VWVortex.com - attaching side skirts?
    Results 1 to 7 of 7
    Thread: attaching side skirts?
    1. 04-17-2002 08:46 PM #1
      has anyone had any success attaching side skirts without the proper clips?
      can someone post a picture of the clips & the plastic stripe that runs along the top of the skirts?
    2. Member FiveAinOne's Avatar
      Oct 5th, 2000
      SoCal
      1991 GTI 16v, 2004 Mazdaspeed Miata
      04-17-2002 09:50 PM #2
      here ya go..
      you can probably just use screws or rivits and it'll hold up good. If you don't want the clips I think you should still get the strip.. it'll make the top of the skirt fit tight to the body. I hate the clips.. its hell to push in, and it'll break the tabs on the skirt if you yank it off later. Sometimes I think the tabs are not in the clips, because the skirt doesn't look straight
      [Modified by FiveAinOne, 6:57 PM 4-17-2002]
    3. 04-17-2002 09:53 PM #3
      no pics man
    4. Member Weaver's Avatar
      Jun 24th, 2001
      Weaver
      04-17-2002 10:02 PM #4
      c'mon Steve, snap out of it
    5. Member FiveAinOne's Avatar
      Oct 5th, 2000
      SoCal
      04-17-2002 10:04 PM #5
      pic's there...
    6. 04-18-2002 05:37 PM #6
      i'm not sure what i'm looking at? can you explain abit?
      is the red the strip?
      vw says the strip is around $50 canadian - for each side & the clips run around $7 each.
      should i look for a used strip or would it be unusable?
      anyone have a pic of the strip & clips on the car (before installing the skirts)?
      May 28th, 2000
      Maple Grove, MN
      8V, 16V, 20V, 30V
      05-07-2002 09:10 PM #7
      Ya, I need 20 clips and 4 side strips. Have any of you tried anything else ?
