VWVortex.com - GTI/RABBIT Amplifier and Sub Installation DIY
    Results 1 to 6 of 6
    Thread: GTI/RABBIT Amplifier and Sub Installation DIY
    1. Member cracKness's Avatar
      Feb 19th, 2007
      Margate, FL
      2007 CW Rabbit (RIP); 2016 CSM GTI SE
      05-29-2007 07:09 PM #1
      This thread is just to index and unite 2litrebully's 3 part DIY post on installing an amp, sub, and line out converter to his GTI (rabbit is pretty much the same). I finished installing mine on my rabbit, and though I had most of it done before I knew this existed, I still referenced it when finishing off. A BIG Thank you to 2litrebully - I know he wasn't the first or only one, but it's BY FAR the most detailed.
      PART 1 GTI Sub Amp and LOC Installation, 91 Pictures Total - 56k Beware!
      http://forums.vwvortex.com/showthread.php?3250477
      PART 2
      http://forums.vwvortex.com/showthread.php?3250541
      PART 3
      http://forums.vwvortex.com/showthread.php?3250572
      Once again, I had nothing to do with this, just making it easy to put on the DIY Sticky. Thank 2litrebully if/when you use this
      Last edited by LangsamKafer; 07-14-2014 at 04:38 PM. Reason: Updated old style URLs.
    2. 05-29-2007 08:35 PM #2
      Added.
    3. 12-17-2008 12:32 AM #3
      how can we go from 4 channels on the headunit and end up with 10 speakers? are there crossovers somewhere in the doors? are the outputs on the headunit full frequency? if i had an amp in my "premium" 09 GTI, where would it be??? thank you
    4. Junior Member Little6D6vil6's Avatar
      May 25th, 2006
      West Chester
      2011 VW GTI
      12-22-2008 12:23 PM #4
      Yes there are crossovers in the doors
    5. 01-06-2009 11:46 PM #5
      I know this is an epic revival, but how the hell do I hook up this:
      To this LOC I just bought:
    6. 05-16-2009 10:59 PM #6
      I recently installed my subwoofer and now the radio is not working. I am not sure whether or not is an electrical problem or a sotware issue with the codes. Please help.
