Results 1 to 22 of 22
Thread: Yellow wax dripping from my doors!
  1. 05-09-2007 04:26 PM #1
    When the weather heats up my car will leak a yellow wax (cosmoline) from the doors. It screws up the rubber moldings, and makes a mess all over. I've taken it to the dealership. They told me it's a common problem w/ black vws. It is used as a rust proofer. They fixed it under warrenty, but my warrenty is about to expire. Its a total defect and i don't want to come out of pocket fixing it in the future. Has anyone had a similar experiance? Is there a permanent fix? Also does this wax damage the paint? if it doesn't scraping it off does
    Modified by FLYGTI325 at 1:31 PM 5-9-2007
  2. 05-09-2007 04:57 PM #2
    It's not gonna hurt your paint and it's not a defect. It's actually quite ingenious to use something as pliable as wax to rustproof body panels. It is a minor annoyance but a mild degreaser to remove what's been caked on and then ironically enough a good coat of wax on the rocker panels will keep it from caking as much.
    Keep your car cleaner!
  3. 05-09-2007 05:08 PM #3
    thats the thing...my car is freshly detailed, thats why Im so annoyed. and it is a defect because when it leaks, it disfigures and unglues the rubber moldings on the underside of the door.
  4. Member IFlyGTI's Avatar
    Feb 26th, 2001
    Sacramento area, CA
    2003 20th Anniversary GTI, 1966 Variant, 1976 Bunny, 1996 GTI VR6, 1991 Variant
    05-09-2007 07:02 PM #4
    Ahhh... You can always tell when summer is coming by the leaky door syndrome. My JB does it too. Nothing to worry about.
    Mike S. SacWater
    '03 20th Anniversary - '96 GTI VR6
    '91 B3 Variant - '76 Mk1 - '66 T3 Variant
    *Duc*Duc*Hawk(GT)*
    The Ranch Run - Wuste2012 "Cogito, ergo zoom!" RIP David E.
  5. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    05-09-2007 08:30 PM #5
    It is normal for the hotter places to have this happen, it isn't because your car is black, it is because your car is under the sun...
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
  6. Member redsoxreturns's Avatar
    Oct 17th, 2004
    IY 3590; 2007 SRX
    05-09-2007 10:48 PM #6
    its called cosmoline
    Big Bopper to March Hare..We're still in the game okay? Understand this, that scag, and his floozy....They're gonna die!
  7. Senior Member bluebora20v's Avatar
    Jun 14th, 2001
    Bay
    2000/VW/MK4 Jetta
    05-10-2007 12:06 AM #7
    It's 10000% normal. The dealership should have laughed at you and told you to go buy some bug and tar remover. You should THANK VW for protecting your car from rusting from the inside out. Big deal, you have to wipe it off every now and again. EVERY COLOR VW will have the same issue if it gets warm enough so I have no idea why they made up that bull**** excuse. You're a fool if you think warranty should cover this. Pay out of pocket? For what? To wipe it off? Since the dealership didn't do it, it will... Hahaha.
    Modified by bluebora20v at 9:07 PM 5-9-2007
  8. 05-10-2007 12:19 AM #8
    My last Jetta did that, since it was all black and just a 2.slow i didnt care, but yes i think its common but crappy thing to happen.
  9. Member A.Fine's Avatar
    Jul 31st, 2003
    Los Angeles
    03 GTI 24V
    05-10-2007 11:04 PM #9
    I feel your pain , ha and the summer has just began
  10. 05-10-2007 11:24 PM #10
    mine is still there from last summer... its not a big deal
  11. Member JettaGetUpandGo's Avatar
    Mar 1st, 2005
    Brookfield, WI
    2005 Jetta GLI, 2011 Xterra Pro-4X
    05-11-2007 12:11 AM #11
    I've never seen this happen on my PG GLI, but then again I live in Wisconsin. If this is a sealant used inside of the doors, shouldn't there be some sort of seal to prevent it from leaking outside of the door? I don't know exactly how it happens. Obviously it's the wax in the door melting due to high temperatures, but where exactly does it leak out from?
    I'm doing work. (Build Thread) | VCDS Scans / Tweaks in the Waukesha / Milwaukee area for $5 or a 12-pk of Mountain Dew | MK4 Remote Window Control for $20
  12. 05-11-2007 12:17 AM #12
    it comes from inside the doors, seeps out of the rubber moldings on the under side of the door. it would not be a big deal if it didnt mess up the rubber. If VW knows that all mkIV's do this, why would they not fix the problem?
  13. Member Dub Ken's Avatar
    Dec 24th, 2004
    Long Island, NY
    '03 VW 20th Anniv. GTI
    05-11-2007 12:53 AM #13
    Quote, originally posted by Code3VW »
    Funny as it may sound, it's more common on black cars because black absorbs more sunlight and heat than any other color.
  14. 05-11-2007 12:55 AM #14
    Quote, originally posted by Dub Ken »
    Wow.... to my father, who never said I would learn ish on VORTEX.
  15. 05-11-2007 01:01 AM #15
    this is very true
  16. Member IFlyGTI's Avatar
    Feb 26th, 2001
    Sacramento area, CA
    05-11-2007 04:23 PM #16
    Quote, originally posted by FLYGTI325 »
    it comes from inside the doors, seeps out of the rubber moldings on the under side of the door. it would not be a big deal if it didn't mess up the rubber. If VW knows that all mkIV's do this, why would they not fix the problem?
    Actually, it comes out through the holes in the bottom of the door that let any excess water the leaks past the scrapers out. As far as VW fixing it, first they would have to actually consider it a problem & not just a nuisance.
    Mike S. SacWater
    *Duc*Duc*Hawk(GT)*
  17. Member SSN-681's Avatar
    Aug 7th, 2002
    Meriden CT
    2003 20th AE GTI
    05-12-2007 08:00 AM #17
    I used a hair dry to warm the wax so it will start to melt and it was easy to clean off my wifes jetta. Its a 2000 and it still leaks it on occasion.
  18. Member 20thgirl#1499's Avatar
    May 16th, 2007
    Phx
    Bmp 20th
    05-17-2007 02:33 AM #18
    GRRR!! The wax is sooo annoying!! So there is nothing to do to stop it??
  19. Member APR'dGLI's Avatar
    Jan 13th, 2005
    Langangster PA 17601
    2004 Jetta GLI (sold but not forgotten) 2000 Jetta GLX, 2011 Reflex Silver 2.5se
    05-17-2007 11:28 AM #19
    yea it happens it goes away though after it happens once....so no swet
    Poop
  20. Member VWReza's Avatar
    Aug 3rd, 2006
    Oak Hills, Ca
    08 Rabbit,10 Cube
    05-17-2007 01:33 PM #20
    You can do one thing. move to a better climate! Gotta love San Diego!!!!!
  21. Member 20thgirl#1499's Avatar
    May 16th, 2007
    Phx
    Bmp 20th
    05-17-2007 01:39 PM #21
    Quote, originally posted by APR’dGLI »
    What do you mean it only happens once? Mine has been leaking for months....
  22. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    05-17-2007 02:13 PM #22
    This is negotiable.
    The heat differential between a black car and any other color is small, and with the summers here getting to 120 degrees, I see VWs of all colors with the cosmoline tear-streaks.
