VWVortex.com - Project: Rabbit Farmer's 1.8T Golf IV (racing oriented)
    Page 4 of 22 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 547
    Thread: Project: Rabbit Farmer's 1.8T Golf IV (racing oriented)
    1. 07-28-2008 10:54 PM #76
      Quote, originally posted by friday »
      I like this car.
      Ditto
      TDI for the win !!!!!!!!!!!!!!
    2. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      MK1-MK4-WRX-Ford-Volvo
      07-28-2008 11:59 PM #77
      Thanks... a lot of blood/sweat/tears went into it.... plus grocery money.
      There was a little progress from when I purchased it....
    3. Member Susannah's Avatar
      Apr 28th, 2005
      Toronto
      Crowned pink RS OG, bagged and BTd. 330ci vert. pink RS the 2nd.
      07-29-2008 12:11 AM #78
      I love this car.
      You did good work son.
      Low.Life.Society | AAC | Unitronic
      Fame is a vapor, popularity an accident and riches take wings. Only one thing endures, and that is character.
    4. Member 2000APRGTI's Avatar
      Feb 21st, 2006
      STL
      92 lysholm gti
      07-29-2008 12:26 AM #79
      So what killed the first engine? hopefully not the tune since it looked like it..
    5. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      07-29-2008 01:07 AM #80
      Quote, originally posted by 2000APRGTI »
      Best guess is that the manual boost controller was loose and caused an over-boost situation. I now run an Electronic Boost Controller through the ECU and monitor engine activity via A/F, EGT, and boost levels.
    6. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      07-30-2008 01:56 AM #81
      Time to inspect the exhaust manifold to determine if I can remove the stud from the ATP manifold without removing it from the engine or replacing it with a SPA manifold if I had to remove the ATP setup. There was no way in heck I would reinstall the ATP manifold if I had to remove it.
      I had to remove the coolant line to remove the turbo (it is hanging from the Shine Racing anti-roll bar that I removed at NHIS last week when it was raining to reduce oversteer). Clean break of the stud.
      I borrowed a 90-degree angle head from my father so that I could get into the tight space between the engine and firewall.
      Drilled a hole in the center of the stud. I used a flute bolt extractor.
      Hmmmm, this looks like good news.
      I was able to remove the broken stud from the exhaust manifold, therefore, thus and hence, I will not be changing from the ATP to SPA exhaust manifolds at this time.
      When I was heading out the back door of the garage to make my way to my truck in the driveway (it still had a lot of my tools in it from the last event), I noticed that I accidentally left Daisy, my cat, outside instead of letting her inside before it got dark (this was around 11:30PM). Then I noticed that Daisy's tail looked a little too big and I then recalled that I did let both cats in when I got home from work. It seems the "cat" was actually very friendly and did not have the inclination to fire off a warning shot. This allowed from some photos, but I opted to use another door to reach my destination.
      I need to get some hi-temp loctite, new locking nuts and special heat washers (they help the nut stay tight) to get the car back together before the weekend. There are some other plans over the next few weeks (including changing the transmission fluid to Motul 300) that will help make this a fun car to drive.
      Sleepy time.
      Steve
    7. Banned friday's Avatar
      Dec 8th, 2007
      07-30-2008 03:08 AM #82
      waiting on those video's.
    8. 07-30-2008 05:01 AM #83
      Hey nice work . I know what you mean about the coil pack harness . i just did the whole thingalong with the new hitachi coils . the install of that harness was quite a wonderful time that is for sure. But it is worth it , the car runs crazy smooth now .
    9. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      07-30-2008 07:44 AM #84
      I had a problem with the video... something to do with MPEG2 output from my video camera wherein my video editing software can't see the sound.
      If you want to watch the video with no sound....
      NHIS with this Golf HERE
      Okemo hillclimb with the turbo Rabbit (first time driving it) HERE
      Watch the number of shifts in the Rabbit before the first turn (sound would make all the difference). Got into 5th before corner three.
      I am working on getting this corrected and uploaded, but getting the cars ready for the next two events is a higher priority for me.
      Steve
      Modified by Rabbit Farmer at 6:46 AM 7-30-2008
    10. Banned friday's Avatar
      Dec 8th, 2007
      07-30-2008 06:21 PM #85
      Your lines were a lot nicer then that corvette. Always fun to see an economy car hammer on the sports cars.
    11. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      10-23-2008 11:24 PM #86
      I need to find a slower forum so this doesn't keep ending up in the archives....
      I was going to bring both the turbo Rabbit and the Golf to the hillclimb this weekend (www.hillclimb.org), but it will take too much time to get both cars to the hill and it doesn't seem worth it as Sunday looks wet.
      Anyway, to drive both cars in the Prepared 2 class, the car must meet P2 rules (event though it is technically belongs in a lower class called Street Prepared). P2 rules requires that the car has a kill switch. I headed over to Joey Kale's place (www.kalescustom.com) and he welded on a plate so that I could mount the battery kill switch.
      Last night I installed everything using 4G wire. It seems that I should have used a thicker wire, so over the winter I will either add another 4G wire to the setup or use one larger wire for the whole setup.
      My goal was to have the switch on the inside of the car so that it didn't rust should it rain. I came up with the idea of where it is mounted and it seems to work great. I can roll down the window just enough to have access to the switch while my race number is still full visible. Best of both worlds.
    12. Member itsthatguyjustin's Avatar
      Jan 14th, 2008
      Rockland County, NY
      2000 VW Golf GLS
      10-24-2008 12:00 AM #87
      car looks sweet man.
      keep up the nice work.
    13. Member Greg_J's Avatar
      Oct 30th, 2005
      Grand Bend ON Canaduh
      '03 Wagon TDI, '16 GLI Autobahn 6MT
      10-24-2008 12:30 AM #88
      love it. i wanna see some videos of this thing in action, and some dyno!
      Quote Originally Posted by ennui_delphian View Post
      Don't anger canadiun lesbian...
    14. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      10-24-2008 09:16 AM #89
      Over the winter I am redoing the IC pipes (the kit sucks), adding bigger brakes, and doing a full dyno tune. I hope to have some better videos after this weekend's event (hillclimb). I will also have to brace the seats (FIA seats; 5 years without brace, then I have to brace to meet the rules) and replace the harnesses (rules are 3 years.... perfect harnesses will be for sale soon!).
    15. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      10-27-2008 05:35 PM #90
      Right click and save as.... VIDEO of the Golf at the starting line of the Mt. Philo Hillclimb. Great event (www.hillclimb.org)
      Steve
    16. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      11-03-2008 11:33 PM #91
      Philo has come and gone. Time to start planning for winter improvements for the track. I already have an extensive list started.....
      I managed to "break" and axle during a practice run on Saturday. The axle is a DriveShaftShop 425 HP axle so it wasn't power that did it in. I recently ordered a set of 475 HP axles from them and noticed a HUGE difference in the design... looks like a set of old Rabbit inner CVs, but a heck of a lot larger. Anyway, the 425 HP driver's side axle "broke" because a C clip that prevents the shaft from sliding towards the transmission, and therefore the tripod was allowed to slide inward to disengage itself from the cage... um, run on sentence... the C clip came off so the tripod wasn't contained. Easy fix... replace the clip and get a new inner boot.
      Finally, a great picture of me driving past one of the checkpoints (#5 on the hill) at Mt. Philo. Big thanks to Dave_G of the Sports Car Club of Vermont (www.sccv.org) for taking and sharing the photo.
    17. Member
      Nov 11th, 2007
      NY
      M3/Wrangler/Yamaha
      11-03-2008 11:56 PM #92
      sick man. i enjoy the build. a little tip. dont run a turbo to mani gasket and if studs are giving you a problem grab some m8 allen head bolts and nordlocks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... PVW 7.08 ... ... ... ... .. .
    18. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      11-04-2008 01:19 AM #93
      i love you
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    19. 11-04-2008 01:26 AM #94
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. Member Rally VW's Avatar
      Sep 7th, 2008
      Greensboro, NC
      Mark 4 GTI
      11-04-2008 01:39 AM #95
      What a great thread!!!! I love racing!!!!!! I should put up some rally pics.
      Your resident pilot
    21. Member J-tec's Avatar
      May 20th, 2006
      Berlin + Boston
      13' Scirocco R, 01' Jetta s256(For Sale!)
      11-04-2008 02:10 AM #96
      Wow great thread, just read through the whole thing. Interesting finds on the wiring harness! I noticed that too on my coil pack wires the other day, makes me think to check in other places as well I can't believe i hadn't seen this thread before, right up my alley.
      Only thing i must say is that i'm surprised you haven't either gotten a 3 spoke steering wheel or gotten a racing steering wheel with no air bag
      Great build and progress man, car has come a long way!
      I'll be staying tuned in for sure [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      11-04-2008 01:40 PM #97
      The airbag will be gutted (it isn't connected, but I have the understanding that centrifugal force may still set it off). Trying to make it LOOK street legal.... I drove it around town yesterday before putting it away. I think I scared a Civic with a fart can.
      I just uploaded this video... It is one of the morning runs. I don't have any of my fast runs as I lent the camera to someone else so they could get some in-car with their Subaru.
      http://www.youtube.com/watch?v=uqdo4xuZFu8
      Modified by Rabbit Farmer at 7:46 PM 11-4-2008
    23. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      04-28-2009 12:04 AM #98
      Pictures... the reason why people read forums and comic books... we don't need no stinking words!
      Since I can't weld (at least I don't think I can) or fabricate (I know I can't... king of measure once and cut a million times), Joey at http://www.KalesCustom.com (Kellogg Road in Essex, Vermont) did a lot to the Golf. Custom intercooler piping to and from the intercooler; relocated the BOV to just before the throttle plate; bracket to hold the downpipe (and support the turbo); custom exhaust utilizing the stock exhaust hanger to change the exhaust from side exit (done by Chris Achilles) to a rear exit as I realized that it was too loud (my fault for thinking I wanted a side exhaust); and relocated the battery to the rear; and adding another vent to the valve cover.
      Very good job!! I highly recommend Joey's welding skills and fabrication abilities. Of course, he is a Subaru expert, so the Subbie folks get a two for one expert in Vermont. Kudos, my friend!
      For those of you hooked on phonics challenged, I present some images for your enjoyment (with limited text interruptions).
      The bumper was removed from in front of the IC to allow better airflow. I picked up a trim piece to go around the IC from Chris Havas at http://www.MetalMarks.com (place for rally folks to get carbon fiber parts; located in Vermont, but can ship). I will install this soon when time allows.
      Okay, we have some options at the end of the exhaust. That is a V-Band clamp on there that allows for the straight pipe (there already is a muffler in the middle of the car) or a cat.
      Joey wired the battery in the rear of the car (or his buddy James who seems to be an electrical guru of sorts... and works on Subbies). I installed the battery box and made the bracket. It actually works pretty well.
      So, someone else made it onto the rear window of the car. I reserve this place for people/companies that make racing this car possible through their expertise, help, and skills. (with the exception of the SCDA1.com and vwvortex.com stickers... I'm sure they will get bumped soon) Added... KalesCustom.com (the .com didn't fit). Thanks Joey!
      Well, there is always a second (and third, and fourth) project in the house. This one I have been working on. New brakes, new bigger radiator, air dam, removed some panels on the front of the car to allow more air flow to the oil cooler and radiator, etc. Getting a new set of 22.5 x 9.5 x 13" mounted (yep, they are taller than my 20", but the price was right). The new radiator should solve the coolant leak. Enough for now... I plan to get the turbo Rabbit 100% ready for the first hillclimb of the season (Ascutney: check out http://www.hillclimb.org for hillclimbs in Vermont, USA); then I will focus on the Golf. Time is running short so I need Plan B (Rabbit) in place before focusing on Plan A (Golf).
      I have to make sure the Golf is track ready all season (i.e. no issues) so that I don't try Plan C again like I did in 2007... the wife's stock 2004 1.8T Jetta on my DOT R componds (235's) running a HPDE at Watkins Glen. Good times (I swapped the brakes over to EBC yellows and put on Bilstein Sports for the event), but it doesn't have the thrill of the Golf.
      Modified by Rabbit Farmer at 11:26 PM 4-27-2009
    24. Member DigitalN.'s Avatar
      Sep 13th, 2007
      Edmonton,AB
      '07 GTI
      04-28-2009 12:48 AM #99
      What coils are you running in the golf? I am looking for some racing coils, but all the 'tex seems to recommend is ones so I can slam it to the ground.
      Thanks!
      Quote Originally Posted by skatedvs420 View Post
      Will this work on my 1.8t vr6 w/ an intake?
    25. Member Rabbit Farmer's Avatar
      Sep 21st, 2003
      Earth
      04-28-2009 01:31 AM #100
      The coil over springs are from Shine Racing Services in Massachusetts.
      http://www.srsvw.com/
      The length of the springs that I purchased only lower the car a little bit, but they handle like hell!
