Just one for the archives as I could not find this information anywhere within the forums.
This setup assumes that you have replaced the A/C heater setup with one from a non A/C car. First thing you'll notice is that the non A/C blower is a three speed and does not use all the same connections as the A/C blower. These steps will allow you to use the factory A/C harness with the non A/C blower
This procedure was done on a CE1 harness. CE2 should be similar but some harness colors may be different. A jeweler's screwdriver worked well for removing the pins from the connectors.
First step is to get power back to the fan switch. To do this find the white three pin connector near the blower motor connector. This connector needs to be jumpered to allow the fan switch to get power.
You'll jumper the Black and Red stripe wire to the Red and White stripe wire
Test jumper installed
Next step is to repin the section of harness that goes between the main heater harness and the blower motor. Stock harness shown
This end goes into the motor. The individual wires that go to the A/C blower motor will be removed. The Brown wire will be completely removed, the Red with Black stripe wire gets cut underneath the heat shrink.
Default wiring for the harness end connector.
Modified harness end connector. Completely remove the brown wire, relocate the white wire to its location.
Modified fan motor connector. The White wire is left in its place.
Move the Red with Black striped wire to the top pin next to the white wire.
Move the soild Yellow wire to the right where the Red with Black wire was.
Move the Yellow with black stripe to where the solid yellow wire was below the white wire.
Reconnect the modified harness to the new blower motor. The fan switch should now behave where starting from the far left position; off, low, medium, high
Hope this helps someone in the future.
