VWVortex.com - wanted: fuse panel diagram
    Results 1 to 15 of 15
    Thread: wanted: fuse panel diagram
    1. 04-30-2007 08:24 PM #1
      my 1988 FOX GL is dead... wont start, battery is good, maybe the starter solinoid? i hope not.
      I need a diagram of the fuses (cuz my cover is missing and i'd like to know what each fuse and relay do. PLEASE HELP HER or it goes to the junk yard.
      thanks!!!
    2. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      04-30-2007 10:28 PM #2
      Quote, originally posted by untitled »
      So if we don't help, us east coast foxers can pick at the carcuss for free? Thanks!
      | œ Orchid Euro Importation œ |
      Currently driving or working on too many cars...
      | '93 Fox 16v - PVW | '99 Greenland Polo Diesel | '89 Rallye Golf | '83 Golf GTi RHD | '75 Swallowtail |
      | '82 Caddy 1.9D | '85 VW LT Car Transporter | Mk2 Jetta Limo | '90 Jetta 8V | '96 VW LT35D | '03 SpintLT35 | '02 GTI 337 | '03 GTI 20v |
      | '09 Aprilia RS125 | '81 Kawasaki AR80 | '59 NSU Quickly | '64 Honda Cub C65 + '65 C105 | Trek Emonda SLR9 | Trek Crockett 9 |
    3. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      04-30-2007 10:38 PM #3
      Nah, just kidding.. sorta..
      Here's a thread i made with every fuse on the panel listed
      Hope this helps [IMG]http://*****************.com/smile/emthup.gif[/IMG] I also have a spare fuse box cover that i would sell cheap, just in case you wanted to get fancy or something
    4. 04-30-2007 10:53 PM #4
      This from 1988 owners manual. No info on relays though.
    5. 04-30-2007 10:59 PM #5
      thanks!! that was quick.
      p.s. if the car was at my home... yeah ya could pick the carcass, but its stck in a parking lot 10miles fom my house.
    6. 04-30-2007 11:08 PM #6
      oh. any ideas for the non starting situation? it just clicks, alt is new, batt is good... what else, is there an ignition relay? i cant change/pull the starter or solinoid, in the parking lot. and a tow aint worth the $$$.
    7. 04-30-2007 11:23 PM #7
      the brit has a tow-dolly. don't tempt him.
    8. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      04-30-2007 11:28 PM #8
      Hack starting testing in a parking lot:
      Make sure the ground wire for the engine block is good. If in doubt, use a jumper wire from the block to the -ve to make sure it is. If it isn't, fix it.
      Nicely insulated screwdriver - reach under your exhaust, pull off the little black connector going to the spade terminal on the starter, bridge that spare to the big bolt/nut connector on the starter. It will turn over and make you jump everytime. Don't get your hands in the way, and don't use a sold piece of metal with your hands on the metal
      Battery good? If not, bump / jump start.
      Don't want to jump the starter, bump start.
      Don't want to pull the ignition switch to check the 'start' postion? Bump start
      You can pull the back off of your ignition to test the switch, but if you don't know how to do it, i'm afraid i'm not going to post how on a easily google searchable public forum...
      Modified by the brit at 11:29 PM 4-30-2007
    9. 05-01-2007 09:59 AM #9
      thanx brit.
      I was going to jump the starter tonight. but if the starter is shot it still wont work right? a push start is my only option then if that happens.
    10. Member
      Apr 4th, 2002
      Livermore, CA
      99 B5: RIP, 89 Fox Wagon, 89 Jetta GL, 2000 & 2005 Suby Outbacks
      05-01-2007 10:28 AM #10
      Well for the love of...
      1. Turn the ignition on. (Not to 'start', just 'on' like you're driving.)
      2. Select neutral and release the parking brake.
      3. Open the door, get out, and put your shoulder to the door frame.
      4. Push until you're going about 2 mph.
      5. Jump in, put in the clutch, select 1st gear, and quickly release the clutch.
      6. Give it some gas, shift and steer as necessary, and go home...
      Easy as cheese.
    11. 05-01-2007 11:46 AM #11
      Quote, originally posted by snowfox »
      Easy as cheese.
      you might try 2nd gear, i killed my battery at college one day and got it going at a good clip and put it in first. it only made the front wheels lock.
      Apr 4th, 2002
      Livermore, CA
      05-01-2007 12:43 PM #12
      Quote, originally posted by tbt10f »
      I'm talking about a slow walking pace, not a good clip. If you have some extra hands to help you push (i.e., go more than a mile or two per hour), a higher gear would be good.
    13. 05-02-2007 10:15 PM #13
      ^^^ whats with the sarcasem? i know how to do this... not that i've HAD to ever jump the solinoid b4 so the instruc"s by brit were much appreech.
    14. Member
      Apr 4th, 2002
      Livermore, CA
      05-03-2007 10:23 AM #14
      None intended, but I didn't think you knew how to do this because of the earlier statement:
      ...but its stck in a parking lot 10miles fom my house.
      Maybe it's just my personal choice, but I wouldn't leave my car sitting or have to call someone for a ride if I could somehow get the beast rolling, whether the starter was helping me out or not.
      Sorry-
    15. 05-08-2007 12:32 PM #15
      ^^^ it's cool man! the parking lot was pretty crowded and i didnt want to deal with kids crossing peep's backing outta spots etc. so i left it. it's safe there... and my fox is nothin to look at anywayz.
      APB I'm done with it so if you can move it. you can have it clean NJ title and all. It's in South Orange NJ.
