VWVortex.com - Why is there not a comprehensive coolant flush DIY?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 47
    Thread: Why is there not a comprehensive coolant flush DIY?
    1. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      2001 Audi TT Quattro
      05-15-2007 04:15 AM #1
      I want to flush my coolant soon because i have 92k miles and I want to flush it because I am not sure if the PO did it or not. I have read some of the archives, but I would like a comprehensive guide so I can make sure I don't screw anything up. I know I need a 50/50 mix of g12 and distilled water. The radiator drain valve is on the driver's side. I should flush the system when the car is completely cold. I should also open the radiator overflow cap so that air can escape too I think??? Cmon guys help me out. I have done as much research as I can at this point.
    2. 05-15-2007 09:22 AM #2
      bump this up!
      I was also searching for exactly this last night !
    3. 05-15-2007 10:36 AM #3
      I too would like to know, free bump!!!!!!!!!
    4. 05-15-2007 10:57 AM #4
      I'm pretty sure I read you just run water through the system with the engine idling and allow that to flush through for a few minutes. Then drain and refill with coolant/water mixture.
    5. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      1980 VW Scirocco, 2004 Audi A6 S-Line 2.7T
      05-15-2007 11:17 AM #5
      Heres your DIY:
      Open the drain on the bottom of lower radiator hose where it connects to the radiator.
      Let it drain out
      Start the car and put a hose in your coolant ball and let it cycle through until the liquid coming out of the drain is 100% clear water
      Turn hose off
      When water stops flowing out freely, shut valve
      Fill coolant ball with coolant/water mixture until full
      /thread
    6. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      05-15-2007 01:07 PM #6
      I don't want to run hose water through my engine. I might just go pick up like 10 gallons of distilled water from kroger. Are you supposed to open any top cap of the radiator to let air release or not?
    7. 05-15-2007 01:27 PM #7
      I'd trust WhiteG60's suggestion. you aren't going to get deposits running with tap water for that short of a period of time.
    8. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      05-15-2007 03:17 PM #8
      Correct. The water isn't going to even have time to get hot. Its gonna flow out warm.
    9. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      05-15-2007 03:55 PM #9
      Quote, originally posted by WhiteG60 »
      ok thanks man. I will try and get this done next week. Anyone know how much a jug of G12 is at the dealer these days?
    10. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      05-15-2007 04:24 PM #10
      I see them online for ~ $17 total. If you're going to do it next week, just get it from GermanAutoParts.com got $17 + shipping. Dealer is ~ $26 if i'm not mistaken.
    11. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      05-15-2007 04:29 PM #11
      thanks for all the help. Ive been meaning to do this for awhile.
    12. 10-26-2007 02:33 PM #12
      i know it's an old thread, but I found this DIY on blauparts.com and it seemed very thorough.......
      How To Change Engine Coolant On A Vw 4 Cylinder (1998 - On) :
      1. When the engine has cooled down, remove the Vw coolant tank cap.
      2. Draining the Vw coolant from the 4cyl cooling system:
      Remove the lower radiator drain plug from the lower front of the radiator (Vw A4, Vw Passat). Remove the passenger side lower radiator hose. Remove the outer Vw coolant hose that connects to the oil cooler. To drain the heater core you'll need to remove the hose on the coolant flange or transfer pipe located on the back side of the engine. This hose goes from the cylinder head to the heater core.
      3. After the system is done draining, put the Vw coolant tank cap back on. Carefully work off and remove the smallest hose that is connected to the top of the Vw coolant tank. Be careful, the tank nipple likes to crack and break off.
      4. With a blow gun and compressed air on low, carefully insert the blow nozzle into the small hose. Wearing safety goggles, carefully force the air out so that any Vw coolant that's still trapped in the cooling system is released.
      5. Reinstall the Vw coolant drain plug. Reinstall the coolant tank hose(s). Fill the Vw cooling system with distilled water. Start the car and air bleed the cooling system as outlined in the factory Bentley manual. Run the car until the cooling fan comes on.
      6. Repeat steps 1 through 5 until the water comes out clean.
      7. Verify that you have the correct anti-phospate anti-amine G11 or G12 Vw coolant. If it's full concentrate, mix a 50/50 ratio per the Bentley manual. Fill your Vw cooling system with this 50/50 mixture. Note: Some factory Vw coolants sold by dealers are already premixed and do not require further delusion.
      8.Run the 4cyl engine and check for any Vw coolant leaks.
      9. Top off the coolant tank to the fill line. Do not overfill.
      10. Using a permanent marker, write 'G11 or G12 Coolant Only' on the Vw coolant tank.
      11. (optional) Be environmentally responsible and dispose of your old Vw coolant properly.
      Vw Coolant System Maintenance:
      1. Never top off the coolant tank with full concentrate G11 or G12 Vw coolant. Your Vw coolant should never exceed a coolant ratio of 80%. If it's over 80% an inefficient Vw cooling system will result, decreasing flow through the radiator along with poor heat transfer through the engine block.
      2.Always top off your Vw coolant tank using a 50/50 mixture. If you're in a pinch and don't have any, use a small amount of distilled water. Remember, adding large amounts of water will change the alkalinity of the Vw coolant and throw off the glycol to water ratio, making it less effective in cold temperatures.
      3. Never mix G11 blue coolant and G12 red coolant. It will turn into a brownish goo and plug up your Vw cooling system.
      4. We highly recommend flushing your Vw's coolant when replacing your timing belt.
      found it here..http://www.blauparts.com/vw/vw_fluid/vw_coolant_engine_fluid.shtml#vw4clycoolantchange
    13. Member
      May 21st, 2005
      2016 Golf R DSG DCC NAV Lapiz Blue
      12-06-2008 01:45 PM #13
      I plan on doing this today. How much G12 do I need to do this job? I didn't realize this was so in-depth. I pulled a P2181 code "Coolant Performance System", and just bought a new coolant temp sensor. Next step is to drain + add new coolant. Any other advice would help.
      Mike
    14. Member TmoeJ747's Avatar
      Oct 9th, 2007
      Westfield
      3076r 01 jetta, 04 GLI parts car
      12-06-2008 05:43 PM #14
      i would also suggest replacing the thermostat as well. you have to drain the coolant to change it anyways, and your code could also be caused by a stuck open t-stat (i believe).
    15. Member herb2k's Avatar
      Jul 29th, 2007
      Vancouver, BC
      2001 GTI 1.8T, 2006 Jetta 2.5L
      12-06-2008 10:14 PM #15
      I did mine a few months ago, because the shop that replaced the thermostat mixed some green coolant into the system.
      You only need 1 jug of G12 for the 1.8T. Mix it 50/50 with distilled water and you have enough for the whole system (and some left over for topping up).
      I didn't have to disconnect any rad hoses, since I had my thermostat replaced already.
      Simply open the drain at the driver's side of the rad, open the lid for the coolant bottle, and wait for it all to drain out. There is no radiator cap in the MK4 cooling system as it is completely sealed.
      You can do a flush with some of that cooling system flush stuff, or just flush it with hose water and engine idling (helps to have anther person to work with).
      Here's what I did:
      Drain and fill with hose water as described above. Close off the drain cap once clear water runs out of the system.
      The cooling system flush stuff I used said to run the engine for about 10-20 mins to allow it to work its way through, also make sure you run the car's heater at full blast so that coolant is allowed to run through the heater core.
      Drain out all of that stuff (it's pretty soapy) and flush with hose water until it runs out clear from the drain port (with engine idling).
      Start filling it with your G12 mixture, but leave the drain port open until you see only bright pink G12 flowing out, then close it up and top off the system.
      Make sure to dispose of the old G12 coolant properly, and you're done. Took us about 3 hours taking our time and making sure all the gunk was flushed out.
      Modified by herb2k at 6:15 PM 12-6-2008
      Modified by herb2k at 6:17 PM 12-6-2008
    16. Member
      May 21st, 2005
      12-07-2008 09:24 PM #16
      thanks for the input. How big is the 1 jug of G12 I need for the 1.8T? A gallon? I see different sizes listed on ecstuning.com
      thanks, Mike
    17. Member herb2k's Avatar
      Jul 29th, 2007
      Vancouver, BC
      12-08-2008 02:20 PM #17
      Yep, my bottle from the dealer was 1 gallon.
    18. Member
      May 21st, 2005
      02-26-2009 09:43 PM #18
      Doing this on Saturday. Do I need to remove my front valence to get at this drain?
    19. 02-26-2009 09:58 PM #19
      No, the lower rad hose is farther under the car and has no direct interaction with the bumper/valance.
    20. Member
      May 21st, 2005
      02-27-2009 08:55 PM #20
      hmmm... Is there a pic someone can point to the radiator hose I'm supposed to remove? How about reattaching it? Is there a cable or fastener I'm supposed to reattach?
      I bought the gallon of G12 and 1 gallon of distilled water. Plan on doing this in the morning.
      Thanks, Mike
    21. 02-27-2009 09:30 PM #21
      Quote, originally posted by scrappy62 »
      Thanks, Mike
      the bottom hose............theres one 2 hoses total, top and bottom
    22. 03-09-2010 03:58 AM #22
      Hey guys,
      I am looking for some diy info on draining my jetta 2.5 mkv coolant. I read on this thread that you just let the old coolant drain out of the lower radiator drain. What about the coolant that is in the engine block? does this old coolant also drain out from the radiator drain?
      I am asking this because on my previous car (honda accord), you had to remove a drain bolt on the engine block in addition to the drain plug on the radiator in order to completely drain the system. Otherwise you only drain half the old coolant in the system. which leads to old coolant left in the system. Also an improper mixture ratio of new g12 to water in the system, especially if you are flushing the old coolant out with garden hose water. either way you are screwed.
      Basically what i need to know is if you remove the drain hose/plug from the radiator does the entire coolant drain out.
    23. 03-21-2010 03:55 PM #23
      After reading through these posts it seems that when you drain the system and run hose water through, the engine will drain also while car it at idle meaning you get the bulk of coolant drained first then run the hose water and start motor and allow system to cycle through untill water flows clear. Close cooling system and fill with G12(apprx 1Gal) then top off with water or coolant.
      This Good?
    24. Member hootyburra's Avatar
      Feb 19th, 2007
      Bloomsburg PA
      337.sold 2.slow
      03-21-2010 08:57 PM #24
      saving this for spring car work weekend
      CTS 3076 kit, CTS 750hp FMIC, CM FX400, 2L, AEB, RMR IM, Raxles, Eurodyne, 870's...
      Vag Scans, pm me
    25. 04-10-2010 10:30 PM #25
      Would these instructions work on a 1999.5 2.0 automatic?
