VWVortex.com - Difficult B6 Passat fault codes/Steering/ABS/ASR
    Results 1 to 6 of 6
    Thread: Difficult B6 Passat fault codes/Steering/ABS/ASR
      Apr 19th, 2006
      2010 Golf TDI
      06-03-2007 08:51 PM #1
      I have followed the process for clearing and resetting the Steering Assist/ABS fault codes. I have done all the steps several times and cannot get the faults to clear, although the VAG-COM indicates all is green during the testing phase.
      I followed these: http://wiki.ross-tech.com/inde...01.29
      and these
      http://wiki.ross-tech.com/index.php/02546
      And the faults will not clear. Any help would be appreciated!
      Here is the scan results, (non-fault sections removed):
      VAG-COM Version: Release 704.1
      Data version: 20070422
      Sunday,03,June,2007,17:47:17:25986
      Chassis Type: 3C0
      Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 53 55
      56 62 65 72 76
      VIN: WVWCU73C16P131129 Mileage: 30220km/18777miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      03-ABS Brakes -- Status: Malfunction 0010
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      0F-Digital Radio -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      1C-Position Sensing -- Status: OK 0000
      36-Seat Mem. Drvr -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: Malfunction 0010
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      53-Parking Brake -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door,Rear Left -- Status: OK 0000
      65-Tire Pressure -- Status: OK 0000
      76-Park Assist -- Status: OK 0000
      Address 03: ABS Brakes Labels: 3C0-614-095.LBL
      Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
      Component: ESP 440 C2 H015 0003
      Coding: 0046541
      Shop #: WSC 00028
      1 Fault Found:
      00778 - Steering Angle Sensor (G85)
      005 - No or Incorrect Basic Setting / Adaptation
      Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
      Part No: 1K1 909 144 K
      Component: EPS_ZFLS Kl.3 D06 1701
      2 Faults Found:
      02546 - Steering Limit Stop
      Freeze Frame:
      Mileage: 200 km
      Temperature: 53.0°C
      Voltage: 11.80 V
      Voltage: 11.60 V
      000 - -
      Freeze Frame:
      2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
      Quote Originally Posted by Outie5000 View Post
      And lets be honest, owning a diesel car is nifty.
      Apr 19th, 2006
      2010 Golf TDI
      06-03-2007 11:35 PM #2
      Fixed it.
      I had to reassign the steering assist to another number, THEN recalibrate.
      Thanks,
      David
    3. Member Theresias's Avatar
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      06-03-2007 11:48 PM #3
      Quote, originally posted by dhambrick »
      Fixed it.
      Mind explaining what you meant by "to another number"?
    4. Member
      Apr 19th, 2006
      2010 Golf TDI
      06-04-2007 01:10 PM #4
      Quote, originally posted by Theresias »
      In the Steering Assist under "Adaptation", you can assign a numbver relating to a specific steering assist.
      I had changed my seeting to "3" (from 5). In order to clear someting to allow the steering to be reset, I had to change (I changed it to "4").
      This apparently cleared something...
      I had followed the procedure as outlines numersous times with no effect, until I changed the adaptation setting.
    5. Member Theresias's Avatar
      Feb 11th, 2004
      Magdeburg, Germany
      06-04-2007 04:50 PM #5
      Let's call it coincidence, the adjustment definitely has nothing to do with the basic setting.
    6. Member
      Apr 19th, 2006
      2010 Golf TDI
      06-04-2007 05:39 PM #6
      After doing the adjustment >10 times with no clearing of the code (and no power steering) and over 3 hours of poring over the "how to" sections, I can say I am pretty much an expert on the adjustment process. It never worked.
      I started thinking of other things to do with steering. The only other thing I had changed was the assistance "number". Once I changed it, it must have cleared whatever was prohibiting the adjustment, because after the adjustment, the fault cleared in about 3 seconds.
      Anyhow, it is working now. I posted the resolution because it may happen to somebody else down the road.
      Thanks!
