Page 5 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 561
Thread: Yes, another VR6-T
  1. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    96 Golf 3.0 VRT. 01 Golf V6 4Motion, 12 Skoda Superb 2,0 TDI avant
    04-11-2008 02:28 PM #141
    Needs to shift pretty early, because the A/R 63 on the T04S is not willing to play past 5000 rpm from third...
    http://s169.photobucket.com/al...3.flv
    Modified by Norwegian-VR6 at 8:39 PM 4-11-2008
    Modified by Norwegian-VR6 at 12:07 AM 4-12-2008
    Skoda Superb 2.0 TDI avant: Daily family car
    Golf MK3 12V Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page6
    Golf V6 4Motion: Dailydriver
  2. 04-14-2008 03:09 PM #142
    hey I like the vid sounds good. You can really hear that gear whine. Very cool.
    what are your latest dyno numbers? I have a appointment set-up for monday the 28th. pretty much your set-up. but I'm adding WAI and plan to give 22psi a try.
  3. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    04-25-2008 06:17 PM #143
    UPS called me today, and had a delivery for me.
    And all I can say is, if this stuff fits, everything will fit
    140 gold nuts and 2.5" OZ lips.. Twice the size from front. They are ABIT to much I guess. My car was painted last april, and I wided out so I can fit some wider wheels... But I think I went abit wide
    Modified by Norwegian-VR6 at 12:26 AM 4-26-2008
  4. 04-29-2008 01:09 AM #144
    those lips gave me norwegian wood
    sorry....... i had to
  5. Banned
    Feb 9th, 2005
    04-29-2008 11:14 PM #145
    Sorry, you may have already said this but who's 3" downpipe did you use for the t4 60-1? I was told the Kinetic kit silicone, downpipe, and manifold weren't made for a T4 exhaust housing turbo.
  6. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    04-29-2008 11:25 PM #146
    you can use a kinetic mani with a t4 turbo. as for the DP i guess anything could be welded onto it so it fits.
  7. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    04-30-2008 12:15 PM #147
    The T4 GT35R will bolt on a Kinetic manifold. And yes, I will use a 3" Kinetic DP with welded on V-Band.
  8. 04-30-2008 12:53 PM #148
    beat me to it. make sure to get some pics up once those wheels are mouned. You planning on hitting the dyno anytime soon???
  9. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    04-30-2008 12:56 PM #149
    Right now, I have no time what so ever to do anything. Im working around the clock. So the car is just daily driven. After may month, I will have some free time to do some work.
    Maybe I will hit the Rotomaster
  10. 04-30-2008 02:09 PM #150
    is that the equivalent of a mustang or dynojet?
  11. 04-30-2008 03:30 PM #151
    Nice project Was considering the SQS and now I'm sold, despite HotSkillet's pictures!
    Can I ask where you got the part arrowed? That is precisely what I need!
    Thanks
  12. 04-30-2008 09:12 PM #152
    that piece comes with the kinetic stage III ( I call it the dump flex pipe) so give them a call. You might be able to get something a little better. Mine has developed a small leak after about 15K on the kit.
  13. 05-01-2008 05:05 AM #153
    Thanks for the info. It looks better than my DIY attempt at a dump tube but I'm not sure they'll be willing to split one from a kit! Plus I'm in the UK, so sending a $20 part will end up costing $60 by the time it gets here! :-(
  14. 05-01-2008 07:29 AM #154
    Quote, originally posted by kevhayward »
    Thanks
    Hotskillet used APtuning gears
  15. Banned
    Mar 12th, 2002
    05-01-2008 02:52 PM #155
    Quote, originally posted by foffa2002@home »
    Uh... no your wrong...again. I've used both. SQS were way worse than the ones in the picture.
    this topic has beeen pounded in the ground over and over again.
  16. 05-01-2008 04:06 PM #156
    does anyone know if they corrected the issues with there 02a gears? anyone put over 450wtq thru them?
  17. 05-02-2008 03:40 AM #157
    Quote, originally posted by HOTSKILLET98 »
    So you blew the SQS also
  18. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    07-10-2008 05:58 AM #158
    Something horrible happen to my SQS gearbox yesrerday. Gonna open it up and see next week. It rattels very loud. And I have problems getting it into gear. Before i stopped the car, the clutch started to slip in third gear.. Clutch and gearbox sounds like ****!
    So right now, im abit down.. In the inner room, down in the basement
    My mechanic was laughing when I came, with the car on top of a truck.
    He said it was the gearbox
    We will see.
  19. 07-10-2008 10:29 AM #159
    let us know what happened
  20. 07-10-2008 12:10 PM #160
    sounds not good with the sqs..let us see what happend.
    Modified by VR6-GT42RS at 9:11 AM 7-10-2008
    R36T AWD 1100HP
    www.ktech.dk
  21. 07-10-2008 12:20 PM #161
    i have run quaife 02a for years now with over 750nm..it works..
    Modified by VR6-GT42RS at 9:21 AM 7-10-2008
    R36T AWD 1100HP
    www.ktech.dk
  22. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    07-10-2008 02:08 PM #162
    I was driving around like always. 1-3 gear straight out, and this time only 10 psi. Was gonna put it back to second gear, but the gearstick was not going into any gears. No way! So I stopped the car, to check the cable connection. Tighten the 13mm that I saw down there, and it was going into gears again. But not like it used to.
    Ok, before this happend, at idle it was ratteling alittle bit as usual. But when i pusched the clutch in, the rattle was gone.
    But now the rattle sound did not go away immediately. Took around 2 seconds, and I could hear something was spinning around then it stopped.
    Anyway. Drove home, and thought I needed my mechanic to adjust the cables to the 02A the next day.
    On my way to work, the gearbox was acting like normal. It was alittle hard somethimes to get it into gear. But in the city, I mostly use 1-3 gear. So I went up a pretty big hill.. Got into 4th gear. Then when I was trying to get it back to third, it was no way. It dindt wanna go at all. After some gentle tryings i got into third gear. I was hitting the pedal, and now the clutch was starting to slip. After this it was no way to get it into 1-5. But reverse was ok. When I got it into reverse, and let the clutch go, I could hear a really bad "rattling" sound again. Got it on to a truck and went to the garage. My mechanic was standing there with his Lucky strike in his mouth and smilling at me
    It made my mood be alittle better. But when I showed him that it got the car into reverse, and the clutch was acting like it should the horrible "Rattling" sound came again.
    He said, this is your gearbox
    Modified by Norwegian-VR6 at 8:10 PM 7-10-2008
  23. Member IwannaGTI's Avatar
    Jul 12th, 2001
    Philadelphia, PA
    02 S2000, '68 Mini Pickup
    07-10-2008 03:22 PM #163
    Quote, originally posted by Norwegian-VR6 »
    I had something similar happen.
    Once with a vw: was the clutch fork.
    Once with a talon: was the ring gear on the flywheel
    and a last time was the trans on the talon
    Quote Originally Posted by NHDUBN#2 View Post
    Like procreation the Internet should just not be done by some people.
    Quote Originally Posted by GTE77 View Post
    You're are'nt a bot are ya? I can see it in your eyes......You have.....LOVE.
  24. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    07-10-2008 03:38 PM #164
    Quote, originally posted by IwannaGTI »
    Ive seen Alexi did modify his clutchfork.. I hope its someting like that. Thanx for the advice. You made me in a good mood.
    Modified by Norwegian-VR6 at 10:08 PM 7-10-2008
  25. Member vr6chris's Avatar
    May 26th, 2003
    Baltimore, MD
    07-11-2008 10:42 AM #165
    damn it, i thought i finally found a gear box that would hold up. i was planning on getting one this winter. looks like ill have to look around some more
  26. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    07-11-2008 11:11 AM #166
    Well, I guess its not fair to say that the SQS setup has failed. Because I dont know what happend yet.
  27. 07-30-2008 01:28 PM #167
    Any updates bro?
  28. Member MKII16v's Avatar
    Oct 23rd, 1999
    Sammamish, WA
    06 Sienna XLE Limited
    07-30-2008 11:07 PM #168
    I had the same thing happen and it caused me to ruin 3rd gear. The clutch fork had bent over 30 degrees. I run one of these now.
    http://www.flipsidecustoms.com...shtml
  29. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    08-08-2008 04:16 PM #169
    Quote, originally posted by benzivr6 »
    Any updates bro?
    Sorry, no updates. Got vacation, and I wanted to spend money on that. So my VRT needs to stand still, until I get the money to fix it.
    Im really starting to get abit tired off it all.
    I mean, Ive never had a really "good/nice" car before.
    I mean my income is around 88000USD a year, but still, this car sucks so much money. And with the price's we have over here, I cant afford to have 2 ok cars.
    Ive been thinking off a Audi RS2 or a BMW 330XD Wagon.
    Audi from 94-95 model, and BMW 2000-2003.
    Both are around 50000,- USD..
    So a car is expensive over here
  30. Member Grabbit's Avatar
    Apr 27th, 2001
    SEA128021
    Mk1, Mk2
    08-08-2008 08:17 PM #170
    Just read all 5 pages, I hope this gets fixed
  31. Member dreadlocks's Avatar
    May 24th, 2006
    Denver, CO
    0xMK6.MK4.T2
    08-08-2008 11:53 PM #171
    Owning a VRT is a love/hate relationship...
    Either swap an o2m into it or drop the cash for a Quafie Dog set, anything less will succumb to the torque monster you have.
    Also a monster turbo that brings the torque on late and gradual will help you save the drive train.
    Im on my 3rd build and been been burned 3 times now, but in the end I always come back and looking for more power.. Gotta pay to play.
    Good luck
    Diesel - 2013 Golf 4DR TDI w/6MT & Tech Package
    GolfKart - 2001 GTI 3.0L 12v VR6 Turbo w/6MT
    Shagwagen - 1975 BayWindow 2.0L Fuel Injected Westfallia w/4MT
  32. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    08-09-2008 03:27 PM #172
    I got the car home yesterday. Havent done anything to it yet, but we towed the car home. Car was at idle the hole journey.
    Thing was like this:
    Car was in neutral, and the clutch pedal was out. It rattles like crazy. Car in front off me started to move, and the rope to my car stretched and we where on our way. 20-30 km/t and I saw the RPM was bounching up and down. Like the clutch was not working, or trying to hook up to something... So I needed to sit in the car as long as I could, with the clutch pedal in hehe..
    And the Sachs Race Enginnering clutch kit have alot stiffer pedal than OEM
    Anyway, I really hope its only the clutch and not my SQS.
    Sent a email to SQS, and he was pretty sure it was the clutch.
    We will see, when I get the money to open this thing up.
    Been wondering on a Spec stage 3+ clutch.
    Any suggestions?
    And what happens if I buy a lighter flywheel in some "clutch package"?
    Does the C2 software allow this?
    Modified by Norwegian-VR6 at 9:28 PM 8-9-2008
  33. Member dreadlocks's Avatar
    May 24th, 2006
    Denver, CO
    0xMK6.MK4.T2
    08-09-2008 10:46 PM #173
    Buy a Southbend clutch, keep OE flywheel and upgrade clutch fork.
  34. 08-09-2008 11:45 PM #174
    Southbend has my vote. I've had their stage 3 clutch in my car for about a year now and it's doing awesome. Much more grabbing power than OEM and still has the same pedal feel.
  35. Member Norwegian-VR6's Avatar
    Feb 6th, 2002
    Norway
    08-11-2008 01:32 PM #175
    Southbend DXD Series Stage 3?
    Is that a complete kit?
