VWVortex.com - Maintenance Schedule for the GTI 2.0 (scans from the manual)
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: Maintenance Schedule for the GTI 2.0 (scans from the manual)
    1. 05-21-2007 01:35 AM #1
      Scans from my US-spec 2007 GTI 2.0t manual:
      Modified by svander at 3:44 PM 10-25-2007
    2. Member svander's Avatar
      Oct 31st, 2003
      Seattle Metro
      '11 S4
      05-21-2007 07:04 AM #2
      FAQd.
      Thank you.
    3. 05-21-2007 09:15 AM #3
      sweet thanks! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I'm going to just use this one as my '06 "GTI" (well, at least it came with a GTI) manual has about 5 models and engines to wade through
    4. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      2016 Mazda CX-5 2006 Volkswagen Jetta 2013 Ford Focus Electric
      05-21-2007 10:43 AM #4
      Thanks!
      I gotta remember this thread for the 1,000,000 people who ask when to change their oil or spark plugs. You'd think people could/should read this on their own but oh well.
    5. Member ssaffioti's Avatar
      Apr 9th, 2006
      '14 IS350, '00 F-150 V6 5MT, '30 Ford A
      05-21-2007 11:28 AM #5
      Wow, the timing belt replacement interval for the 2.0T is 120,000 miles! They must have just figured this out... My 2006 manual does not mention when to change the belt.
    6. 05-21-2007 01:15 PM #6
      Quote, originally posted by ssaffioti »
      maybe it's a lifetime timing belt for the '06!
      j/k
    7. Member adROCK319's Avatar
      Jul 5th, 2006
      VA 23322
      2012 Golf TDI 4DR 6MT
      05-21-2007 01:23 PM #7
      good thread.
      quite frankly, i'm surprised you didn't make it into a pdf.
    8. 05-21-2007 01:35 PM #8
      Quote, originally posted by adROCK319 »
      x2
    9. Senior Member syntrix's Avatar
      Aug 20th, 2000
      Little Rock, AR
      indeed!
      05-21-2007 01:50 PM #9
      It's safe to assume they use one schedule for the entire fleet?
      I noticed the 5.0 TDI in there.
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    10. 05-21-2007 04:05 PM #10
      good thread.
      actually, i was going to, but i figured it'd be easier to read this way, since there aren't that many sheets.
    11. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      05-21-2007 05:31 PM #11
      Quote, originally posted by syntrix »
      I would think so, what with the V8 TDI, 3.6L FSI and the 4.2L engine mentioned. I think it may also include the City Jetta in Canada (when it says 2.0L Canada only).
    12. 05-21-2007 06:45 PM #12
      Wait, this might be dumb, but does that mean oil changes are every 10k miles once you get past the first 10k miles? Or does that just not mention that you should still get one every 5k? I'm sure my car will let me know when I need my next oil change but I'd be pretty stoked if I was good for another 8k miles (I just had the 10k service done a couple months ago)...
    13. Member b0mb3r's Avatar
      Nov 9th, 2006
      Bear DE
      2012 A4; 2010 TDI
      05-21-2007 06:51 PM #13
      my dealer insists on oil changes every 5K... so far I been in for 5, 10, 15 and 20
    14. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      05-21-2007 06:56 PM #14
      Quote, originally posted by ZGerman »
      Your car may or may not tell you when your next change is due, and it may or may not be right when it does. If you read the schedule you'll see that oil changes are required every 10,000 miles. However my dealer set my car to message me at 15,000 cause they want the extra business.
    15. 05-21-2007 07:01 PM #15
      Go figure... I guess after having only American vehicles, I was just accustomed to getting oil changes every 3-5k miles.
    16. 05-21-2007 09:20 PM #16
      from what i can tell, all us-spec 2007 vw cars, but the beetle.
    17. Member
      Feb 1st, 2003
      Winston-Salem, NC
      15 Golf, 14 Ram Ecodiesel, 13 CC, 10 Tiggy, 07 Bunny, 98 TDI, 74 Thing.
      05-21-2007 09:33 PM #17
      Not surprising, but it doesn't make any sense, nor coincide with the information we got at the dealer. Take spark plugs for example on a 2.0T. Don't replace until 60K....then again at 80K and twice at 120K. The last schedule I read at the dealer said replace @ 20K, 60K, 100K, etc...Dust/pollen filter replace @ 40K, 80K and 100K. Is it every 20 or 40K miles? Make up your mind Vw. I wish they would make one clear, concise list that made some kind of apparent sense, and was actually coherent from the owners manual, to online schedules, to dealership schedules.
      BTW, I replaced a 2.0T timing belt last week @ 74K miles, and I definitely wouldn't wait until 120...it's easy for them to say 120K when they won't be footing the bill if it breaks at 100. With plastic impeller water pumps, it's probably a moot point anyway.
    18. Member FlyingTurtle's Avatar
      Mar 26th, 2006
      85 911 Carrera ROW, 14 F150 EB FX2
      05-21-2007 09:59 PM #18
    19. Member ssaffioti's Avatar
      Apr 9th, 2006
      05-21-2007 11:25 PM #19
      Quote, originally posted by veedubtek »
      How did the belt look? How many hours work to replace it on the 2.0T? Seems like it is very hard to reach. I've never replaced a timing belt before.
    20. 05-21-2007 11:29 PM #20
      Its very similar to a Mk4 2.0 t-belt, which is only a little different than a mk3 t-belt. The part that makes mk4 and mk5 a little trickier is the engine mount... you need to use a jack (and 2x4) to support the engine while you remove the mount... then you'll need to jack the engine up a little to help you reach the bolts.
      If you've never done a t-belt before... I'd say at least 4hrs. But I did the last t-belt on my mk4 in about 2hrs (including water pump).
      As previous poster mentioned... the water pump has a plastic impeller. As many past vw owners found, these break into little pieces. When you do the t-belt... DEFINITELY replace your water pump... and DEFINITELY get the upgraded one with metal impeller [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I plan on doing a t-belt DIY when I do mine. I figure with my current mileage, I'll be one of the first on here to have to do it... (38k miles now, prolly do the t-belt between 70k and 80k).
      Modified by digitalhippie at 10:34 PM 5-21-2007
    21. 05-22-2007 12:20 AM #21
      i'm definitely not waiting until 120k...i know on the b5, vw recommended 105k for the timing belt, but there have been multiple documented failures under that, with quite a few not much past 60k.
    22. Member
      Feb 1st, 2003
      Winston-Salem, NC
      05-22-2007 12:25 AM #22
      Quote, originally posted by digitalhippie »
      However, the mount sucks to remove in a mk5. Repair manual says to remove axles, exhaust, and a/c lines to safely lift the engine enough to remove the mount and calls for 6 hours labor time (it very well may say this on a mk4 as well, I never read the book for those...only consulted it this time as the mount was really fighting me). I didn't remove axles or downpipe, but did loosen the A/C lines and cussed most of the time. I'd like to do another one or 2 before I make any firm statements, but I'm guessing it to be a good 4-5 hour job for someone with experience...and I'm sure with experience will come nice little time saving tricks. I'll be honest, I'm not looking forward to the next one. The one thing I did like was Vw sells a complete kit now, including belt, tensioning roller (it is a true tensioning roller, no separate spring loaded or hydraulic piece), both idler rollers, and all hardware, making it pretty easy to get all the right parts needed.
      As for how it looked, there was appreciable wear, particularly on the teeth. Granted, this car has been run pretty hard (apr stage 2) most of its 75K miles, but on the flip side, has been majority highway miles. I'll never have my GTI that long, but I predict if I did I'd be changing mine at 60K with my driving habits.
    23. Member ssaffioti's Avatar
      Apr 9th, 2006
      05-22-2007 12:55 AM #23
      I wonder why they would design something that calls for all sorts of disassembly for a "routine maintenance part." Seems like a chain or gear-set would have been a much better choice. I have heard that timing chain guides tend to wear out, but what about timing gear-sets?
    24. 05-22-2007 08:34 AM #24
      Timing gears are noisy, and chains require maintence too (see VR6 timing chain guides).
    25. Member NJRoadfan's Avatar
      Sep 16th, 2006
      Northern NJ
      2013 Audi A4 2.0T quattro
      05-22-2007 08:54 AM #25
      Funny, my 2006 Bentley says that VW hadn't determined it at the time of printing. They used something like 70,000 miles as a recommendation (realistic unlike that 120k figure) and based it from the Audi A3 2.0T's service schedule. Maybe we should look at that car's service schedule, seems they haven't changed it 5 times.
      The Nice Car:
      2013 Ibis White Audi A4 quattro 2.0T - Have HEX+CAN VCDS, PM Me
      The Hoopty Beater: SOLD
      1987 Alpine White Audi 4000cs quattro "special build"
