Results 1 to 14 of 14
Thread: Ignition Coil Replacement DIY (also for SAI removal) on a 2.0
  1. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    2001/VW/Golf 2008/VW/GTI
    04-24-2007 01:04 AM #1
    the story:
    I was misfiring on Cyl1 one morning about a year ago after a week of raining. After the car warmed up the misfire went away and all was fine. I thought maybe my wires were bad (I had 111,000 miles) so I replaced the wires and plugs and yet the problem persisted. Around 120,000 (6 years and the stock battery was still working!) miles I replaced the battery with a red-top and the problem went away... at least i thought it did. Driving home from my mom's house in Rochester NY I hit some cold rain and began misfiring in the middle of nowhere. VAG-Com on the side of the road revealed Cyl1. The car has 131,000 miles on it! Still running strong!
    Application:
    Ignition coil on a 2.0L AVH but it's pretty much the same on any other 2.0 and probably the VR as well, just a slightly different part.
    the DIY
    One:
    First thing you have to do is remove the secondary air injection pump. Well... I didn't "remove" it, I just unscrewed it and threw it on the intake manifold while still connected.
    Two:
    There are three 10mm bolts.
    Three:
    that one is hard to get to. Once you've unscrewed all the bolts you just got to jiggle it out of there. You don't have to disconnect the hoses and move it aside.
    Four:
    I think they were 5mm allens and that's all it takes. I took the coil out before I took out the spark wires because they're easier to get off. It's also easier if you remove that little wire organizer clip thing.
    Five:
    Once it's gone you can install the new one with the three allens. Put the plug wires back on and clip it back in.
    Six:
    You are done and if your SAI's top nut was broken you can use a zip tie
    Modified by jrowny at 1:05 AM 4-24-2007
    Nov 27th, 2004
    Charlotte, NC
    2000 VW Jetta VRT, 2000 Audi TT Quattro
    04-24-2007 01:36 AM #2
    Good writeup. I wish it were this easy to remove the SAI pump on a VR6
    Mike
    Chapter 11 Dubs: Member #001
    http://www.chapter11dubs.com
  3. Member vdubin85's Avatar
    Aug 30th, 2004
    Avondale, PA
    2001 Passat 1.8t, 2007 Jetta Wolfsburg, 1993 corrado SLC
    04-24-2007 07:51 AM #3
    good write up x2
    8 valve society member #158
  4. Member vasillalov's Avatar
    Nov 4th, 2003
    Chicago, IL
    2008 BMW 335i
    04-24-2007 08:09 AM #4
    Good stuff! ...but you are a little late
    Quote Originally Posted by MAG58 View Post
    Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
    A turbocharger is a device which exhaust gases go in, witchcraft happens, and then you go faster.
  5. 04-24-2007 08:45 AM #5
    Nice writup. ECS tuning cheap oil filters buy a case. there cheper then fram. do it.
  6. Member jrowny's Avatar
    Sep 11th, 2005
    Germantown, MD
    04-24-2007 11:34 PM #6
    Quote, originally posted by sarge1 »
    yea I know, but I ran out and was going on a road trip and my oil needed to be changed so I figured it'd be okay just once.
  7. 04-24-2007 11:37 PM #7
    Um 2.0 and VR6 have COILPACK's not COIL's. It'll never end.
    Nice from forum sponsor, hope you run your business with better morals.
    Quote Originally Posted by Brendan@bwalkauto View Post
    Stole my first love from her b/f, and yanked my currently lady from someone else. Who cares.
  8. 11-03-2007 06:27 PM #8
    Thanks very much for the DIY. It enabled this girl to do the repair herself
  9. 03-09-2011 11:16 AM #9
    I know this is an old post. I have a 2003 VW Golf GLS with 2.0l engine. The ignition coils went bad two times already on it for the last 6 months. I saw when my mechanic was reading the codes that showed the particular cylinder. So, I paid once and don't want to say how much (tooo much!). Now, the check engine light was on again and it was another cylinder code. I paid again tooo much.... The guy said you need to replace two ignition coil but for now one will be ok, let's see how it goes then. In about a month, the light went on, the engine was shaking when I started it.
    Now, the question is I started looking on the web to buy the part myself and saw for the 2.0l engine it is the coil pack not the individual ignition coils. So, how it was possible to replace them idividually as the mechanic was telling me? Was the first replacement the fix for all four cylinders? The mechanic told me I need to buy the individual ignition coils. What I see on the web these are for the 1.8l engines. I am very confused. I guess, the only way to do it is to open the plastic cover on the block and see where the wires go??????
  10. n00b
    Feb 21st, 2009
    CT, USA
    2000 Jetta 2.0
    05-25-2011 05:04 PM #10
    I know the thread is old, but it took me 3 days to find. Thanks to jrowney for a great write-up and clear pictures. Just what I was looking for.
  11. n00b
    Feb 21st, 2009
    CT, USA
    2000 Jetta 2.0
    06-06-2011 07:42 PM #11
    Thanks again to jrowney for the write up & pics. I was about to have the garage do the job, he would have charged me $150 for the coil pack (Autozone wanted $143 & tax) and at least an hr. labor at $80 per. I found this thread, bought the OE coil pack online for $53 & $10 s/h. Did it myself and saved a bundle. I did have to remove the bracket holding the secondary air intake pump to get at one of the bolts but except for some frozen bolts that I had to JB Blast a couple of times and tap with a hammer, it was a cinch thanks to your thread. Would have only taken maybe 20 min. if not for that.
    Funny thing is that the same damned bolt broke when I did it, so I even did the old zip tie like you did. Anyway, running good now. Hopefully it stays that way for a while.
  12. n00b
    May 8th, 2011
    2002 NEW BEETLE 2.0 GAS
    06-29-2011 08:37 AM #12
    Hey rico. Where did you find the coilpack online for $53? Thanks
  13. 02-17-2013 11:36 AM #13
    I just wanted to say thank you for posting such great step by step instructions. I was able to replace my plug wires and coil in about 2 hours.
    Thanks again!
  14. 06-07-2013 03:21 PM #14
    to anyone still having problems: use JB weld to seal the cracked coilpack.. worked for me. $5 fix
