow.
      Some pics today. Been raining the hole day:
    23. 07-03-2007 03:50 PM #73
      congrats on getting her up and boosting! wait till you feel 15psi , i'll have numbers for you by next Friday!
    24. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      07-03-2007 03:51 PM #74
    25. 07-05-2007 06:15 PM #75
      Nice work...you finally pulled this off.
