VWVortex.com - Changing thermostat on 2000 Jetta 2.0
    Results 1 to 4 of 4
    Thread: Changing thermostat on 2000 Jetta 2.0
    1. 04-27-2007 02:33 AM #1
      My friend's Jetta is overheating, the top radiator hose is hot and the lower is cold. Heater blows cold. I'm almost certain it is the thermostat.
      Unfortunately, every time I look for a guide, the pics are different. Were it my car, I would just mess with it, but it isnt and I want to get it right first. Is it where the top radiator hose meets a plastic housing with an electrical connection? This is on the driver's side of the engine block and the top radiator hose enters it, and the heater hose leaves it.
      If anyone has any tips on how to do this or things to look out for, please let me know.
      Thanks in advance.
    2. 10-03-2007 10:58 AM #2
      Bump... anyone have a DIY for this?
    3. Member MikeWire's Avatar
      Oct 20th, 2003
      Montana
      Air and water
      10-03-2007 11:36 AM #3
      Yep. If you have a 2.o then you need to cruise the 2.oL forum as well as the MKIV - the DIY you need is in the DIY/FAQ.
      http://forums.vwvortex.com/zerothread?id=1730221
      Pics don't work, but the procedure is there. It's really pretty easy - just remember to use G12, not the green stuff. And get distilled H20.
      Good Luck!
      I should add that the thermostat is right below cylinder #2 on the front of a 2.0.
      Modified by mross71 at 9:54 AM 10-3-2007
      2014 VW Passat TDI SEL Premium 6sp DSG | 2010 VW Jetta TDI 6sp DSG | 1992 VW Montana Green GTI | 1982 VW Caddy 1.8 | 1980 VW Lago Caddy 1.8 JH swap | 1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC
    4. 10-03-2007 12:13 PM #4
      Pics work OK for me.
