VWVortex.com - DTC P0327: Knock Sensor
    Results 1 to 5 of 5
    Thread: DTC P0327: Knock Sensor
    1. 05-08-2007 01:07 AM #1
      I don't know if I posted this in the wrong section but I just got my 2001 VW Jetta 1.8T out of the shop for all new valves, head machined, and new timing belt. So I'm now getting this trouble code: DTC P0327 Knock Sensor Circuit Low Voltage . What I want to know is does this mean the sensor is bad or possibly timing issues? I did a search and pulled up posts with OTHER problem codes attached. I only have this problem code. All tips and suggestions I'd REALLY appreciate!
    2. 05-08-2007 11:21 AM #2
      bump
    3. Banned
      Nov 1st, 2005
      05-08-2007 12:44 PM #3
      I've heard of the cam chain tensioner thingy either going bad or not being re-installed correctly can cause knock sensor codes.
      I'd still wait for somebody that knows for sure though.
    4. 05-08-2007 10:13 PM #4
      Thank U!
    5. Junior Member
      Mar 8th, 2004
      Ottawa, Canada
      Passat '06 4motion
      01-11-2008 09:48 AM #5
      Any updates about the issue? The shop also did the timing belt on mine, valves and head machined. I end up with the same knock sensor error as you.
