Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: How to Reset Automatic Transmission
  1. 04-15-2002 12:51 PM #1
    Does anyone know how to reset the Automatic Transmission. I pulled some plugs last night while I was cleaning (no water) the engine, and the CE light came on and now the tranny changes gears at 4000. I read one time that MKIVs have an adaptive automatic transmission that can be reset to the driver's style. Does this apply to my '98 GLX?
    I tried making a search, but I couldn't find anything.
    Any help would be great.
  2. 04-15-2002 02:58 PM #2
    You didn't get any results to your search, because the automatic transmission is rarely referred to on this forum. Lucky for you, I have have one, as well as a Bentley
    Here's the info from that:
    Ignition on (not engine)
    Gas pedal down all the way for min. of 5 seconds
    Ingition off
    Or you can use the vag-com. Hopefully this helps?
    [Modified by Frankenwagen, 2:01 PM 4-15-2002]
  3. 04-15-2002 03:07 PM #3
    so at what rpm point does either of your Vr6 auto trannies shift at...? and what's the normal shift points also..?
  4. Member RonN's Avatar
    Feb 15th, 2001
    Memphis, TN
    '02 Audi TT 225 QC APR S3+, '11 VW Touareg TDI Sport
    04-15-2002 03:27 PM #4
    1. Put your key in the ignition and turn ignition to the on position (the position right before you start the car)
    2. Hold down the gas pedal pressing the button under the pedal for at least 20 seconds.
    3. Let foot off pedal and start car. Be sure that you do no turn ignition off because that will void the reset
  5. 04-15-2002 04:02 PM #5
    Awesome, thanks Frankenwagen and FastVR6VW for your help.
    I am going outside right now....good to know there are some helpful dubbers out there I can count on.
  6. 04-15-2002 04:18 PM #6
    dr()opy......
    shift points vary depending on the amount the throttle is depressed, as well as the "mode" the transmission is in (there are two, equating to 'sport' and 'econo').
    Under passive/normal driving it shifts soon (especially out of 1st), and under hard driving it shifts later, but still quite quickly out of first (unless you are literally flooring it).
    hope this helps a little.
  7. 04-15-2002 04:49 PM #7
    so how do u put it into "sport" mode? I heard about this a while ago.
  8. 04-15-2002 04:50 PM #8
    Thanks Frankenwagen.....! for your reply..!
  9. 12-19-2003 08:52 PM #9
    Just wanted to update this for the archives because this post seems to conflict with most of the other ones I've seen on this topic.
    I used the procedure where you turn the ignition off after you hold down the pedal, and that worked. I took the key out and then put it back in and restarted the car and it still held the reset.
    Maybe it does work if you just start the car after the 20 seconds also, I wouldn't know and can't try it being that my car is OK now. But from my experience, turning the key off does not void the reset.
    I have a 2002 Jetta TDI wagon automatic. I just started having problems around 39,000 miles, in reverse and 1st gear. Reverse seemed like it didn't want to engage, but reading other posts, it just takes longer than normal when the adaptive transmission settings are messed up. In first gear, it would lurch forward when I just touched the accelarator, but was fine in the other gears.
    Good thing I found the posts on this reset procedure, everyone should know about this. I was ready to schedule an appointment, and it's Christmas week, and I didn't need the hassle of begging the dealer for an emergency appointment, and being without my car for a day or two when I have so many things to do.
    Also, just realized that the transmission is a closed system, you can't check or add transmission fluid like most cars. Why can't they just put a note about this in the index so you don't have to go through hoops to find this out? I had 5 of my co-workers baffled on why we all couldn't find the transmission dipstick!
    Maybe it's in the service manuals somewhere, but if it is, it should be easier to find.
  10. Member Fantomasz's Avatar
    Aug 14th, 2001
    EU
    Golf V 2.5 auto
    12-19-2003 10:22 PM #10
    so how long keep foot on pedal? what happen if I hold longer? will not reset?
  11. 12-20-2003 06:22 PM #11
    I think it's just a minimum of 20 seconds to activate the reset so you don't do it by mistake.
    I imagine it wouldn't make a difference how long you keep it pressed past 20 seconds.
  12. 12-22-2003 03:15 AM #12
    Quote, originally posted by Frankenwagen »
    Ingition off
    The above is the alternate procedure to perform the transmission adaptation (synchronize to the throttle body) without Vag-Com.
    Now if you want to engage Sport mode on a Mk IV:
    Depress the gas pedal TWICE to activate the kickdown switch
    Release the gas pedal and Immediately start the car
    Notice how it shifts different?
    Modified by T99inFL at 3:16 AM 12-22-2003
    -T99inFL-
  13. 12-22-2003 04:15 PM #13
    thats good info, some other info we should all know is
    up, up, down, down, left, right, left, right , a, b, select start gets you alot of guys in contra.....
  14. 12-22-2003 04:46 PM #14
    Quote, originally posted by 86gtipos »
    Dude, it's B, A then Start (or Select Start for two players)
  15. 12-31-2003 09:14 PM #15
    Quote, originally posted by cnap »
    Agreed!!
  16. 05-12-2004 12:39 AM #16
    Quote, originally posted by hotpprs »
    the 01M, 09A trannies dont have the traditional dipstick, its a "sealed" tranny... you need to get the kit for the dipstick at the dealer, its a small tube that screws in the pan and when filling the transmission, check to see if there's fluid dripping out of there...
    01M Transmission, Checking ATF Level, Changing ATF
  17. 05-12-2004 12:41 AM #17
    Quote, originally posted by T99inFL »
    just curious on the bolded part, how long to hold the pedal down? same 20 second deal?
  18. Member VR6boi65's Avatar
    Jan 28th, 2004
    Atlanta, GA
    03 A4 1.8tqm, 03 24v turd (RIP), 84 GLI, 91 Maxima SE 5M
    05-20-2004 02:07 AM #18
    Does this reset system work with the 'ancient' 096 trannies from the 95 and earlier vr's?
  19. Member
    May 7th, 2002
    01 golf gls 1.8T
    05-20-2004 10:36 AM #19
    wondering if this still works (or makes any difference) w/chipped ecu?
  20. 03-20-2005 03:21 PM #20
    Quote, originally posted by DaFabolous2.0 »
    No, you just click the switch twice.
    Now does resetting the transmission put it back in economy mode, or does it reset to the basic sport programming?
  21. 03-22-2005 03:57 PM #21
    I tried the "sport mode" hack and didn't notice any different. I have a drive-by-cable, not drive-by-wire - does this make a difference? also must i start it instantly after releasing the gas pedal?
  22. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    2001 VW Jetta VR6, 2006 VW Jetta 2.5
    10-30-2005 04:28 PM #22
    just wondering, what would happen after driving around after doing the sport mode, and you shut off the car, then start it up again? would it be still in sport mode or would it reset back to normal?
    mujjuman
  23. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    10-31-2005 12:36 AM #23
    anyone bump please??
    mujjuman
  24. Member Thrasis's Avatar
    Feb 10th, 2005
    Wilmington, OH
    '10 Mazda 5 GT / '02 Beetle TDI
    10-31-2005 08:05 AM #24
    Will the sport selection (twice down) have any effect on a tiptronic?
    Going from a AWP 1.8t to a mazda 5 - feels like I'm stuck in mud.
  25. Senior Member mujjuman's Avatar
    Jul 29th, 2004
    New York
    11-01-2005 12:38 AM #25
    someone bump
    mujjuman
  26. Member PBWB's Avatar
    Sep 12th, 2004
    NoVA
    91 GTI, 97 GTI VR, 06 MkIV Golf
    11-08-2005 12:41 PM #26
    im interested in this too
    -Apple
    Articulated Speed Solutions FTW
    *******FS: Autronic SM4 standalone engine management********
    Quote Originally Posted by slcturbo View Post
    I dont care what you or anyone else "thinks" they have done. We're all just racing for fun on here whether you run 9's or 17's.
  27. Member Fantomasz's Avatar
    Aug 14th, 2001
    EU
    Golf V 2.5 auto
    11-09-2005 09:45 PM #27
    the best way to play with tranny is to recode transmission with vag-com.look at my thread.
    http://forums.vwvortex.com/zerothread?id=2063606
  28. 12-18-2005 06:00 AM #28
    is there a procedure like this for MK3?
  29. Member sworksguy's Avatar
    Apr 25th, 2002
    NC
    2002 VW 337
    01-02-2006 12:26 PM #29
    I did the "tap twice" step with our '00 VR6 Jetta 4spd, and all I can say is, "THANK YOU!" to those who figured this out!
    The car FINALLY works like I expeted it to, when we got it 5 years ago!
  30. 01-06-2006 04:23 PM #30
    Now, if I put my car into "sport" mode, and want to change it back to "Ecconomy" or "Normal" mode, how would I do that??
    Just asking in case I have to make another 5 hour road trip and don't want to waste gas.
    Thanx all.
  31. 02-14-2006 01:08 AM #31
    I think VW has complicated things. I've seen many cars (OLDER cars too) with the basic, Econo and Power mode (or Normal or Power Mode) switches. Why didn't they just do that??? All this programming with Adaptive tranny etc... what a nightmare. AND they don't tell you about it in the manual. There are times i was to drive slow, it should be just a flick of a button.
  32. 02-18-2006 12:50 AM #32
    95 Golf 2.0 4dr. i've been having this transmission problem which when i accerate to 3000rpm, it jumps to 4000. i tried the method it seems work~ i tried the sport mode, cant' tell if it kicks. going to have the golf checked tomorrow. first VW car. looking forward~
  33. 02-21-2006 07:37 PM #33
    All I can say is THANK YOU SO MUCH! Everyone with a MKIV Auto needs to know about this. Pushing the throttle 2 times didnt do anything, but the 20 seconds did. I didn't know my 2.0 could even go like that! Thank you so much, that has put a massive smile on my face.
  34. 03-07-2006 11:56 PM #34
    I did this procedure on my '03 Tip. I use tip 99% of the time.
    Am I imagining better faster smoother shifts ? (20 sec reset)
  35. 12-13-2011 02:31 PM #35
    I wonder the 20sec would work on my 2000 golf turbo?
