Results 1 to 7 of 7
Thread: Save yourself $60 - make your own MSD 8920
  1. 05-07-2007 08:12 PM #1
    Just take this schematic:
    http://www.msextra.com/manuals...o.GIF
    and put it inside a gutted relay:
    87 to MSD tacho out / megasquirt tach out, 30 to ground, 85 to red/black tacho wire, 86 to switched 12v positive / positive coil lead.
    Unfortunately, I'm getting static from the radio (even when it's playing a CD!) and I don't know how to fix it - I'm no electrician. All the connections were hot glued so they wouldn't rattle and touch. The tach works perfectly, however.
    Modified by jettaflair at 5:14 PM 5-7-2007
  2. Member g60manny's Avatar
    Feb 6th, 2006
    Santa Ana, Ca
    B8 A4 Audi, 1977 Rabbit
    05-08-2007 12:31 PM #2
    but where do you get it
  3. 05-09-2007 03:08 AM #3
    make it
  4. Member
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    05-09-2007 09:51 PM #4
    what does it do?
  5. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    05-09-2007 11:15 PM #5
    Quote, originally posted by antichristonwheels »
    what does it do?
    Allows you to run a square wave tach output into a tach made for a spiking coil signal type output.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  6. Member Ultraflux3's Avatar
    Mar 14th, 2003
    Front Range
    90 Corrado 1.8 T
    06-12-2012 08:19 PM #6
    Bringing it back up. Has anyone successfully made this?
    I can't seem to find out what the 2H5551 is it looks like a diode in the schematic, but I can't find any diode with that number.
    I would rather spend $5 than $60-$80.
    Corrado
  7. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-14-2012 09:27 AM #7
    It's a transistor and a common 2N2222A works fine. You will want to gut the relay contacts to get rid of the buzzing.
    -Paul
